infrequent and generic error on <cfinclude>
Oct 29, 2008 Oct 29, 2008
I'm experiencing an intractible and difficult-to-explain problem with a framework-level coding structure.
My index.cfm ends with a <cfinclude> tag that brings in the page template. It works just fine - *most* of the time. Every now and then that line of code throws a very generic error that only reports the line number.
The code reads: <cfinclude template="#PageInfo.Page.PageTemplate#">
I assure you that the variable contains an absolutely valid template value. I have proven this over and over.
Instead of attempting to explain the truly arcane and numerous factors that I've discovered, let me ask a simple question: Does anyone know why <cfinclude> would throw a generic error when the template most certainly exists? How can I address this?
Advanced techniques
826
You could always do a cftry, and when it fails, dump the cfcatch structure into an email and send it to yourself. If nothing else, it might give you some more information.
Good Idea. I'll give it a (cf)try.
Thanks.
Oct 30, 2008 Oct 30, 2008
Dan -
I catpured an error at 10:30 last night. The "type" is java.util.EmptyStackException.
Although the on-screen errormsg showed one error at line 87, the cfcatch dump shows TWO elements under TagContext. Both are CFINCLUDES, as shown below.
Is this meaningful to you?
1 struct
COLUMN 0
ID CFINCLUDE
LINE 87
RAW_TRACE at cfindex2ecfm2088046539.runPage(D:\Inetpub\tas\index.cfm:87)
TEMPLATE D:\Inetpub\tas\index.cfm
TYPE CFML
2 struct
COLUMN 0
ID CFINCLUDE
LINE 177
RAW_TRACE at cfApplication2ecfc1561683104$funcONREQUEST.runFunction(D:\Inetpub\tas\Application.cfc:177)
TEMPLATE D:\Inetpub\tas\Application.cfc
TYPE CFML
so... what's the code on line 87 in index.cfm and on line 177 in
onRequest() in Application.cfc?
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Thanks for your interest, Azadi.
The code on line 87 of index.cfm is as stated above:
The code in application.cfc line 177 is in the OnRequest function and states:
<cfinclude template="#Arguments.targetPage#">
Again, I assure you that the template name variable referenced on line 87 is absolutely valid. I also presume that the Arguments.TargetPage template is valid as part of the CF framework structure.
I am stumped!
Oct 31, 2008 Oct 31, 2008
In index.cfm, add cfdump pageinfo to the mail you send yourself. In application.cfc, cfdump the arguments.
Documentation
