Every time I select Exposer brush it goes to custom brush when I try to use it
Grant,
I did a little experimenting. If the exposure slider is set to zero when I select the "Exposure" preset, then when I click on the image with the brush, the preset field changes to "Custom", and the slider stays at zero. It's odd, but hardly a major problem. The sliders seem "sticky": if I'm in the Exposure preset and set the Exposure slider to zero, it will be zero the next time I invoke the Exposure preset.
This is a badly thought out interface design, but it shouldn't be that hard to work
...Copy link to clipboard
which program?
Sorry Lightroom have the same problem with adjustment brushes and the radial filter. If I choose exposure the as i use it changes to custom
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to specific Program forum... Mod]
Of course it does. Whenever you change one of the sliders so that the new configuration doesn't match the "effect" preset selected, the preset changes to "Custom". This is the way it should work, not a bug.
Hal
Thanks for your answer but the exposure button is the only one that does this. I have tried resetting the brushes to default but no joy
OK. I misunderstood. Are you saying that if you set the brush to the Exposure preset and then draw a brushstroke on the image that the preset field changes to "Custom"? If so, are any of the other sliders changing? In other words, is the problem only with the label, or does it affect your editing adversely?
What version of LR are you using? And what OS?
Hal
Hi Hal as far as I can tell it is happening on the exposure and highlight brushes. when the brush changes to custom so do the sliders they go to a zero setting
I am using 2015.12 Lightroom
IOS 10.12.6
Grant,
This is a badly thought out interface design, but it shouldn't be that hard to work around.
Hal
Thanks Hal thats seems to be the problem. It was never a show stopper just a bit odd when it happened thanks
