Only "some" page numbers export to PDF?
Aug 03, 2017 Aug 03, 2017
I'm very puzzled. I have a 46 page document made in InDesign CS4. Page numbers are on a master page and they all show up correctly within InDesign. Once I export to PDF, however...I get pages with correct numbering 1-6...then after that only even pages. So 7, 9, 11, 13, etc are all without a page number showing up but the even pages have their number showing up. I've tried everything I can think of: make sure the object is arranged at the front, change font color, change location on the page...even delete page numbers and insert new page numbers. The result is the same every time.
What is odd is that when you view the PDF exported document, you can use the mouse to "highlight" where the page number should be...copy, and paste it into a text editor. The page number exists and is correct...but it appears to be "hidden."
I can't figure out why one odd page number (page 5) would correctly show up but the rest do not.
Thoughts?
1.8K
Try putting all of your auto page numbers on a separate layer on the master page and make that layer the top layer of the document and see if that solves your problem.
Aug 04, 2017 Aug 04, 2017
Yes i Think this is the best Way to find the Problem. There is an option in the layer panel (i'm not sure of my translation) "Show all" or "Hide all" or something like that (French inside )
I thons the best to do is redoing an another master page with page Number and apply it. And i Think the problem gone.
I just want to add to my post above that you should also check that the page numbers that are not showing up are still controlled by the master page. Whether they are or not make sure that they are also on the top layer that you are creating for page numbers.
Thanks for your suggestions. I have tried putting the page numbers on a new top layer and there is no change in the output. I cannot understand for the life of me why odd-numbered "page 5" shows properly while all other odd page numbers are hidden. All pages correspond to the same master pages.
Are you making a print pdf or is it an interactive one. If it is an interactive one have you used any interactive elements—such as a button—on the pages in question. That was my theory in suggesting putting the numbers on a separate top layer. Interactive elements will always "blot out" non-interactive elements that are on the same layer or below so they need to be put on a separate layer above. My suggestion in my second post is to make absolutely sure that the numbers on the pages that are not printing are definitely by themselves on the top layer because sometimes it is easy to forget that we've detached something from a master for whatever reason.
Just producing a press-quality PDF for printing. Nothing interactive, no form buttons or anything like that.
I've made sure the page numbers are on the top layer. I decided to send the InDesign package to the printing company which is also a design house and they are InDesign experts. I've asked them to find and correct the problem, and let me know what it is.
Good luck!
46 pages is an odd number for a publication, shouldn't that be 48?
Instead of choosing Press Quality for your PDF, you'd probably be better choosing PDF/X-4.
InDesign CS3 is quite an old version, as a matter of interest what OS are you using?
It's CS4 - still old, but I'm not interested in a subscription. Its running on OSX 10.9 Mavericks.
This publication is a product catalog.
Guide ,
What do you see on your InDesign page 7 when overprint preview is on?
I can replicate your issue when a few odd conditions are met; (I'm using InDesign CS6)
1. The page number on the master page has the transparency effect Screen applied.
2. You are viewing InDesign with the display performance set to- Fast Display*.
3. There is a white box on page 7 below the page number.
I assume the missing page numbers are not on a black background with the page number set to overprint.
*Edit, the Fast Display option can be applied to the object only (the page number on the master page), and overprint preview will not show the missing page number.
With the overprint preview on, all the odd pages continue to show correctly in InDesign but not as an exported PDF. No transparency effects are applied; I checked. I'm using typical display but this still wouldn't effect a PDF output. There is no white box. Basically, the pages numbers are in white against an orange box. I tried moving the page number right into the main page area and changing font color, but to no avail.
Guide ,
Did you try exporting your InDesign file to IDML, then opening the IDML file and saving it to a new file? Does the problem persist?
Can you make a stripped down version of the file, package, Zip and upload it, then post a link so we can have a look?
Edit: Are you using Acrobat or Reader to check your PDF?
