Change leading value
Participant ,
Jul 31, 2017 Jul 31, 2017
I have some paragraphs with overrides applied manually across the document.
I want to apply the leading that are in each respective paragraph styles without do the clearOverrides method because I have italic or colored words with no char style applied that I don't want to "clear".
Thank you in advance.
Scripting
1.2K
People's Champ , Jul 31, 2017 Jul 31, 2017
You can use everyItem() in a collection purpose but you would still need to introspect every single paragraph as they may have different leading values.
var myParas = app.activeDocument.stories.everyItem().paragraphs.everyItem().getElements();
var n = myParas.length;
while ( n-- ) {
myParas.leading = myParas.appliedParagraphStyle.leading;
People's Champ ,
myPara.leading = myPara.appliedParagraphStyle.leading;
Participant ,
And the var myPara would be? I tried app.activeDocument.stories.everyItem but not work.
People's Champ ,
while ( n-- ) {
Participant ,
Works!
Yeah I forgot to say that are various paragraph styles with different leadings. Sorry...
Thank you!
Participant ,
Aug 03, 2017 Aug 03, 2017
Hi! I'm back!
I'm trying to apply this method only in a selected group with various elements, even other groups, include text frames that where my paragraphs are using selection[0] but I saw that this is not the way. I don't want to ungroup...
How I can achieve this?
People's Champ ,
Given that app.selection[0] is your group you need to introspect allPageItems property which is an array. If the nth item is of kind TextFrame you can then apply paragraphs changes.
Participant ,
I see that's the way, but I don't know how to put this theory in the code. I'm a novice in javascript with indesign.
Can you help with the code? Sorry to bother you again
Participant ,
Aug 08, 2017 Aug 08, 2017
I tried this, but nothing...
var mySel = app.selection[0];
var myEveryGroup = mySel.groups.everyItem().allPageItems;
var myParas = myDoc.stories.everyItem().paragraphs.everyItem().getElements();
for(var i = 0; i < myEveryGroup.length; i++)
        for (var j = 0; j < myEveryGroup.length; j++)
                myEveryGroup instanceof TextFrame && myEveryGroup.paragraphs.properties = {leading: myParas.appliedParagraphStyle.leading};
Participant ,
I did it:
                myEveryGroup instanceof TextFrame && myEveryGroup.paragraphs.everyItem().leading = 14;
To change the leading to a specific number, but don't know how to do with "appliedParagraphStyle" method.
Participant ,
Any light [Jongware]​ ? I mentioned you because maybe Loic.Aigon is busy.
Engaged ,
var myGroup = app.selection[0];
// Building an array:
var myGroupItems = myGroup.pageItems.everyItem().getElements();
myGroup.ungroup();
// If you like a selection of the ungrouped items:
app.select(myGroupItems);
while ( n-- ) {
myObj = app.selection;
app.activeWindow.activePage.groups.add(myObj);
AP
Aug 09, 2017 Aug 09, 2017
Ribnog  wrote
I did it:
if you are after all items stored in app.selection[0] (I suppose a group of items of unknown depth with a nested structure) just get them like that:
var arrayOfPageItems = app.selection[0].allPageItems;
Then loop the items for text frames. Something like that:
for(var n=0;n<arrayOfPageItems.length;n++)
    if(arrayOfPageItems.getElements()[0].constructor.name != "TextFrame"){continue};
    arrayOfPageItems.parentStory.texts[0].leading = 14;
Hope, that helps…
What I did not understand:
What do you mean by "how to do with "appliedParagraphStyle" method"?
Would you like to apply the new leading value only to paragraphs, that are formatted with a distinct paragraph style?
And if yes, would you like to have a locale override with leading? If not, just change the paragraph style…
Uwe
Participant ,
Hi Laubender​
I need to use the script in groups that I have to increase the size to 200%, so when I do that the text increases too. So to not have to ungroup them and apply your styles with your correct leading and pointSize (yes, I will need to change the size of the text too) I will need this.
So the appliedParagraphStyle is because in those groups I have text frames with differents text sizes and leadings and all of them have your own style so to not change one by one I think is more easy apply your respective styles to back to your right properties.
I think override.ALL works, but if some text have italic will miss it.
I hope you understand, my english is not very good.
