I am facing some serious issue with my new machine to play back realtime 4k RED footage. I keep getting frames drop within couple of secs. I reported this to the customer care and they reverted with a stupid reply without even knowing my hardware details. The reply is as follows:
Hi Prashant,
I hope you are doing well,
As far as I can understand the concern you are having regarding the 4k files to have a real time playback in Premiere pro . there is no 100% surety that the Premiere pro can give you a real-time playback.
In your case, you can use the proxy workflow which is design for such conditions
Please check the link below and follow the same
https://helpx.adobe.com/premiere-pro/using/proxy-workflow.html
Regards
Bhaskar Das
DVA Support
The only reason I bought creative package was it was realtime.
I hand picked this config so that it can play realtime 4k. PP 2015.3 was able to play. Why can't the new one?
My hardware:
i7 6900k processor (tried both 3.2 and 4.0 GHz) with water cooler
64 GB Corsair RAM
Quadro p4000
X99 ASUS workstation E motherboard.
850 watt Corsiar RM power supply
1TB samsung 850 pro hard dial
Also 8 TB RAID 0 (zero) hard disk.
It's connected to LG widescreen 34 inch Wide screen monitor and 4k 10 bit monitor
I have been using premiere since Premiere 6 5 (before CS and Pro series). But this time it's turning into a big disappointment.
I have tried every possible thing from reinstalling windows to checking all preferences. Any help will be appreciated
[Moderator note: moved to best forum]
First, "real time playback" is nice when it works, but hardly necessary for most workflows. Second, depending on which format/codec out of that RED, any one computer may do better or worse than you'd "expect". Third, the way you work ... which effects you use, plus any 3rd party plugins & all, WILL affect how the playback works.
This last is where a lot of people hit a wall ... they say plop Warp Stabilizer on multiple long clips off the bat ... then add other things. It can't do real-time, it keeps re-analyzing ... it's terrible! Well, yea, just do a test sequence to make sure that WS will work properly on a clip, maybe with your other expected effects applied also, but don't apply it in your working sequences until near the end of the editing process.
Lumetri, especially in multiple layers, kills playback ... also do it last. As with video denoising.
So work smarter considering PrPro as it exists, not how you think or want it to be.
And also ... download & run Bill Gehrke 's PPBM8 process, to get real good & hard data on how well that entire machine actually works within PrPro.
Neil
I am not using any effect. Just Playback. 😕 Even in source Monitor it drops. Whats the use of spending so much? And why does Adobe claim 4k 60 fps realtime playback?
R Neil Haugen Did the test. Every export of the sequence took less than a min. The vbs file doesn't execute; gives an error in windows 10.
You will need to have all the system monitoring stuff installed & running, and send the output logs to Bill for him to evaluate, that's how that works. Then from the data, you'll be able to see exactly how each subsystem performed.
I've never seen any actually absolute claim of 4k playback in 60fps of any codec on any system ... nothing even close. In fact, the entire reason they came out with their new proxy setup on ingestion was because format/codec changes (larger "K", faster frame-rates, often at higher compression and/or long-GOP) are outpacing hardware upgrades rather substantially.
It's so quick to pop between the proxies & the original media ... single click or keyboard short ... that it's to me a puzzlement why some folks don't use it. Although there are some situations where the new proxy process doesn't work as well, they aren't so common.
Which settings for the format/codec are you using on that RED?
Neil
PrashantMac wrote
https://forums.adobe.com/people/R+Neil+Haugen Did the test. Every export of the sequence took less than a min. The vbs file doesn't execute; gives an error in windows 10.
It most likely gives you an error message because we do not know where your files were exported to. The exports have to be where to script is located . DO NOT copy and move the files CUT and paste them so the timestamps are not changed. IF the MPEG2-DVD export without GPU assistance took less than a minute you are doing something wrong
Did you catch the 3rd test where you turn off Mercury Playback. That test will take more than a minute and if you are missing a test you get that error from the .vbs.
HI All,
Thank You for your support.
I did a screen sharing session with an adobe representative now, He couldnt figure out what was the issue. I played davinci resolve and it played 8k realtime. I showed him that 😕
MyerPj Bill Gehrke I didnt have 3rd test in the project. There is Test 1, 2 and 4. Re-downloading it. When I open the project it asks me to rename the project file because it has got upgraded. Is there a specific file name I need to enter? for the version 2017.1.2? Will it affect the vbs script?
R Neil Haugen I took the footage from: RED | Sample R3D Files | Test drive your RAW workflow I started working on davinci resolve 14 for now because it is playing in full resolution. right from the timeline without frames dropped. I miss premiere now.
I have requested the support to team to send someone who can help in solving it. They tried resetting the preference and the software.
Bill Gehrke I have installed the Speccy software. Here are the details:
0Summary
Operating System
Windows 10 Enterprise 64-bit
CPU
Intel Core i7 6900K @ 3.20GHz 37 °C
Broadwell-E/EP 14nm Technology
RAM
64.0GB Unknown @ 1199MHz (15-17-17-35)
Motherboard
ASUSTeK COMPUTER INC. X99-E WS (SOCKET 2011) 46 °C
Graphics
LG ULTRAWIDE (3440x1440@60Hz)
LG TV (3840x2160@60Hz)
4095MB NVIDIA Quadro P4000 (NVIDIA) 55 °C
Storage
7452GB Intel Raid 0 Volume (RAID)
1863GB Seagate ST2000DX001-1NS164 (SATA) 31 °C
2794GB Seagate FA GoFlex Desk USB Device (USB (SATA))
953GB Samsung SSD 850 PRO 1TB (SSD) 37 °C
3726GB Seagate ST4000DX001-1CE168 (SATA) 31 °C
1863GB Seagate ST2000DX002-2DV164 (SATA) 33 °C
2794GB Seagate ST33000651AS (SATA) 38 °C
2794GB Western Digital WD Elements 107C USB Device (USB (SATA)) 30 °C
2794GB Western Digital WD Elements 107C USB Device (USB (SATA)) 32 °C
1862GB Western Digital WD My Book 111D USB Device (USB (SATA)) 37 °C
Optical Drives
No optical disk drives detected
Audio
Realtek High Definition Audio
Operating System
Computer type: Desktop
Installation Date: 20-05-2017 21:46:16
Serial Number: KT6X7-HKD4G-V98JB-PKMG3-GF4CD
Windows Security Center
User Account Control (UAC) Enabled
Notify level 1 - Rare Notify
Windows Update
AutoUpdate Not configured
Windows Defender
Windows Defender Enabled
Firewall
Firewall Enabled
Display Name ESET Personal firewall
Antivirus
ESET Smart Security
Antivirus Disabled
Company Name ESET
Product Version 10.1.210.0
Virus Signature Database Not updated
Windows Defender
Antivirus Enabled
Virus Signature Database Up to date
.NET Frameworks installed
v4.7 Full
v4.7 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
Version 11.540.15063.0
PowerShell
Version 5.1.15063.0
Environment Variables
USERPROFILE C:\Users\AndMediaTwo
SystemRoot C:\Windows
User Variables
OneDrive C:\Users\AndMediaTwo\OneDrive
Path C:\Users\AndMediaTwo\AppData\Local\Microsoft\WindowsApps
TEMP C:\Users\AndMediaTwo\AppData\Local\Temp
TMP C:\Users\AndMediaTwo\AppData\Local\Temp
Machine Variables
CLASSPATH .;C:\Program Files (x86)\QuickTime\QTSystem\QTJava.zip
ComSpec C:\Windows\system32\cmd.exe
INTEL_DEV_REDIST C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
NUMBER_OF_PROCESSORS 16
OS Windows_NT
