I'm after some general advice about the simplest way to display prices throughout a brochure as per the layout below:
What shortcut could I use to get the price label to populate in the correct place throughout the brochure?
Put it on any master page that has been created for the pages in question. You will, of course, have to manually change the price on each. Unless you use the primary text frames for the prices (you can only have one primary text frame per master page or one each if the master page is a spread) the text frames for the prices will be “locked” by default on the document pages but if you Command/Control-Shift click on the frame it will unlock and you can edit the price.
Great, thanks
Happy to help.
