How to detect a coincidence of an image part ?
Aug 09, 2017 Aug 09, 2017
How to detect a coincidence of an image part ? I need to detect a coordinates of top left corner of an image. Is it possible?Untitled-1.jpg
a part
a coincidence
Actions and scripting
631
Adobe
Aug 12, 2017 Aug 12, 2017
Please elaborate.
I have already elaborated as I could...
Good luck!
I don't believe that's possible with PS scripting.
Guide ,
Aug 13, 2017 Aug 13, 2017
I think it might be possible.
First select the white, select inverse, make work path.
Make arrays of all anchor point for each subpaths
Make temp arrays of subpath anchors subtracting the lowest first anchors x & y
Once you have these you can do a string match on the arrays.
Just an idea?
I think in this case that would not work immediately as you described because the »part« is clipped (lower left), so the part and the instance would not even produce paths with the same number of pathPoints.
If one starts comparing segments of the paths the approach would likely become quite complicated …
Guide ,
Thats why I said String match, not by individual pathpoints, by converting to a string I believe it should work.
Aug 14, 2017 Aug 14, 2017
How far to go? Include Bezier handles, round the numbers …?
I would like to detect some areas in pdf document which can be vary in position by Y coordinates.
Seems like a problematic idea and a relevant piece of information you should have mentioned right at the start.
I suspect that if the pdf has to be converted even optically »identical« elements might produce Work Paths that differ too much for easy identification.
andyf6586786​, what is this supposed to be for anyway?
What kind are the images and what is the ultimate goal?
I would like to detect some areas in pdf document which can be vary in position by Y coordinates. Those areas are known how they looks like so detecting their coordinates will open the ability to paste other image in exact position in opened pdf file.
Those images in the first top most post is just a samples to describe the idea...
What »areas« would that be and how can they be identified?
I would recommend you provide an actual example file – which you should have done that right away.
Edit: Actually better provide more than one file.
I have reviewed an original task to make it easy to complete so to continue the quiz please follow the link
Iterating image lines pixel by pixel
Aug 15, 2017 Aug 15, 2017
If you had given a proper description of what you wanted to achieve right away this could have gone easier …
