Why can't we create video slideshow with the lightbox?
As we know, how to do a lightbox with a video gallery, we do not know why you cannot do this.
At what point do you struggle?
You could first start to watch out here in this forum:
Personally, I can not say why you can not do this.
Here is what i have when i copy the embed code 😕
when i copy past the code the video stay outside, its not going into the lightbox
This is because you need to use a composition-lightbox , not a slideshow-lightbox
i choose this one
then it does this when i integrate the code
but i cant put an other video
and if i export a previsualisation the block stay grey
hey Pavel
instead of telling me whats wrong
why wont you show me the right steps to follow
Wonder why a video tutorial is not available on this
Please create a single page with only this element and provide the code you want to have embedded and we have a look.
Be aware that you have to click least twice into the lightbox so you see this in the upper left menu:
There you delete all pictures/triggers except one, choose target or trigger and paste the embed code:
Did you follow these steps from this site: Embed videos and other HTML content in Adobe Muse
It is quite tricky to put the video inside the target. You may try the easy way by simply paste the code inside the target or you have to try the "embed html" for this as mentioned a little further down.
It is important to set up the size of the target so that the video will fit in it.
Hope this helps?
Best Regards,
Uwe
Ok so i made it by video so you could target wich mistakes i made
here
So how could i dont have the video popping out in the screen?
and how to have the video under the thumbnails?
thx
Could you check the video and tell me whats wrong ?
thx
Why don’t you use Muse’s YouTube widget. I used it many, many times and it works nice in composition light boxes.
How do you get the thumbnails with that?
Perhaps this code doesn't work. As you are talking about thumbnails, you want to use not a single video, but a video gallery. Eventually this Galerie uses its own lightbox.
Why don't you simply follow fotoroeder's advice and give us a .muse file with only the composition widget and the YouTube code. Please follow these instructions: https://forums.adobe.com/docs/DOC-8652
You are certainly right,
So how would you do a multiple video lightbox slideshow from your opinion?
Did you watch my post No 8?
There it is quite exact written how to do it.
Of course you could also use the youtube widget, but I did (quick and fast) not find a way to have a proper thumb.
You could grab the screenshot and use this for filling the thumbs and the video widget works really pretty well.
BTW-the video ID that you will need you find here:
For thumbs you might need to sign in at youtube or try : YouTube thumbnail grabber (no sign in necessary)
Or is there a better, yet right way to get thumbs Günter Heißenbüttel
Anyway, to use the widget is by far the fastest way, I guess. You could even change between youtube and vimeo and with anything else
AND Pavel HomerikiPavel Homeriki did tell you what you could do. And finally you tried it. Now you got it, I hope?
Best Regards,
Uwe