Path %INTEL_DEV_REDIST%redist\intel64\compiler
C:\Program Files (x86)\Intel\iCLS Client\
C:\Program Files\Intel\iCLS Client\
C:\Windows\system32
C:\Windows
C:\Windows\System32\Wbem
C:\Windows\System32\WindowsPowerShell\v1.0\
C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL
C:\Program Files\Intel\Intel Management Engine Components\DAL
C:\Program Files (x86)\Intel\Intel Management Engine Components\IPT
C:\Program Files\Intel\Intel Management Engine Components\IPT
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER Intel64 Family 6 Model 79 Stepping 1, GenuineIntel
PROCESSOR_LEVEL 6
PROCESSOR_REVISION 4f01
PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
C:\Windows\system32\WindowsPowerShell\v1.0\Modules
QTJAVA C:\Program Files (x86)\QuickTime\QTSystem\QTJava.zip
RG_GPU_FRAMEWORK_ENGINE_RESOURCEDIR C:\Program Files\Red Giant\RGFX
TEMP C:\Windows\TEMP
TMP C:\Windows\TEMP
USERNAME SYSTEM
windir C:\Windows
Power Profile
Active power scheme High performance
Hibernation Enabled
Turn Off Monitor after: (On AC Power) 35 min
Turn Off Hard Disk after: (On AC Power) 35 min
Suspend after: (On AC Power) Never
Screen saver Disabled
Uptime
Current Session
Current Time 17-08-2017 15:43:29
Current Uptime 10,092 sec (0 d, 02 h, 48 m, 12 s)
Last Boot Time 17-08-2017 12:55:17
Services
Running Adobe Acrobat Update Service
Running Adobe Genuine Software Integrity Service
Running AdobeUpdateService
Running apmwinsrv
Running Application Information
Running Application Management
Running ASUS Com Service
Running ASUS HM Com Service
Running ASUS System Control Service
Running AsusFanControlService
Running Background Intelligent Transfer Service
Running Background Tasks Infrastructure Service
Running Base Filtering Engine
Running Bluetooth Support Service
Running Chrome Remote Desktop Service
Running CNG Key Isolation
Running COM+ Event System
Running Computer Browser
Running Connected Devices Platform Service
Running Connected Devices Platform User Service_5e974
Running Connected User Experiences and Telemetry
Running Contact Data_5e974
Running CoreMessaging
Running Credential Manager
Running Cryptographic Services
Running Data Usage
Running DCOM Server Process Launcher
Running Delivery Optimization
Running Desktop Video Helper Service
Running Device Association Service
Running DevicesFlow_5e974
Running DHCP Client
Running Diagnostic Policy Service
Running Diagnostic Service Host
Running Diagnostic System Host
Running Distributed Link Tracking Client
Running DNS Client
Running DTSAudioSvc
Running ESET Service
Running FABS - Helping agent for MAGIX media database
Running Function Discovery Provider Host
Running Function Discovery Resource Publication
Running Geolocation Service
Running Group Policy Client
Running HomeGroup Provider
Running HP LaserJet Service
Running Human Interface Device Service
Running IKE and AuthIP IPsec Keying Modules
Running Intel Dynamic Application Loader Host Interface Service
Running Intel Integrated Clock Controller Service - Intel ICCS
Running Intel Management and Security Application Local Management Service
Running Intel PROSet Monitoring Service
Running Intel Rapid Storage Technology
Running Intel Security Assist
Running IP Helper
Running IPsec Policy Agent
Running Local Session Manager
Running Network Connected Devices Auto-Setup
Running Network Connection Broker
Running Network List Service
Running Network Location Awareness
Running Network Store Interface Service
Running NVIDIA Display Container LS
Running NVIDIA LocalSystem Container
Running NVIDIA Telemetry Container
Running NVIDIA WMI Provider
Running Peer Name Resolution Protocol
Running Peer Networking Identity Manager
Running Plug and Play
Running postgresql-x64-9.5 - PostgreSQL Server 9.5
Running Power
Running Print Spooler
Running Program Compatibility Assistant Service
Running Radio Management Service
Running Remote Procedure Call (RPC)
Running RPC Endpoint Mapper
Running Secondary Logon
Running Security Accounts Manager
Running Security Center
Running Sentinel LDK License Manager
Running Server
Running Service KMSELDI
Running Shell Hardware Detection
Running SSDP Discovery
Running State Repository Service
Running Storage Service
Running Superfetch
Running Sync Host_5e974
Running System Event Notification Service
Running System Events Broker
Running Task Scheduler
Running TCP/IP NetBIOS Helper
Running TeamViewer 12
Running Themes
Running Tile Data model server
Running Time Broker
Running TokenBroker
Running User Data Access_5e974
Running User Data Storage_5e974
Running User Manager
Running User Profile Service
Running Windows Audio
Running Windows Audio Endpoint Builder
Running Windows Connection Manager
Running Windows Defender Antivirus Network Inspection Service
Running Windows Defender Antivirus Service
Running Windows Defender Security Center Service
Running Windows Driver Foundation - User-mode Driver Framework
Running Windows Event Log
Running Windows Firewall
Running Windows Font Cache Service
Running Windows Image Acquisition (WIA)
Running Windows License Manager Service
Running Windows Management Instrumentation
Running Windows Push Notifications System Service
Running Windows Push Notifications User Service_5e974
Running Windows Search
Running Windows Time
Running Windows Update
Running WinHTTP Web Proxy Auto-Discovery Service
Running WLAN AutoConfig
Running WMI Performance Adapter
Running Workstation
Running X-Rite Device Services Manager
Stopped ActiveX Installer (AxInstSV)
Stopped AllJoyn Router Service
Stopped App Readiness
Stopped Application Identity
Stopped Application Layer Gateway Service
Stopped AppX Deployment Service (AppXSVC)
Stopped Auto Time Zone Updater
Stopped BitLocker Drive Encryption Service
Stopped Block Level Backup Engine Service
Stopped Bluetooth Handsfree Service
Stopped BranchCache
Stopped Certificate Propagation
Stopped Client License Service (ClipSVC)
Stopped COM+ System Application
Stopped Data Sharing Service
Stopped Device Install Service
Stopped Device Management Enrollment Service
Stopped Device Setup Manager
Stopped DevQuery Background Discovery Broker
Stopped Distributed Transaction Coordinator
Stopped dmwappushsvc
Stopped Downloaded Maps Manager
Stopped Embedded Mode
Stopped Encrypting File System (EFS)
Stopped Enterprise App Management Service
Stopped Extensible Authentication Protocol
Stopped Fax
Stopped File History Service
Stopped Firebird Server - MAGIX Instance
Stopped FlexNet Licensing Service
Stopped Google Update Service (gupdate)
Stopped Google Update Service (gupdatem)
Stopped HomeGroup Listener
Stopped HV Host Service
Stopped Hyper-V Data Exchange Service
Stopped Hyper-V Guest Service Interface
Stopped Hyper-V Guest Shutdown Service
Stopped Hyper-V Heartbeat Service
Stopped Hyper-V PowerShell Direct Service
Stopped Hyper-V Remote Desktop Virtualization Service
Stopped Hyper-V Time Synchronization Service
Stopped Hyper-V Volume Shadow Copy Requestor
Stopped Infrared monitor service
Stopped Intel Bluetooth Service
Stopped Intel Capability Licensing Service TCP IP Interface
Stopped Intel Security Assist Helper
Stopped Interactive Services Detection
Stopped Internet Connection Sharing (ICS)
Stopped IP Translation Configuration Service
Stopped KtmRm for Distributed Transaction Coordinator
Stopped Link-Layer Topology Discovery Mapper
Stopped LPA Service
Stopped MessagingService_5e974
Stopped Microsoft Diagnostics Hub Standard Collector Service
Stopped Microsoft Account Sign-in Assistant
Stopped Microsoft App-V Client
Stopped Microsoft iSCSI Initiator Service
Stopped Microsoft Passport
Stopped Microsoft Passport Container
Stopped Microsoft Software Shadow Copy Provider
Stopped Microsoft Storage Spaces SMP
Stopped Microsoft Windows SMS Router Service.
