Hi, i use the latest version of photoshop cc 2017 and windows 10 64 bit (build 16257.rs3)
About a week ago i can not use all the tools correctly. Example
Using the brush tool instead of coloring drags the image and so on with all the tools.
What can be the solution?
I apologize for my English but I'm using google translate
Please do these steps in this order
1.)Photoshop menu Edit>Preferences>General Click the Reset Preferences On Quit Button
(Uninstalling and reinstalling Photoshop does not reset User ID Photoshop Preferences)
2.) Create a file PSUserConfig.txt in you user ID Photoshop Preferences folder
"C:\Users\your Id\AppData\Roaming\Adobe\Adobe Photoshop CC 2017\Adobe Photoshop CC 2017 Settings"
with these two lines:
# Use WinTab
UseSystemStylus 0
3.) Use Wacom Tablet Preference File Utility to remove all W
...Copy link to clipboard
Try resetting your Wacom Intuos Preferences. If the does not fix your problem try resetting your Photoshop preferences. I configure Photoshop and wacom to use Wintab API for Pen stpport not Windows INK.
the version of wacom driver is the latest, the version of windows 10 is 1703 build 16257.1
if i uncheck " use windows ink" and insert psuconfig in photoshop config i dont have pressure on the brush
P.S.
Both photoshop and wacom drivers have been uninstalled and reinstalled
Try resetting all tools.
To do this
Let us know if this works.
If not you may want to try and rest preferences to factory defaults
No doesn't work
So try going to factory defaults and see if that works.
HTH
.mj
are you sure is del ?
ok, i have reset preferences, but i don't have pressure on brush
What version of Wacom driver. I showed you I have the same Windows version, and Photoshop version and an Intuos Pro Small as you. The version of Wacome and my Wacom and PS configures to use Wintab API. I do not have a problem like you have. Use the Wacom utility to delete all wacom preferences and start from its defaults and configure your preferences from there. Start PS with Shift held skip loading thirt party plug-ins. Uninstalling PS doe not rest your user ID Photoshop Preferebces. Make sure you reset them.
OK, I agree with JJ Mack.
We need to try and sort out your Wacom drivers.
Before you do that though, do you have another application like Ai or Lr that can handle pressure?
Try it there to see if the problem is universal or exclusive to Ps please
ok i reinstalled the driver (6.3.23-1)
i try on Ai and the pressure go (uncheck use windows ink)
i try on affinity and work
i try on krita and work
i think is a ps problem
# Use WinTab
UseSystemStylus 0
3.) Use Wacom Tablet Preference File Utility to remove all Wacom Preferences one you machine start new.
4.) Open Wacom settings.
Add Application Photoshop
A the Pen device
Use pen Mapping tab for Photoshop un check Use Windows Ink - For PS I also force proportion monitor 1
Use Pen Tab turn Tip Double Click distance OFF
Use Touch for Photoshop Standard Gestures to set you preferences for Photoshop.
5.) Wondows Control Panel Pen and Touch
Flicks Tab Un Check "Use flicks to perform common actions quickly and easily "
Pen Options Tab
Press and hold Right-click Settings
Un Check "Enable press and hold for right clicking"
Ok, I downloaded the wintab.dll library from the microsoft site, replaced the file.txt and now it goes. Thanks a lot for the help you gave me.
I do not have that dll on my machine only a wintab32.dll exist???
Is the same thing, there is also wintab64.dll
