I'm trying to use an Action in PS, but the last several times I've tried it,
I get this message " The Command " Select " is not currently available,
Well if that's the case, then it hasn't been working for a couple of weeks.
Does anyone know what I can do to fix this, I need it to edit new photos.
Janice
I figured it out, it's not a PS problem, it's the action itself, I tested another action, by selecting my action & clicking on 'play' & it worked just fine. I will get in touch with the company that I bought this action from. I appreciate your help
Check the steps of your action: You can open the entries like in this screenshot.
Do you have to make the selection BEFORE you start the action?
Is there a command recorded which deletes your selection?
Fenja
Yes, when I open up the action , I click on ' play' & that is when I get the message & no to your other question, no command recorded which deletes the selection ..
thank you
But the action needs a selection - this is what the error message means.
Did you change your workflow a little bit?
What is the action for?
And, please, provide a screenshot of the actions panel with the relevant steps visible.
Fenja
