Text Box Shadows
Oct 27, 2008 Oct 27, 2008
PowerPoint 2007
Presenter 7.0.1
Add text box
Add text to text box
Select box (not text), and Format > Shape Effects > Shadow, select a shadow
The shadow is applied only to the box (not the text inside the box)
Publish the presentation. When it's online, note that the text inside the box has acquired the shadow attribute also.
In addition to another bug which causes shaded text to look blurry (instead of shaded), this means that all text inside of my shadowed boxes look corrupted.
Presenter
872
Oct 28, 2008 Oct 28, 2008
Adobe Employee ,
Oct 30, 2008 Oct 30, 2008
I also observed the same.
One workaround i can suggest. You are using PowerPoint2007, PPTX is the default file in PP2007. This problem is seen for PPTX file not for PPT file.
You can save your presentation as PPT (Save as->PowerPoint 97-2003 format) and you will not see this problem.
Oct 31, 2008 Oct 31, 2008
That's not much of a workaround. I lose a lot of PP2007 functionality when I do that. The whole point of our recent upgrade from Office 2003 and Presenter 6 to Office 2007 and Presenter 7 is to gain additional functionality.
As soon as you say to publish in the older version, I lose all of that additional functionality. And it takes longer to publish this way. And as things are converted from the newer version of the programs to the older version ("Compatibility Profiles") some things get paginated and positioned differently, so I'll be creating an inferior end-product.
A better workaround is to create an empty shaded and formatted box and send it to back. Then create an unformatted text box which contains the text and send it to front, and position it on top of the formatted text box.
This still creates additional work. Any time I change text, I'll have to resize two boxes to fit a position, etc. Plus, I can't paginate text within the text box without it looking bad.
Help resources