Stopped Natural Authentication
Stopped Net.Tcp Port Sharing Service
Stopped Netlogon
Stopped Network Connections
Stopped Network Connectivity Assistant
Stopped Network Setup Service
Stopped NVIDIA NetworkService Container
Stopped Office 64 Source Engine
Stopped Offline Files
Stopped Optimize drives
Stopped Payments and NFC/SE Manager
Stopped Peer Networking Grouping
Stopped Performance Counter DLL Host
Stopped Performance Logs & Alerts
Stopped Phone Service
Stopped PNRP Machine Name Publication Service
Stopped Portable Device Enumerator Service
Stopped Printer Extensions and Notifications
Stopped Problem Reports and Solutions Control Panel Support
Stopped Quality Windows Audio Video Experience
Stopped Remote Access Auto Connection Manager
Stopped Remote Access Connection Manager
Stopped Remote Desktop Configuration
Stopped Remote Desktop Services
Stopped Remote Desktop Services UserMode Port Redirector
Stopped Remote Procedure Call (RPC) Locator
Stopped Remote Registry
Stopped Retail Demo Service
Stopped Routing and Remote Access
Stopped Secure Socket Tunneling Protocol Service
Stopped Sensor Data Service
Stopped Sensor Monitoring Service
Stopped Sensor Service
Stopped Shared PC Account Manager
Stopped Smart Card
Stopped Smart Card Device Enumeration Service
Stopped Smart Card Removal Policy
Stopped SNMP Trap
Stopped Software Protection
Stopped Spot Verifier
Stopped Still Image Acquisition Events
Stopped Storage Tiers Management
Stopped Telephony
Stopped Touch Keyboard and Handwriting Panel Service
Stopped Update Orchestrator Service
Stopped UPnP Device Host
Stopped User Experience Virtualization Service
Stopped Virtual Disk
Stopped Volume Shadow Copy
Stopped WalletService
Stopped WebClient
Stopped Wi-Fi Direct Services Connection Manager Service
Stopped Windows Backup
Stopped Windows Biometric Service
Stopped Windows Camera Frame Server
Stopped Windows Connect Now - Config Registrar
Stopped Windows Defender Advanced Threat Protection Service
Stopped Windows Encryption Provider Host Service
Stopped Windows Error Reporting Service
Stopped Windows Event Collector
Stopped Windows Insider Service
Stopped Windows Installer
Stopped Windows Media Player Network Sharing Service
Stopped Windows Mobile Hotspot Service
Stopped Windows Modules Installer
Stopped Windows Perception Service
Stopped Windows Presentation Foundation Font Cache 3.0.0.0
Stopped Windows Remote Management (WS-Management)
Stopped Wired AutoConfig
Stopped Work Folders
Stopped WWAN AutoConfig
Stopped Xbox Accessory Management Service
Stopped Xbox Game Monitoring
Stopped Xbox Live Auth Manager
Stopped Xbox Live Game Save
Stopped Xbox Live Networking Service
TimeZone
TimeZone GMT +5:30 Hours
Language English (United States)
Location India
Format English (India)
Currency ?
Date Format dd-MM-yyyy
Time Format HH:mm:ss
Scheduler
17-08-2017 16:31; HPLJCustParticipation
17-08-2017 16:35; GoogleUpdateTaskMachineUA
17-08-2017 23:59; AutoPico Daily Restart
18-08-2017 01:35; GoogleUpdateTaskMachineCore
18-08-2017 02:00; AdobeAAMUpdater-1.0-ANDMEDIATWO-AndMediaTwo
18-08-2017 02:00; AdobeAAMUpdater-1.0-DESKTOP-85H45GO-AndMediaTwo
18-08-2017 08:00; X-Rite Device Services Software Updater
18-08-2017 09:57; OneDrive Standalone Update Task-S-1-5-21-94733980-1370256720-2831819212-1001
18-08-2017 14:00; Adobe Acrobat Update Task
22-08-2017 02:22; Red Giant Link
CCleanerSkipUAC
Connect
HFS+ Activator
HFS+ Updater
Hotfixes
Installed
17-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.1154.0)
Install this update to revise the definition files that are used
to detect viruses, spyware, and other potentially unwanted software.
Once you have installed this item, it cannot be removed.
16-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.1124.0)
16-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.1077.0)
14-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.1026.0)
14-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.1023.0)
14-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.1022.0)
14-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.1005.0)
13-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.999.0)
12-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.984.0)
12-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.979.0)
11-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.955.0)
11-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.944.0)
10-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.902.0)
09-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.872.0)
09-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.871.0)
09-08-2017 2017-08 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4034674)
A security issue has been identified in a Microsoft software
product that could affect your system. You can help protect your
system by installing this update from Microsoft. For a complete
listing of the issues that are included in this update, see the
associated Microsoft Knowledge Base article. After you install
this update, you may have to restart your system.
