So I've been using a couple of fonts for a while with the site exporting them as images. I've now made a font webkit using font squirrel and added those files into Muse but when I export the site to GoDaddy it is still exporting the text as images and I can't seem to find a way to change this. Does anyone know what I'm missing here?
I tested your site and your fonts and everything is working as it should! (Be aware, that besides „Blippo“ and „Swis“ you have one more font in your text frame: The [return] in the line between „Test Text Title“ and „Text Test Boxy“ has an invisible paragraph break in „Arial“. This doesn’t matter in the actual issue as „Arial“ is a standard font, but be aware, that a text box has to be converted to an image during output, if it contains system font characters. Why? Just read here (post 4): https://forums.adobe.com/thread/2357163
...Copy link to clipboard
Hello AGAalastair,
Looking at your issue description I assume that even after hosting your fonts they are getting exported by Muse as images.
Can you please try to preview the site locally or upload on Business Catalyst server as a test and let us know it behaving similarly?
Also, share the link to your site hosted on Godaddy so we can examine the codes generated.
Kindly update us accordingly.
Ankush
I have previewed the a few sites I've added the fonts to and all behave the same way, keeps the text as images.
Couple of URLs are:
www.abbeymat.co.uk
www.bishopyoungacademy.co.uk
ankushr40215001​ did yo manage to have a look at the URLs below and spot anything?
Sorry for the delay in response, was on a long leave.
However nothing much I found from your site URLs.
Can you please try uploading the same site to Business Catalyst as a test and share the URL?
Ankush
@ankushr40215001 apologies about the delay in getting back to you! I'd completely forgotten about this but the fact I need to get this sorted has been raised again!
URL: abbeymattest.businesscatalyst.com
Same problem with the fonts despite publishing to business catalyst
Could you please share .muse file with nothing but a small tet container using one of these fonts. And, if the font isn’t free available, could you provide the font files too? You may use Creative Cloud, Dropbox or a similar file sharing service to share these files with us.
Hi, here's the link Dropbox - Test
But now back to your actual issue:
