Hi there
After a windows update last night my keyboard and mouse stop working when open Adobe InDesign CC 2017. they keep on flickering on and off i can not select anything to open and keyboard doesn't type. the files i am working in still open but can not work on them or on a new document.
does someone knows what to do??
This helped me, has fixed the problem.
Is it a wireless keyboard? If so, check the batteries first.
If it is a USB keyboard and mouse try unplugging them and then replugging them into a different USB port than they were in previously.
Does the keyboard work normally when you are not in InDesign?
Is your keyboard working today?
I just had my computer updated and now only in InDesign my keyboard doesn't register. I use a lot of numbers and I have to hit the keys repeatedly to get it to type, same with the delete key. I swapped out keyboards so that is not the issue.
Anyone else? this is driving me crazy as I have to keep a vigilant eye on what is being typed and typos are now high - not good.
Me too! Although I haven't just updated Window, but I did just update Indesign.
It seems to just be numbers, both the numpad and normal number keys. Same issue with both a wireless keyboard and the laptop keyboard.
I'm currently working on a job inserting/updating numbers so it's driving me crazy.
The link below seemed to fix the issue thank you! Big Big Thank You!