09-08-2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - August 2017 (KB890830)
After the download, this tool runs one time to check your computer
for infection by specific, prevalent malicious software (including
Blaster, Sasser, and Mydoom) and helps remove any infection that
is found. If an infection is found, the tool will display a status
report the next time that you start your computer. A new version
of the tool will be offered every month. If you want to manually
run the tool on your computer, you can download a copy from the
Microsoft Download Center, or you can run an online version from
microsoft.com. This tool is not a replacement for an antivirus
product. To help protect your computer, you should use an antivirus
product.
09-08-2017 2017-08 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4034662)
09-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.847.0)
09-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.842.0)
08-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.807.0)
08-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.805.0)
08-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.799.0)
08-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.787.0)
07-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.745.0)
06-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.724.0)
06-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.723.0)
05-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.711.0)
05-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.707.0)
04-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.670.0)
04-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.665.0)
03-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.608.0)
03-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.603.0)
03-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.600.0)
02-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.543.0)
31-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.456.0)
31-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.450.0)
30-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.418.0)
29-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.380.0)
28-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.342.0)
26-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.262.0)
25-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.211.0)
24-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.136.0)
22-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.100.0)
22-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.96.0)
22-07-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.95.0)
12-07-2017 2017-07 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4025376)
12-07-2017 2017-07 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4025342)
12-07-2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - July 2017 (KB890830)
product.
30-06-2017 SAMSUNG Electronics Co., Ltd. - Other hardware - SAMSUNG Mobile MTP Device
SAMSUNG Electronics Co., Ltd. Other hardware software update
released in February, 2012
30-06-2017 SAMSUNG Electronics Co., Ltd. - Modem - 5/15/2017 12:00:00 AM - 2.12.5.0
SAMSUNG Electronics Co., Ltd. Modem driver update released in
May 2017
30-06-2017 SAMSUNG Electronics Co., Ltd. - USB - 5/15/2017 12:00:00 AM - 2.12.5.0
SAMSUNG Electronics Co., Ltd. USB driver update released in May
2017
13-06-2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - June 2017 (KB890830)
product.
13-06-2017 2017-06 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4022725)
13-06-2017 2017-06 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4022730)
13-06-2017 2017-06 Update for Windows 10 Version 1703 for x64-based Systems (KB4022405)
Install this update to resolve issues in Windows. For a complete
associated Microsoft Knowledge Base article for more information.
After you install this item, you may have to restart your computer.
23-05-2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - May 2017 (KB890830)
product.
21-05-2017 2017-05 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4020821)
21-05-2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - May 2017 (KB890830)
product.
21-05-2017 2017-05 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4016871)
20-05-2017 Hewlett Packard - Printers - HP LaserJet Pro MFP M125-M126 PCLmS
Hewlett Packard Printers software update released in May, 2013
20-05-2017 PXI - Pointing Drawing - HID-compliand device
PXI Pointing Drawing software update released in December, 2012
20-05-2017 Western Digital Technologies - Other hardware - WD SES Device
Western Digital Technologies Other hardware software update released
in October, 2015
20-05-2017 Intel - Other hardware - Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 3 Thermal Control - 6FB5
Intel Other hardware software update released in January, 2016
Not Installed
04-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.682.0)
Installation Status Failed
01-08-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.249.493.0)
13-06-2017 2017-05 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4020102)
03-06-2017 2017-05 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4020102)
22-05-2017 Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - May 2017 (KB890830)
product.
20-05-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.243.846.0)
20-05-2017 Definition Update for Windows Defender - KB2267602 (Definition 1.243.842.0)
System Folders
Application Data C:\ProgramData
Cookies C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\INetCookies
Desktop C:\Users\AndMediaTwo\Desktop
Documents C:\Users\Public\Documents
Fonts C:\Windows\Fonts
Global Favorites C:\Users\AndMediaTwo\Favorites
Internet History C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\History
Local Application Data C:\Users\AndMediaTwo\AppData\Local
Music C:\Users\Public\Music
Path for burning CD C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\Burn\Burn
Physical Desktop C:\Users\AndMediaTwo\Desktop
Pictures C:\Users\Public\Pictures
Program Files C:\Program Files
Public Desktop C:\Users\Public\Desktop
Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Templates C:\ProgramData\Microsoft\Windows\Templates
Temporary Internet Files C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\INetCache
User Favorites C:\Users\AndMediaTwo\Favorites
Videos C:\Users\Public\Videos
Windows Directory C:\Windows
Windows/System C:\Windows\system32
Process List
aaHMSvc.exe
Process ID 4192
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\ASUS\AAHM\1.00.23\aaHMSvc.exe
Memory Usage 8.91 MB
Peak Memory Usage 9.84 MB
acrotray.exe
Process ID 18884
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\acrotray.exe
Memory Usage 8.11 MB
Peak Memory Usage 8.15 MB
Adobe CEF Helper.exe
Process ID 19576
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\HEX\Adobe CEF Helper.exe
Memory Usage 84 MB
Peak Memory Usage 95 MB
Adobe Desktop Service.exe
Process ID 19536
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe
Memory Usage 113 MB
Peak Memory Usage 146 MB
AdobeIPCBroker.exe
Process ID 19096
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\AdobeIPCBroker.exe
Memory Usage 12 MB
Peak Memory Usage 14 MB
