You can leave it "as is" (they won't print) or update your Paragraph style overrides.
Have a look at your Paragraph Styles to see if you have "Strike Through" applied.
I believe this is more likely to do with your "Track Changes" settings in Preferences. I don't have a lot of experience with this feature but I've come across it before when using one document across a team of people.
Check your settings in "Preferences / Track Changes" and see if disabling this feature removes your problem.
The vertical red bar at the left of each line would suggest this isn't a styles issue.
You forgot to say what version of InDesign you are using.
In CC2017 (and presumably a few versions before that), this is a toggle to show local overrides at the character and paragraph level. The indicators are visible in the normal working mode only, not in Preview or in exported PDFs. I'm not 100% sure this is a CC-or-newer file though, as it looks different in that versions.
In older versions the feature is toggled by a script by Marc Autret. You, or someone else, ran this script, enabled the redlining, and saved the document. Simply run the script again to remove them from view: Indiscripts :: Show Local Formatting in InDesign CS4/CS5
Hi Jongware,
I'm 100% sure that the Style Override Highlighter was enabled with that document the OP is showing.
And the OP perhaps opened an IDML document from a doc where the feature was enabled.
In InDesign versions before CC 2015.3 the highlighting is done in red.
With CC 2015.3 and newer the highlighting is done in blue.
Officially the feature was introduced with CC 2015.3.
In versions before it can be controlled only by using scripts.
Here a comparison.
CS4 to CC 2015.2:
CC 2015.3 and above:
Uwe
Thx, But how can I correct it?
Tnx!!! very helpful!
CS6
