3 Replies Latest reply on Aug 10, 2017 10:25 AM by resdesign
    Recreate this: Randomly floating bubbles created with Flash
    Jonofunker Level 1
      my coding skills are very limited - so I came here to seek help
      Back in the Flash-days I got hold of some ActionScript that gave me the following result:
      Randomly floating bubbles created with Flash - YouTube
      It was a piece of code that I could just apply to an object, and it would have this floating movement.
      It is a nice and subtle effect to spice up an ad
      Anyone who can help me recreate this in Adobe Edge?
      (I found this thread about a similar effect, but it require some adjustments which I dont know how to do: Constant random X & Y movement + constraints?)
      Thank you very much.
        • 1. Re: Recreate this: Randomly floating bubbles created with Flash
          resdesign Adobe Community Professional & MVP
          What version of EA do you have?
          • 2. Re: Recreate this: Randomly floating bubbles created with Flash
            Jonofunker Level 1
            I am using Adobe Edge Animate CC 2015.0
            • 3. Re: Recreate this: Randomly floating bubbles created with Flash
              If you want to use Tim's script change the min and max for be less dramatic. Of course this is only for 1 object. You will need to do this for each bubble. I will try and get a sample later but you might want to try this.
              FYI, change the name of your symbol to your symbol name as well as the stage size.
              var timerTween;
              // used to offset the bounds
              var objWidth = sym.$("bubble").width();
              var objHeight = sym.$("bubble").height();
              // stage width/height
              var windowWidth = 600;
              var windowHeight = 400;
              // min/max vars
              var minXPos = 10;
              var minYPos = 10;
              var maxXPos = 50;
              var maxYPos = 50;
              // timer function
              sym.initTimer = function(){
                        // very short timer, to call "tweenObject" function
                        timerTween = setTimeout(function() {
                             sym.tweenObject();
                                      }, 10);
              // here's where we get random values and actually tween the object, using the jQuery "animate" method
              sym.tweenObject = function(){
                  var tweenTime = sym.getRandomInRange(1000, 3000);
                   var xPos = sym.getRandomInRange(minXPos, maxXPos);
                   var yPos = sym.getRandomInRange(minYPos, maxYPos);
                   sym.$("bubble").animate({left:xPos, top:yPos}, tweenTime, 'swing', sym.initTimer);
              // utility function to give us random values
              sym.getRandomInRange = function(start, end) {
                   return Math.round( start + (Math.random() * (end - start)) );
              // let's start the animation, shall we?
              sym.initTimer();