AdobeUpdateService.exe
Process ID 4256
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe
Memory Usage 7.89 MB
Peak Memory Usage 8.38 MB
AGSService.exe
Process ID 4268
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe
Memory Usage 16 MB
Peak Memory Usage 19 MB
AiChargerPlus.exe
Process ID 18488
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\InstallShield Installation Information\{E6931688-DA2B-4E16-8539-3D323D69C677}\AiChargerPlus.exe
Memory Usage 8.49 MB
Peak Memory Usage 8.59 MB
AISuite3.exe
Process ID 7976
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\ASUS\AI Suite III\AISuite3.exe
Memory Usage 3.57 MB
Peak Memory Usage 90 MB
apmwinsrv.exe
Process ID 4176
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Paragon Software\HFS+ for Windows\apmwinsrv.exe
Memory Usage 5.35 MB
Peak Memory Usage 6.93 MB
ApplicationFrameHost.exe
Process ID 21208
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\ApplicationFrameHost.exe
Memory Usage 24 MB
Peak Memory Usage 33 MB
armsvc.exe
Process ID 4184
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
Memory Usage 5.75 MB
Peak Memory Usage 6.59 MB
AsSysCtrlService.exe
Process ID 4208
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.22\AsSysCtrlService.exe
Memory Usage 5.48 MB
Peak Memory Usage 6.32 MB
AsusFanControlService.exe
Process ID 4216
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\ASUS\AsusFanControlService\1.08.14\AsusFanControlService.exe
Memory Usage 9.09 MB
Peak Memory Usage 9.70 MB
atkexComSvc.exe
Process ID 4168
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\ASUS\AXSP\1.02.03\atkexComSvc.exe
Memory Usage 12 MB
Peak Memory Usage 13 MB
backgroundTaskHost.exe
Process ID 13568
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\backgroundTaskHost.exe
Memory Usage 44 MB
Peak Memory Usage 59 MB
BMDStreamingServer.exe
Process ID 17380
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\BMDStreamingServer.exe
Memory Usage 6.86 MB
CCLibrary.exe
Process ID 18308
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\CCLibrary.exe
Memory Usage 2.46 MB
Peak Memory Usage 2.67 MB
CCXProcess.exe
Process ID 20292
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\CCXProcess.exe
Memory Usage 2.09 MB
Peak Memory Usage 2.61 MB
CheckVersionPCI.exe
Process ID 13492
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\CheckVersionPCI.exe
Memory Usage 12 MB
chrome.exe
Process ID 15660
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
Memory Usage 89 MB
Peak Memory Usage 92 MB
chrome.exe
Process ID 9160
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 169 MB
Peak Memory Usage 200 MB
chrome.exe
Process ID 17292
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 215 MB
Peak Memory Usage 311 MB
chrome.exe
Process ID 12708
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 75 MB
Peak Memory Usage 77 MB
chrome.exe
Process ID 5688
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 74 MB
chrome.exe
Process ID 17424
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 151 MB
Peak Memory Usage 305 MB
chrome.exe
Process ID 6980
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 67 MB
Peak Memory Usage 70 MB
chrome.exe
Process ID 9236
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 85 MB
Peak Memory Usage 109 MB
chrome.exe
Process ID 17372
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 68 MB
Peak Memory Usage 72 MB
chrome.exe
Process ID 1172
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 100 MB
Peak Memory Usage 100 MB
chrome.exe
Process ID 10560
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 73 MB
Peak Memory Usage 75 MB
chrome.exe
Process ID 11108
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 91 MB
Peak Memory Usage 91 MB
chrome.exe
Process ID 5864
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 178 MB
Peak Memory Usage 272 MB
chrome.exe
Process ID 12488
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 82 MB
Peak Memory Usage 84 MB
chrome.exe
Process ID 14740
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 308 MB
Peak Memory Usage 317 MB
chrome.exe
Process ID 6752
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 90 MB
Peak Memory Usage 101 MB
chrome.exe
Process ID 19224
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 9.77 MB
Peak Memory Usage 10 MB
chrome.exe
Process ID 13048
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 82 MB
Peak Memory Usage 99 MB
chrome.exe
Process ID 10328
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 9.28 MB
Peak Memory Usage 9.64 MB
chrome.exe
Process ID 11364
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 207 MB
Peak Memory Usage 608 MB
chrome.exe
Process ID 21344
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 70 MB
conhost.exe
Process ID 8364
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\conhost.exe
Memory Usage 9.67 MB
Peak Memory Usage 9.93 MB
conhost.exe
Process ID 4672
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 9.44 MB
Peak Memory Usage 9.74 MB
conhost.exe
Process ID 16976
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 9.25 MB
Peak Memory Usage 9.98 MB
conhost.exe
Process ID 6348
User postgres
Domain ANDMEDIATWO
Memory Usage 10 MB
Peak Memory Usage 11 MB
CoreSync.exe
Process ID 20340
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Adobe\Adobe Sync\CoreSync\CoreSync.exe
Memory Usage 44 MB
Peak Memory Usage 46 MB
Creative Cloud.exe
Process ID 18984
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe
Memory Usage 78 MB
Peak Memory Usage 94 MB
csrss.exe
Process ID 880
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\csrss.exe
Memory Usage 7.67 MB
Peak Memory Usage 26 MB
csrss.exe
Process ID 760
User SYSTEM
Domain NT AUTHORITY
Memory Usage 4.52 MB
Peak Memory Usage 5.21 MB
dasHost.exe
Process ID 2492
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\dasHost.exe
Memory Usage 16 MB
Peak Memory Usage 16 MB
DesktopVideoHelper.exe
Process ID 4504
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\DesktopVideoHelper.exe
Memory Usage 6.37 MB
Peak Memory Usage 7.39 MB
DipAwayMode.exe
Process ID 7880
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\ASUS\AI Suite III\DIP4\DIPAwayMode\DipAwayMode.exe
Memory Usage 240 KB
Peak Memory Usage 17 MB
dllhost.exe
Process ID 4980
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\dllhost.exe
Memory Usage 11 MB
DTSU2PAuSrv64.exe
Process ID 4452
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Realtek\Audio\HDA\DTSU2PAuSrv64.exe
Memory Usage 7.11 MB
Peak Memory Usage 7.74 MB
dwm.exe
Process ID 1216
User DWM-1
Domain Window Manager
Path C:\Windows\System32\dwm.exe
Memory Usage 93 MB
Peak Memory Usage 244 MB
egui.exe
Process ID 9408
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\ESET\ESET Security\egui.exe
Memory Usage 39 MB
Peak Memory Usage 42 MB
ekrn.exe
Process ID 1928
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\ESET\ESET Security\ekrn.exe
Memory Usage 177 MB
Peak Memory Usage 191 MB
explorer.exe
Process ID 6840
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\explorer.exe
Memory Usage 158 MB
Peak Memory Usage 228 MB
EzUpdt.exe
Process ID 7816
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\ASUS\AI Suite III\EZ Update\EzUpdt.exe
Memory Usage KB
