hello,
I am ujil. I need a check point in Photoshop or give a feature to save the history.
As Derek indicated your question seems unclear.
As for
save the history
that is not possible in Photoshop currently and may never be.
Depending on what you actually mean as work-arounds you could
• create a log (Photoshop > Preferences > History Log) to get a text record of what you did or
• use non-destructive practices (Layers, Adjustment Layers, Smart Objects, …) and Layer Comps to »conserve« and manage image editing stages.
Your question is not clear. Please rewrite it with more explanation and give version number of Photoshop and OS details,
As for
save the history
Photoshop's history is session based which means when you close the file the history is gone. (though you can save a history log). You can also create a new document from the current history state in Photoshop. Lightroom keeps the history until you clear it. (if its nondestructive build in Photoshop you need just use adjustment layers & smart objects as mentioned or use Lightroom) What are you trying to accomplish with the history?
Hi Ujil
There are a few things you can do - which may help you.
1. Within the history panel - take snapshots (click on the camera). . You can combine this with number 3 automatically by turning on Automatically create New Snapshot when saving in History options. These snapshots are there even if you go beyond the number of history states but will remain only whilst you have the document open
2. A practice I always recommend - Save the document regularly at key-points using Save As and incremental filenames i.e. filename001, filename002 etc. These incremental versions, as well as giving you history points, can be a lifesaver if you have a crash or realise you need to start again from an earlier point.
3. A variation on the above - Save the document regularly using Ctrl+S to your Creative Cloud Files Folder and ensure that Sync is turned on. When you overwrite it, Cloud storage moves the previously saved version(s) to the archive.
How useful this is to you depends on the number of documents, the size and the Cloud storage in your plan.
4. As others have said, the history log gives you a text list of adjustments
Dave
Love those ideas Dave! And I too keep students creating snapshots only to be used with the history tool for erasing to the past for destructive changes. It seems less useful for a saved History as it is session based. I prefer nondestructive edits most of the time in Photoshop (Smart Objects, Layer Masks, Adjustment Layers, etc). But if you want to save those snapshots, why don't you Stamp Visible. I use this Stamp Visible for the occasional solution when I have to go destructive. This is my favorite Photoshop gem to share.
The keyboard shortcut is Layer>Merge Visible with the Option (Alt) key added in and remember Stamp Visible only creates a new layer from the visible layers! (You can actually hold down the Option (Alt) key while you choose Layer>Merge Visible to Stamp Visible!)
Stamp Visible
Variations
Hope that helps even a little more!
