hi
i been using lightroom for a lot of years. i use the stand alone ver 6. today i tried to update to ver 6.12 but without success. i tried to remove and install again for a few times and always the same problem , raf files wont recognized by lightroom. i try to download the cc ver but the problem apper again, also i tried to update camera raw to 9.12 but it didnt help.
please help..
What version do you actually have installed? What camera model do you have? What operating system (Mac or Windows)?
thanks, i used ver 6.9 but after unistall ans install again at the start of lightroom i see ver 6.0/
i use windows 10, camera fuji xt2, fuji xpro 2. no problem with cr2 files..
thanks again
You cannot update Lightroom with the camera raw plug-in because Lightroom doesn't use it. Also, there isn't a separate update for Lightroom CC. There is only one Lightroom program and only one Lightroom update. The only difference is how you have activated the program. Here is the link to where you can download the .12 update and install it manually:
After you get that update installed, you should have support for both cameras.
thanks, but the same massege "the file is not recognized by the raw format support in lightroom"
Then you haven't installed the update is my suspicion. That is the only possible answer. Did you download and install the latest update from that link that I gave you?
sure. from the link you send
my
In that link there is a download for the original version, 6.0/2015.0, then a list of updates for both Mac and Windows. you have to manually download and then install the .12 update.
thanks, can you please add the link to the update?
It is in that Download PS Lightroom link.
yes, thanks , u trued it before and now, "update failed"
thanks guys for you help..
What is the full error message? Any error code?
i tried to download thrgue criective cload the cc ver and i get error 6/
this is the link
i look my files all the all the Microsoft Visual C++ that was in this error, updated them, but no sucses.
That's a link to your local hard drive. No-one can see it but you.
At this stage, no-one really knows what you are doing so no-one can really help you.
sorry' i didnt noicth that
this is the error
Exit Code: 6 Please see specific errors below for troubleshooting. For example, ERROR: DW003, DW071 ... -------------------------------------- Summary -------------------------------------- - 0 fatal error(s), 12 error(s) ----------- Payload: Microsoft Visual C++ 2008 Redistributable Package (x64) 9.0.30729.5677 {512B6D21-18F9-11E2-93C1-00215AEA26C9} ----------- ERROR: DW071: ERROR: DW003: Third party payload installer vcredist_x64.exe failed with exit code: 1638 ERROR: Failed to install Microsoft Visual C++ 2008 Redistributable Package (x64). Please try installing it by double clicking on the executable at "C:\Users\yaniv\AppData\Local\Temp\{402C2895-7CF1-4A23-A0A7-551DD2F98D70}\Lightroom_6_LS11\payloads\Microsoft VC 2008 Redist (x64)\vcredist_x64.exe", or download and install the latest Microsoft Visual C++ 2008 Redistributable Package (x64) from Microsoft website - www.microsoft.com ----------- Payload: Microsoft Visual C++ 2008 Redistributable Package (x86) 9.0.30729.5677 {539B5BB0-18F9-11E2-BBBC-00215AEA26C9} ----------- ERROR: DW071: ERROR: DW003: Third party payload installer vcredist_x86.exe failed with exit code: 1638 ERROR: Failed to install Microsoft Visual C++ 2008 Redistributable Package (x86). Please try installing it by double clicking on the executable at "C:\Users\yaniv\AppData\Local\Temp\{402C2895-7CF1-4A23-A0A7-551DD2F98D70}\Lightroom_6_LS11\payloads\Microsoft VC 2008 Redist (x86)\vcredist_x86.exe", or download and install the latest Microsoft Visual C++ 2008 Redistributable Package (x86) from Microsoft website - www.microsoft.com ----------- Payload: Microsoft Visual C++ 2010 Redistributable Package (x64) 10.0.40219.325 {54B0C34F-18F9-11E2-BC1D-00215AEA26C9} ----------- ERROR: DW071: ERROR: DW003: Third party payload installer vcredist_x64.exe failed with exit code: 1638 ERROR: Failed to install Microsoft Visual C++ 2010 Redistributable Package (x64). Please try installing it by double clicking on the executable at "C:\Users\yaniv\AppData\Local\Temp\{402C2895-7CF1-4A23-A0A7-551DD2F98D70}\Lightroom_6_LS11\payloads\Microsoft VC 2010 Redist (x64)\vcredist_x64.exe", or download and install the latest Microsoft Visual C++ 2010 Redistributable Package (x64) from Microsoft website - www.microsoft.com ----------- Payload: Microsoft Visual C++ 2010 Redistributable Package (x86) 10.0.40219.325 {55B82130-18F9-11E2-8D43-00215AEA26C9} ----------- ERROR: DW071: ERROR: DW003: Third party payload installer vcredist_x86.exe failed with exit code: 1638 ERROR: Failed to install Microsoft Visual C++ 2010 Redistributable Package (x86). Please try installing it by double clicking on the executable at "C:\Users\yaniv\AppData\Local\Temp\{402C2895-7CF1-4A23-A0A7-551DD2F98D70}\Lightroom_6_LS11\payloads\Microsoft VC 2010 Redist (x86)\vcredist_x86.exe", or download and install the latest Microsoft Visual C++ 2010 Redistributable Package (x86) from Microsoft website - www.microsoft.com -------------------------------------------------------------------------------------
THANK YOU ALL. I FORMAt my pc and download again, everythink works o.k. thanks again
