New to After Effectt and enjoying it very much.
My After Effect was first installed in Korean. Then I found out the names of the effects under animation presets are massed up.
(its not translation of those effects because those alphabets are meaningless.)
so I re-installed the After Effect in English through Adobe CC and yet the problem is still there.
here is what it looks like. It seems I am not the only one who is going through this problem. well at least in Korea.
please do help. thanx.
Try resetting your AE preferences. See this: Reset After Effects Preferences
ummm pressing those buttons won't do anything to my AE
I am using windows 10 by the way.
If following those directions doesn't work, you may need to uninstall, remove your preferences, run the Adobe CC Cleaner app, and reinstall.
Hi 정덕,
Are you still having trouble with this issue? Please let us know if you solved it, or if you still need help.
Kevin