FABS.exe
Process ID 2096
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Common Files\MAGIX Services\Database\bin\FABS.exe
Memory Usage 7.60 MB
Peak Memory Usage 8.03 MB
fontdrvhost.exe
Process ID 696
User UMFD-0
Domain Font Driver Host
Path C:\Windows\System32\fontdrvhost.exe
Memory Usage 13 MB
fontdrvhost.exe
Process ID 884
User UMFD-1
Memory Usage 36 MB
Peak Memory Usage 48 MB
GoogleCrashHandler.exe
Process ID 13436
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler.exe
Memory Usage 428 KB
Peak Memory Usage 6.53 MB
GoogleCrashHandler64.exe
Process ID 13500
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler64.exe
Memory Usage 100 KB
Peak Memory Usage 6.16 MB
googledrivesync.exe
Process ID 18200
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Google\Drive\googledrivesync.exe
Memory Usage 110 MB
Peak Memory Usage 111 MB
googledrivesync.exe
Process ID 7240
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 3.69 MB
hasplms.exe
Process ID 5784
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\hasplms.exe
Memory Usage 19 MB
Peak Memory Usage 20 MB
HelpPane.exe
Process ID 10592
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\HelpPane.exe
Memory Usage 23 MB
Peak Memory Usage 24 MB
HPLaserJetService.exe
Process ID 4468
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\HP\HPLaserJetService\HPLaserJetService.exe
Memory Usage 4.01 MB
HPStatusAlerts.exe
Process ID 19292
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\HP\StatusAlerts\bin\HPStatusAlerts.exe
Memory Usage 11 MB
Peak Memory Usage 28 MB
hpwuschd2.exe
Process ID 19192
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\HP\HP Software Update\hpwuschd2.exe
Memory Usage 6.97 MB
Peak Memory Usage 7.02 MB
IAStorDataMgrSvc.exe
Process ID 16352
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorDataMgrSvc.exe
Memory Usage 54 MB
Peak Memory Usage 55 MB
IAStorIcon.exe
Process ID 12764
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorIcon.exe
Memory Usage 40 MB
Peak Memory Usage 44 MB
ICCProxy.exe
Process ID 17300
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel Integrated Clock Controller Service\ICCProxy.exe
Memory Usage 6.46 MB
Peak Memory Usage 7.48 MB
IPROSetMonitor.exe
Process ID 4444
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\IPROSetMonitor.exe
Memory Usage 4.75 MB
Peak Memory Usage 5.61 MB
isa.exe
Process ID 4956
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel Security Assist\isa.exe
Memory Usage 13 MB
jhi_service.exe
Process ID 2276
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL\jhi_service.exe
Memory Usage 5.86 MB
Peak Memory Usage 6.37 MB
LMS.exe
Process ID 1560
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Intel\Intel Management Engine Components\LMS\LMS.exe
Memory Usage 11 MB
lsass.exe
Process ID 960
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\lsass.exe
Memory Usage 16 MB
Memory Compression
Process ID 5220
User SYSTEM
Domain NT AUTHORITY
Memory Usage 4.00 KB
Peak Memory Usage 4.00 KB
MSASCuiL.exe
Process ID 16512
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\Windows Defender\MSASCuiL.exe
Memory Usage 9.37 MB
Peak Memory Usage 9.42 MB
MsMpEng.exe
Process ID 20936
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\Windows Defender\MsMpEng.exe
Memory Usage 143 MB
Peak Memory Usage 588 MB
NisSrv.exe
Process ID 5124
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Program Files\Windows Defender\NisSrv.exe
Memory Usage 18 MB
Peak Memory Usage 38 MB
node.exe
Process ID 4588
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\libs\node.exe
Memory Usage 67 MB
Peak Memory Usage 83 MB
node.exe
Process ID 19092
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\node.exe
Memory Usage 67 MB
Peak Memory Usage 80 MB
nvcontainer.exe
Process ID 4512
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
Memory Usage 25 MB
Peak Memory Usage 25 MB
nvcontainer.exe
Process ID 7208
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
Memory Usage 27 MB
Peak Memory Usage 47 MB
NVDisplay.Container.exe
Process ID 2572
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
Memory Usage 34 MB
Peak Memory Usage 57 MB
Process ID 2072
User SYSTEM
Domain NT AUTHORITY
Memory Usage 13 MB
NVIDIA Share.exe
Process ID 17240
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
Memory Usage 79 MB
Peak Memory Usage 98 MB
NVIDIA Share.exe
Process ID 7660
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 58 MB
Peak Memory Usage 60 MB
NVIDIA Web Helper.exe
Process ID 16836
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
Memory Usage 48 MB
Peak Memory Usage 54 MB
nvspcaps64.exe
Process ID 16912
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\NVIDIA Corporation\ShadowPlay\nvspcaps64.exe
Memory Usage 42 MB
nvsphelper64.exe
Process ID 17200
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\NVIDIA Corporation\ShadowPlay\nvsphelper64.exe
Memory Usage 12 MB
Peak Memory Usage 12 MB
NvTelemetryContainer.exe
Process ID 4708
User NETWORK SERVICE
Domain NT AUTHORITY
Path C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
Memory Usage 16 MB
nvtray.exe
Process ID 13020
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
Memory Usage 12 MB
nvwmi64.exe
Process ID 7180
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\nvwmi64.exe
Memory Usage 15 MB
Peak Memory Usage 40 MB
nvwmi64.exe
Process ID 2064
User SYSTEM
Domain NT AUTHORITY
Memory Usage 6.04 MB
Peak Memory Usage 6.77 MB
OneDrive.exe
Process ID 16812
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Users\AndMediaTwo\AppData\Local\Microsoft\OneDrive\OneDrive.exe
Memory Usage 31 MB
Peak Memory Usage 31 MB
pg_ctl.exe
Process ID 6160
User postgres
Domain ANDMEDIATWO
Path C:\Program Files\PostgreSQL\9.5\bin\pg_ctl.exe
Memory Usage 6.71 MB
Peak Memory Usage 7.79 MB
postgres.exe
Process ID 8308
User postgres
Domain ANDMEDIATWO
Path C:\Program Files\PostgreSQL\9.5\bin\postgres.exe
Memory Usage 4.83 MB
Peak Memory Usage 5.97 MB
postgres.exe
Process ID 6856
User postgres
Domain ANDMEDIATWO
Memory Usage 5.46 MB
Peak Memory Usage 6.54 MB
postgres.exe
Process ID 6340
User postgres
Domain ANDMEDIATWO
Memory Usage 17 MB
Peak Memory Usage 18 MB
postgres.exe
Process ID 8288
User postgres
Domain ANDMEDIATWO
Memory Usage 6.07 MB
Peak Memory Usage 7.23 MB
postgres.exe
Process ID 8240
User postgres
Domain ANDMEDIATWO
Memory Usage 5.38 MB
Peak Memory Usage 6.60 MB
postgres.exe
Process ID 8216
User postgres
Domain ANDMEDIATWO
Memory Usage 6.30 MB
Peak Memory Usage 6.57 MB
postgres.exe
Process ID 6776
User postgres
Domain ANDMEDIATWO
Memory Usage 4.73 MB
ProductUpdater.exe
Process ID 19948
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\Common Files\Freemake Shared\ProductUpdater\ProductUpdater.exe
Memory Usage 40 MB
PushNoticeMonitor.exe
Process ID 7936
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNoticeMonitor.exe
Memory Usage 740 KB
Peak Memory Usage 15 MB
PushNotify_PCCtrl.exe
Process ID 16412
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNotify_PCCtrl.exe
Memory Usage 208 KB
Peak Memory Usage 27 MB
PushNotifyServer.exe
Process ID 7800
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNotifyServer.exe
Memory Usage 456 KB
RAVBg64.exe
Process ID 16660
