Hello,
I am having an issue with Acrobat crashing after attaching an email to Outlook and then closing Acrobat. I open Acrobat, open a PDF, click the email button to attach in Outlook, send the email, then close Acrobat. After closing, Acrobat crashes with the following information:
Problem signature:
Problem Event Name: BEX
Application Name: Acrobat.exe
Application Version: 15.6.30280.16515
Application Timestamp: 587e7b7b
Fault Module Name: StackHash_0a9e
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 32003800
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
I have updated, uninstalled, run the Acrobat cleaner tool, reinstalled, ran sfc /scannow, and checked to make sure protected view is off. Basically I've searched the forums and tried everything people have mentioned while getting random crashes, but nothing will fix this. Acrobat only crashes when these specific steps are followed, but it's something that occurs frequently as this task is performed many times. Any help is greatly appreciated.
Thank you.
Hi Dbillet,
Based on the description mentioned above, Acrobat is crashing when attaching a pdf to email using Outlook and then closing Acrobat, is that correct?
Please try following troubleshooting steps:
1- Install updates- check if any update is pending for Acrobat- click "Check for Updates" under Help menu.
You can also download updates manually using this link: Adobe - Acrobat : For Windows
2- If that doesn't work, try the steps suggested in the following link at post #1 : bex error every time I try to open a pdf file. What should I do?
Could you let us know the operating system installed on the machine?
Does Acrobat also crashes when you close the application after using other options like Export PDF/Create PDF?
Let us know how it goes.
Shivam
I have the same exact issue with similar Event Log information:
Faulting application name: Acrobat.exe, version: 15.6.30354.42847, time stamp: 0x598b6035
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0xa8dc0246
Faulting process id: 0x174c
Faulting application start time: 0x01d31b6b6957ce70
Faulting application path: C:\Program Files (x86)\Adobe\Acrobat 2015\Acrobat\Acrobat.exe
Faulting module path: unknown
Report Id: b397e0f9-875e-11e7-8963-10604b64cb6e
Any update on this issue? I actually opened a ticket with Microsoft and they said you Adobe has it down as a known issue at the moment. Is that correct?
Hi B_cin,
We are aware of this issue and our team is working on it. You may visit this link for more info on: Known issues | Adobe Acrobat DC, Reader DC
-Shivam
Adorobat,
Any update on the issue? I do not see the topic discussed here on the known issues or if it is being addressed?
MS keeps updating their Office, and I would like to update to the latest releases but this issue is not allowing that.
Hi B_cin,
Could you please let us know the version of Acrobat installed on the machine? You may refer to the following link on how to:Identify the product and its version for Acrobat and Reader DC
Also, update Acrobat to the latest version. Click "Check for Updates" under Help. You may also download updates manually from this link:
Reboot the machine once updated and try again.
-Shivam
Adorobat,
Version of Adobe installed on the machine is Adobe Acrobat DC (2015) 15.006.30355 (latest Version Released Aug 29, 2017)
I did have reader installed but i ripped that out to further troubleshoot.
I performed the CLEANER tool on my machine, as well as the re-installed the client again issue still persists.
If you move your Office client back to an OLDER deferred client 16.0.8201.2193 .. issue is resolved .. but there has been a client released on the Deferred channel updated October 2017 that has security releases 16.0.8201.2200 .. which worked for a little while but now is giving us the same issue again.
You use the SendMail feature, it pops open the e-mail, you send it. You then close out of the PDF that was generated in the browser and IE crashes.
Any assistance would be amazing Adorobat
