I have started my first project in Premier Elements 7. After I have uploaded video clips I am only able to place six or seven clips on the board at the bottom before I get a message telling me the program has stopped working. My operating system is Windows 8. Could it be that I have insufficient space on my C: drive?
There is no program called Photoshop Premiere Elements. Since you're talking about video editing, I assume you're talking about Premiere Elements.
It's possible that you've run out of space or that your computer is under-powered -- but you don't list your specs, so it's hard to say. What processor do you have with how much RAM? How much free, clean, defragmented space is on your hard drive?
The more likely issue is that you're editing with version 7, which was designed pretty much to work only with tape-based miniDV and HDV video. It can't edit any of the modern video standards like MP4 and AVCHD. What model of camcorder is your video coming from and what is the video's resolution and format?
The video I am uploading is in MP4 format from my Sanyo camcorder. I would have to check on the video's resolution. Note that all the video files are uploaded successfully, the program only breaks down when I drag 6,7 or 8 clips to the timeline below (I am not looking at it now so I forget the correct name). If the MP4 format is the problem, can I change the files to the correct format using some sort of software?
Here are my specs (perhaps more specs than you need):
Operating System
Windows 8 Pro 32-bit
CPU
Intel Core 2 Duo E6300 @ 1.86GHz 82 °C
Conroe 65nm Technology
RAM
4.00GB Dual-Channel DDR2 @ 399MHz (6-6-6-18)
Motherboard
Gigabyte Technology Co. Ltd. G41M-Combo (Socket 775) 74 °C
Graphics
SMB2030 (1600x900@60Hz)
Intel G41 Express Chipset (Gigabyte)
Storage
465GB Seagate ST3500413AS ATA Device (SATA) 36 °C
298GB Imation M100 USB 3 USB Device (USB (SATA)) 30 °C
14GB ?????? ?? Card (USB)
Optical Drives
TSSTcorp CDDVDW SH-224BB ATA Device
Audio
Realtek High Definition Audio
Operating System
Computer type: Desktop
Installation Date: 02/12/2015 15:12:23
Windows Security Center
User Account Control (UAC) Enabled
Notify level 2 - Default
Firewall Enabled
Windows Update
AutoUpdate Download Automatically and Install at Set Scheduled time
Schedule Frequency Every Day
Schedule Time
Windows Defender
Windows Defender Disabled
Antivirus
Avast Antivirus
Antivirus Enabled
Virus Signature Database Up to date
Windows Defender
Antivirus Disabled
.NET Frameworks installed
v4.5 Full
v4.5 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
Version 10.0.9200.17607
PowerShell
Version 3.0
Java
Java Runtime Environment
Path C:\Program Files\Java\jre1.8.0_111\bin\java.exe
Version 8.0
Update 111
Build 14
Path C:\Program Files\Java\jre1.8.0_121\bin\java.exe
Version 8.0
Update 121
Build 13
Path C:\Program Files\Java\jre1.8.0_66\bin\java.exe
Version 8.0
Update 66
Build 18
Path C:\Program Files\Java\jre1.8.0_91\bin\java.exe
Version 8.0
Update 91
Build 14
Environment Variables
USERPROFILE C:\Users\Roger_000
SystemRoot C:\WINDOWS
User Variables
DASHLANE_DLL_DIR C:\Users\Roger_000\AppData\Roaming\Dashlane\4.8.3.33797\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components;C:\Users\Roger_000\AppData\Roaming\Dashlane\4.8.3.33797\ucrt
Path C:\Users\Roger_000\AppData\Roaming\Dashlane\4.6.5.21982\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components
C:\Users\Roger_000\AppData\Roaming\Dashlane\4.6.6.23032\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components
%DASHLANE_DLL_DIR%
TEMP C:\Users\Roger_000\AppData\Local\Temp
TMP C:\Users\Roger_000\AppData\Local\Temp
Machine Variables
asl.log Destination=file
CLASSPATH .;C:\Program Files\Java\jre1.8.0_121\lib\ext\QTJava.zip
ComSpec C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK NO
NUMBER_OF_PROCESSORS 2
OS Windows_NT
Path C:\ProgramData\Oracle\Java\javapath
C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\System32\Wbem
C:\WINDOWS\System32\WindowsPowerShell\v1.0\
C:\Program Files\Common Files\Ulead Systems\MPEG
C:\Program Files\QuickTime\QTSystem\
As I said, version 7 was not designed to edit non-tape-based video. it's not going to work well with an MP4.
If you're going to edit MP4s, I'd very much recommend you upgrade to at least version 11.
Though you're also going to have trouble editing any video with your current video processor. Your processor rates about a 1700 on this benchmark chart. In my books I always recommend editing with a processor that rates at least a 5000.
I can't afford to upgrade and I only use the program every so often so it looks like I'm stuck with something that doesn't work. What format was used with tape cameras?
miniDV and HDV.
Further to all of the above, I converted my MP4 files to MPG and was able to load 50+ clips (as against 6 or 7 MPREG). After that I got the same error message I got before. Doesn't this suggest that my problem is space related rather than processor related? I now have to work out the best way to use the stabilizer.
Not necessarily. Since version 7 didn't edit MPEGs natively, it was easy to overload the program.
As I've said, version 7 pretty much worked natively with miniDV and HDV tape-based video.