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe
Memory Usage 14 MB
remoting_host.exe
Process ID 4160
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\Google\Chrome Remote Desktop\60.0.3112.25\remoting_host.exe
Memory Usage 8.88 MB
Peak Memory Usage 9.82 MB
remoting_host.exe
Process ID 5944
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 14 MB
RtkNGUI64.exe
Process ID 16564
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
Memory Usage 15 MB
RuntimeBroker.exe
Process ID 10932
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\RuntimeBroker.exe
Memory Usage 50 MB
Peak Memory Usage 144 MB
SearchFilterHost.exe
Process ID 10728
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\SearchFilterHost.exe
Memory Usage 12 MB
SearchIndexer.exe
Process ID 12044
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\SearchIndexer.exe
Memory Usage 45 MB
SearchProtocolHost.exe
Process ID 12744
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\SearchProtocolHost.exe
Memory Usage 19 MB
SearchUI.exe
Process ID 9372
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
Memory Usage 156 MB
Peak Memory Usage 173 MB
SecurityHealthService.exe
Process ID 4644
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\SecurityHealthService.exe
Memory Usage 14 MB
Service_KMS.exe
Process ID 4572
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files\KMSpico\Service_KMS.exe
Memory Usage 40 MB
Peak Memory Usage 45 MB
services.exe
Process ID 952
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\services.exe
Memory Usage 9.73 MB
ShellExperienceHost.exe
Process ID 9264
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
Memory Usage 111 MB
Peak Memory Usage 121 MB
sihost.exe
Process ID 7296
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\sihost.exe
Memory Usage 27 MB
smss.exe
Process ID 516
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\smss.exe
Memory Usage 488 KB
Peak Memory Usage 1.16 MB
Speccy64.exe
Process ID 12920
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files\Speccy\Speccy64.exe
Memory Usage 39 MB
spoolsv.exe
Process ID 3128
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\spoolsv.exe
Memory Usage 25 MB
svchost.exe
Process ID 1976
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\svchost.exe
Memory Usage 19 MB
svchost.exe
Process ID 17020
User SYSTEM
Domain NT AUTHORITY
Memory Usage 14 MB
svchost.exe
Process ID 2016
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.88 MB
Peak Memory Usage 8.00 MB
svchost.exe
Process ID 2024
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 9.49 MB
Peak Memory Usage 9.60 MB
svchost.exe
Process ID 1148
User LOCAL SERVICE
Domain NT AUTHORITY
Peak Memory Usage 7.89 MB
svchost.exe
Process ID 2132
Domain NT AUTHORITY
Memory Usage 10 MB
svchost.exe
Process ID 2156
Domain NT AUTHORITY
Memory Usage 7.91 MB
svchost.exe
Process ID 2220
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.05 MB
svchost.exe
Process ID 2240
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 6.80 MB
Peak Memory Usage 7.82 MB
svchost.exe
Process ID 2328
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.78 MB
Peak Memory Usage 9.46 MB
svchost.exe
Process ID 2404
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.14 MB
svchost.exe
Process ID 2484
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.57 MB
Peak Memory Usage 8.36 MB
svchost.exe
Process ID 2500
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 6.38 MB
svchost.exe
Process ID 2696
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 2764
User SYSTEM
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 2772
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 5.67 MB
Peak Memory Usage 6.50 MB
svchost.exe
Process ID 2780
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 2916
User SYSTEM
Domain NT AUTHORITY
Memory Usage 12 MB
svchost.exe
Process ID 2984
User LOCAL SERVICE
Domain NT AUTHORITY
Peak Memory Usage 9.40 MB
svchost.exe
Process ID 3032
User SYSTEM
Domain NT AUTHORITY
Memory Usage 13 MB
svchost.exe
Process ID 3056
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 7.26 MB
Peak Memory Usage 8.57 MB
svchost.exe
Process ID 1192
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 12 MB
svchost.exe
Process ID 3196
User SYSTEM
Domain NT AUTHORITY
Memory Usage 19 MB
svchost.exe
Process ID 3220
Domain NT AUTHORITY
Memory Usage 6.99 MB
Peak Memory Usage 7.88 MB
svchost.exe
Process ID 3384
User SYSTEM
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 3960
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 7.09 MB
Peak Memory Usage 8.48 MB
svchost.exe
Process ID 3988
User SYSTEM
Domain NT AUTHORITY
Memory Usage 6.14 MB
svchost.exe
Process ID 4024
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 2480
User SYSTEM
Domain NT AUTHORITY
Peak Memory Usage 7.95 MB
svchost.exe
Process ID 3248
Domain NT AUTHORITY
Memory Usage 6.17 MB
Peak Memory Usage 8.73 MB
svchost.exe
Process ID 4144
User SYSTEM
Domain NT AUTHORITY
Memory Usage 27 MB
Peak Memory Usage 56 MB
svchost.exe
Process ID 21308
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 9.36 MB
svchost.exe
Process ID 21152
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 31 MB
svchost.exe
Process ID 4152
Domain NT AUTHORITY
Memory Usage 12 MB
Peak Memory Usage 22 MB
svchost.exe
Process ID 4436
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 25 MB
svchost.exe
Process ID 15952
User SYSTEM
Domain NT AUTHORITY
Memory Usage 36 MB
Peak Memory Usage 142 MB
svchost.exe
Process ID 5968
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 21272
User SYSTEM
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 15456
User SYSTEM
Domain NT AUTHORITY
Memory Usage 17 MB
svchost.exe
Process ID 4492
User SYSTEM
Domain NT AUTHORITY
Memory Usage 9.15 MB
svchost.exe
Process ID 5060
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.96 MB
Peak Memory Usage 6.26 MB
svchost.exe
Process ID 19928
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 6.87 MB
Peak Memory Usage 7.11 MB
svchost.exe
Process ID 4520
User SYSTEM
Domain NT AUTHORITY
Memory Usage 11 MB
svchost.exe
Process ID 4636
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 13 MB
svchost.exe
Process ID 17568
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.30 MB
Peak Memory Usage 5.57 MB
svchost.exe
Process ID 1068
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.04 MB
Peak Memory Usage 8.56 MB
svchost.exe
Process ID 8684
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 11 MB
svchost.exe
Process ID 1268
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.73 MB
Peak Memory Usage 6.13 MB
svchost.exe
Process ID 4660
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.20 MB
Peak Memory Usage 5.82 MB
svchost.exe
Process ID 4852
User SYSTEM
Domain NT AUTHORITY
Memory Usage 18 MB
svchost.exe
Process ID 4616
User SYSTEM
Domain NT AUTHORITY
Memory Usage 18 MB
Peak Memory Usage 21 MB
svchost.exe
Process ID 5204
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 4.64 MB
svchost.exe
Process ID 4500
User SYSTEM
Domain NT AUTHORITY
Memory Usage 16 MB
svchost.exe
Process ID 7356
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 12 MB
svchost.exe
Process ID 7384
User AndMediaTwo
Domain ANDMEDIATWO
Memory Usage 27 MB
Peak Memory Usage 30 MB
