Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Is it possible to inject a @reference object in a service with normal initialization?
Avatar
Level 4
Hi all,
Is it possible to initialize the object in class with @reference in a service with normal java initialization?
Example:
This is the class
public class AEMUtilImpl implements AEMUtil {
    @Reference
    private ResourceResolverFactory resourceFactory;
    @Reference
    private SlingRepository slingRepository;
If I'm initializing this class in another class (like a servlet) like this:
AEMUtil aem = new AEMUtilImpl();
resourceFactory and slingRepository is always null.
If I initialize like this in a servlet
@Reference
AEMUtil aem;
resourceFactory and slingRepository do get initialized and works properly.
What is the reason behind this? Is there anyway we can initialize by using the first method?
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
Hi
   As per Apache Felix documentation Apache Felix - SCR Annotations @Reference annotation is defined as below
     @reference is used to refer any service registered in your osgi console. So until you declare your class as a service , if you try to refer it using @reference annotation it is going to return you null.
I would try to explain you in a plain language . One service can be referred only in another service.
That means, if AEMUtilImpl is a service, then all the below objects will return you a valid object.
So your code snippet should be something like below
public interface AEMUtil {
@Service
@Component(metatype = false)
@Reference
    @Reference
And in this case you should not initialize or cannot do the below
This service should be initialized in any other service as below
@Reference
AEMUtil aemUtil;
or in any Java class , you can use bundle context to get the object of the class as below
servlets - Getting OSGi services from a bundle in Sling/CQ - Stack Overflow
Hope this helps !! . Let me know if this is not what you are looking for .
Veena
Avatar
Level 10
To use @Reference in a backend Java class - make sure you are using @Component and @Service annotations - see this article as an example --
Adobe Experience Manager Help | Injecting a DataSourcePool Service into an Adobe Experience Manager ...
Hope this helps....
Avatar
Level 7
Your normal class is not registered in OSGi.. So you cannot use any of service in it... Even if you just use @Component annotation you can use other OSGi components in your class..
Avatar
Level 4
No the servlet is registered. so is the service impl but when i do
AEMService a = new AEMServiceImpl();
all the instance variables inside the impl class is null.
but when I do
@Reference
AEMService a
the instance variables inside it like
@Reference
do get initalised. I was thinking if there was any work around to make first approach work
Avatar
Level 5
Hi Vitis,
If  i am not wrong you are calling the class from Sling servlet if it is than you can do one thing.
In the servlet you write
public class Servlet extends SlingSafeMethodsServlet {
@Reference
@Reference
//your code and call your class in doGet or doPost like yourClass y = new yourClass(resourceFactory,slingRepository);
And these value in your normal class as constructur and assign these values in constructor.
Avatar
Correct answer by
Community Advisor
Hi
@Service
@Reference
    @Reference
@Reference
AEMUtil aemUtil;
Veena
Avatar
Level 4
Thank you! This was very helpful.
