Help with some questions about tables, colors and fonts
Participant ,
Aug 11, 2017 Aug 11, 2017
Please, to start see the simple code that I'm writing:
var myDoc = app.activeDocument;
var myTable = app.selection[0].convertToTable("\t", "\t", 2);
myTable.cells[0].properties = {
contents: "TITLE",
width: "4 mm",
rotationAngle: 270,
rightInset: 0.5, leftInset: 0.5, topInset: 2, bottomInset: 2,
fillColor: "COLOR 2018",
bottomEdgeStrokeColor: "COLOR 2018",
topEdgeStrokeColor: "COLOR 2018",
leftEdgeStrokeColor: "COLOR 2018",
topEdgeStrokeWeight: 1,
bottomEdgeStrokeWeight: 1,
rightEdgeStrokeWeight: 0,
leftEdgeStrokeWeight: 1,
myTable.cells[0].texts[0].properties = {justification: Justification.RIGHT_ALIGN, appliedFont: "Fira Sans", fillColor: "Paper"};
myTable.cells[1].properties = {
width: "100 mm",
rightInset: 2, leftInset: 2, topInset: 2, bottomInset: 2,
leftEdgeStrokeWeight: 0,
myTable.cells[1].paragraphs[0].remove();
With that I'm change this:
To this:
Easy, ok?
So I get stuck with some things that I call for your help:
  1. I'm applying the Fira Sans font in the word TITLE, but how I can use your style "Bold"? I know that's using the fontStyleName property but where?
  2. The width of my cells[1] is 100 mm, but I want this width the same size of the text frame. See the second image.
  3. I think this is the hard one! I'm using the color with name "COLOR 2018", but I will have different indesign files with different name colors. The only things that remains is the " 2018", like "BIO 2018", "MATH 2018". So is even possible to create a variable that apply the color using something like NAME + " 2018" instead the string itself?
I hope you will understand what I want and I'm grateful for some help!
Scripting
615
Mentor , Aug 14, 2017 Aug 14, 2017
Question 2:
Your table has a frame's (paragraph TTYTT) width while created by default. Store this value before setting custom width and calculate column width using this as a base.
Question 3:
to find current doc color name collect all collor name in an array and use a trick to match.Something like:
var
   mDoc,
   mNames = mDoc.swatches.everyItem().name,
   mString = "@@" + mNames.join("@@") + "@@",    //    so we've got a string "@@name1@@name2@@....@@"
   foundName = mString.match(/[^@]+?2018(?=@@
Participant ,
The question 1 is solved, is fontStyle instead fontStyleName, my mistake..
Mentor ,
Question 2:
Question 3:
var
   mDoc,
   foundName = mString.match(/[^@]+?2018(?=@@)/),
   foundColor = foundName ? mDoc.swatches.item(foundName[0]) : false;
if (!foundColor) alert ("Color '....2018' not found in a doc: " + mDoc.name);
So var foundColor is false or a color object ready to apply
Jarek
Participant ,
Thank you so much Jarek!
Aug 22, 2017 Aug 22, 2017
hi Jarek,
if it is possible to explain to me line 06
appreciating your response
Mentor ,
This is a shorter way to conditional assigning a value.
variable = condition ? valueIfTrue : valueIfFalse;
foundName could be an Array with string matched (true) or null (false).
Jarek
thank very,
it adds valuable knowledge to me.
may you suggested for me further reading about conditional assigning a value.
