No text shows when i publish online
Aug 05, 2017 Aug 05, 2017
Hi
Im running indesign cc 2017 in windows 10 home.
When i publish online, textboxes doesn´t show.
i have
uninstaled and reinstaled.
Started so many new documents
import other docs from webb
But the result is stil the same
What is the problem???
Håkan
716
Adobe Employee ,
Can you post some screenshots of the original file and what you see when you publish online?
Also, can you see the text boxes when you export to .pdf?
-Aman
Hi
yes i can see the textboxes when i export them to a pdf.
The textbox with 2 columns down right is just one of my last tryes to solve the situation.
What happens if you export it as an interactive PDF?
Hi Derek
The result are stil the same
You mean the text that shows on the screen doesn't show on the PDF, just the images?
Hi
Some text occur, but it seems to be the first inserted textboxes. But then of a sudden, they refuses to be seen.
The images are ok.
The text arn´t even included in the onlinepublished if i use a form downloaded from the webb, a form that i haven´t done any changes.
So not all the text is text that you've created in text frames in the usual way – is that so?
You presumably haven't got text on Master Pages (apart from things like page numbers).
Hi
i have one small textbox, images and a few colored boxes on the masters.
result when publish
So is this text in a text box, perhaps with Paragraph and Characters styles applied?
well, funny enough. But that box works ok actualy. Its more the small squared boxes over the green on the sides that isnt working.
Have a look at your Layers panel – see if rearranging the order might work.
You might have something there... But its a bit tricky anyway.
Big thanks Derek, havn´t solved the problem yet. But changes are happening.
Haha, and all off a sudden... it turns up like this...
Have you tried viewing the Publish Online document in a different web browser?
Hi Steve
Yes, i have tryed that. No luck though.
And, so is it back again.
No hidden boxes, images anything underneath.
Something is happening when i change the sizes of the boxes... Don´t now more than that
Images works just fine.
