When ‘Accordion Label’ on the mobile menu is linked, the link doesn’t work in chrome on Samsung android devices (possibly other devices on chrome mobile browser too).
Basically, I click on the hamburger menu icon, which releases the drop down menu, I click on the ‘accordion label’ button but nothing happens. It’s as if it isn’t linked to a page, but it definitely is. I triple checked. Here is a link to our website: www.kandtcreative.com maybe you could open it on your mobile and have a look at the menu (you’ll see what I mean). Please help.
Here you find a „quick and dirty“ example file (.muse): https://www.dropbox.com/s/ukqu3ekcb2azk3n/menu-sample.zip?dl=0
By the way: (Using a standard menu, it isn’t necessary any longer to have a „Close“ icon, because this menu closes automatically.
Cant test it on Android devices, but:
• Is this a composition widget containing an accordion? If yes: Why such a construction? Why not using a menu within a composition? Why using a composition at all and not configuring a standard menu this way?
• If no: Please describe how it is done and why it is done this way.
Thank you for your suggestion, however I did not construct the menu, the person who did tried to delete the accordion and replace it with a regular vertical menu inside the mobile menu composition target area but it did not work.
Why putting the menu into an accordion? Is this person in love with this kind of widget? It isn’t necessary, to put the menu into an accordion.
Not sure what you mean?
I can’t understand, why first the menu is placed into an accordion, and now inside a composition.
And „didn’t work“ is a quite insufficient answer to find a fix, don’t you think?
Indeed it doesn't work on Chrome or Android even though the links are in the html file.
If you could share your file with us, we could take a look at it.
Otherwise, I also suggest Günter's method. Why do you want to use an acc if you actually don't need it?
