Hello, I'm doing my 1st website in the Muse. And I need help:
Is possible to pin a object to browser in lighthouse.
I put an image to help explaining.
Thank you
This is possible if you use css code.
<style>
#u00 {
position: fixed;
left: auto;
margin-right: auto;
margin-left: 334px;
</style>
#u00 = ID of your object
margin-left = your value
… and what is a „lighthouse“?
Which widget do you use?
Sorry, I wrote it wrong. Wanted to write lightbox.
I used the Widget / Compositions / blanck in the position "lightbox".
You want the text to sty and the umages to the left scroll? No, unfortunately this isn't possible.
What wors (a slightly different approach:
Simply place the text to the right (where it is now) and place a slideshow to the right "into" the composition widget.
Configure the slide transitions as "vertical" and set the rest just as you like.
As I said: A slightly different approach, but not so far from your idea.
<style>
#u00 {
position: fixed;
left: auto;
margin-right: auto;
margin-left: 334px;
</style>
@Pavel Homeriki That's what I wanted to do!
Can you explain me step by step. I try, but I'm not able to do the id object.
Thank you
Preview in the browser and examine the object with the help of the browser code inspector, In order to get it id.
Thank you very much!
Is it possible to clear the css code when moving to the next target?
New target = new object with a different id
Add the ID of the next object to the code, separated by a comma.
You must place your block with the text inside the target window. But judging by the screenshots it over the target window.
No need to clean the css. You just need to arrange the object correctly.