svchost.exe
Process ID 7504
User SYSTEM
Domain NT AUTHORITY
Memory Usage 14 MB
svchost.exe
Process ID 2556
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 8.93 MB
svchost.exe
Process ID 1900
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 14 MB
svchost.exe
Process ID 496
User SYSTEM
Domain NT AUTHORITY
Memory Usage 3.00 MB
Peak Memory Usage 3.88 MB
svchost.exe
Process ID 11068
User SYSTEM
Domain NT AUTHORITY
Memory Usage 5.39 MB
Peak Memory Usage 6.33 MB
svchost.exe
Process ID 2188
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 17 MB
svchost.exe
Process ID 672
User SYSTEM
Domain NT AUTHORITY
Memory Usage 23 MB
svchost.exe
Process ID 1088
Domain NT AUTHORITY
Memory Usage 13 MB
svchost.exe
Process ID 1132
User SYSTEM
Domain NT AUTHORITY
Memory Usage 7.37 MB
svchost.exe
Process ID 1248
User SYSTEM
Domain NT AUTHORITY
Peak Memory Usage 6.24 MB
svchost.exe
Process ID 1348
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 9.91 MB
svchost.exe
Process ID 1356
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 6.31 MB
Peak Memory Usage 6.61 MB
svchost.exe
Process ID 1444
User SYSTEM
Domain NT AUTHORITY
Peak Memory Usage 9.49 MB
svchost.exe
Process ID 12492
User SYSTEM
Domain NT AUTHORITY
Peak Memory Usage 6.79 MB
svchost.exe
Process ID 1460
User SYSTEM
Domain NT AUTHORITY
Memory Usage 9.55 MB
svchost.exe
Process ID 1468
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 9.96 MB
svchost.exe
Process ID 1500
User SYSTEM
Domain NT AUTHORITY
Memory Usage 15 MB
svchost.exe
Process ID 4536
User SYSTEM
Domain NT AUTHORITY
Memory Usage 15 MB
svchost.exe
Process ID 1620
User SYSTEM
Domain NT AUTHORITY
svchost.exe
Process ID 10600
User LOCAL SERVICE
Domain NT AUTHORITY
Peak Memory Usage 6.31 MB
svchost.exe
Process ID 1288
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 5.34 MB
Peak Memory Usage 5.44 MB
svchost.exe
Process ID 1708
User SYSTEM
Domain NT AUTHORITY
Peak Memory Usage 7.98 MB
System
Process ID 4
Memory Usage 1.18 MB
Peak Memory Usage 6.36 MB
System Idle Process
Process ID 0
SystemSettingsBroker.exe
Process ID 16544
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\SystemSettingsBroker.exe
Memory Usage 18 MB
taskhostw.exe
Process ID 7892
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\taskhostw.exe
Memory Usage 22 MB
Peak Memory Usage 37 MB
TeamViewer_Service.exe
Process ID 4840
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
Memory Usage 17 MB
TiltWheelMouse.exe
Process ID 16740
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Windows\System32\TiltWheelMouse.exe
Memory Usage 8.68 MB
Peak Memory Usage 8.91 MB
U3BoostSvr64.exe
Process ID 13464
User AndMediaTwo
Domain ANDMEDIATWO
Path C:\Program Files (x86)\ASUS\AI Suite III\USB 3.0 Boost\U3BoostSvr64.exe
Memory Usage 76 KB
Peak Memory Usage 8.50 MB
wininit.exe
Process ID 872
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\wininit.exe
Memory Usage 5.62 MB
Peak Memory Usage 6.68 MB
winlogon.exe
Process ID 796
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\winlogon.exe
Memory Usage 11 MB
Peak Memory Usage 29 MB
WmiApSrv.exe
Process ID 11032
User SYSTEM
Domain NT AUTHORITY
Path C:\Windows\System32\wbem\WmiApSrv.exe
Memory Usage 7.73 MB
Peak Memory Usage 7.73 MB
WmiPrvSE.exe
Process ID 7304
Domain NT AUTHORITY
Path C:\Windows\System32\wbem\WmiPrvSE.exe
Memory Usage 30 MB
WmiPrvSE.exe
Process ID 19004
User SYSTEM
Domain NT AUTHORITY
Memory Usage 38 MB
Peak Memory Usage 39 MB
WmiPrvSE.exe
Process ID 20044
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 14 MB
WUDFHost.exe
Process ID 1888
User LOCAL SERVICE
Domain NT AUTHORITY
Path C:\Windows\System32\WUDFHost.exe
Memory Usage 7.66 MB
Peak Memory Usage 8.16 MB
WUDFHost.exe
Process ID 1540
User LOCAL SERVICE
Domain NT AUTHORITY
Memory Usage 5.01 MB
Peak Memory Usage 6.15 MB
xrdd.exe
Process ID 4928
User SYSTEM
Domain NT AUTHORITY
Path C:\Program Files (x86)\X-Rite\Devices\Services\xrdd.exe
Memory Usage 16 MB
Security Options
Accounts: Administrator account status Disabled
Accounts: Block Microsoft accounts Not Defined
Accounts: Guest account status Enabled
Accounts: Limit local account use of blank passwords to console logon only Enabled
Accounts: Rename administrator account Administrator
Accounts: Rename guest account Guest
Audit: Audit the access of global system objects Disabled
Audit: Audit the use of Backup and Restore privilege Disabled
Audit: Force audit policy subcategory settings (Windows Vista or later) to override audit policy category settings Not Defined
Audit: Shut down system immediately if unable to log security audits Disabled
DCOM: Machine Access Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
DCOM: Machine Launch Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
Devices: Allow undock without having to log on Enabled
Devices: Allowed to format and eject removable media Not Defined
Devices: Prevent users from installing printer drivers Disabled
Devices: Restrict CD-ROM access to locally logged-on user only Not Defined
Devices: Restrict floppy access to locally logged-on user only Not Defined
Domain controller: Allow server operators to schedule tasks Not Defined
Domain controller: LDAP server signing requirements Not Defined
Domain controller: Refuse machine account password changes Not Defined
Domain member: Digitally encrypt or sign secure channel data (always) Enabled
Domain member: Digitally encrypt secure channel data (when possible) Enabled
Domain member: Digitally sign secure channel data (when possible) Enabled
Domain member: Disable machine account password changes Disabled
Domain member: Maximum machine account password age 30 days
Domain member: Require strong (Windows 2000 or later) session key Enabled
Interactive logon: Display user information when the session is locked Not Defined
Interactive logon: Do not require CTRL+ALT+DEL Not Defined
Interactive logon: Don't display last signed-in Disabled
Interactive logon: Don't display username at sign-in Not Defined
Interactive logon: Machine account lockout threshold Not Defined
Interactive logon: Machine inactivity limit Not Defined
Interactive logon: Message text for users attempting to log on
Interactive logon: Message title for users attempting to log on
Interactive logon: Number of previous logons to cache (in case domain controller is not available) 10 logons
Interactive logon: Prompt user to change password before expiration 5 days
Interactive logon: Require Domain Controller authentication to unlock workstation Disabled
Interactive logon: Require Windows Hello for Business or smart card Disabled
Interactive logon: Smart card removal behavior No Action
Microsoft network client: Digitally sign communications (always) Disabled
Microsoft network client: Digitally sign communications (if server agrees) Enabled
Microsoft network client: Send unencrypted password to third-party SMB servers Disabled
Microsoft network server: Amount of idle time required before suspending session 15 minutes
Microsoft network server: Attempt S4U2Self to obtain claim information Not Defined
Microsoft network server: Digitally sign communications (always) Disabled
Microsoft network server: Digitally sign communications (if client agrees) Disabled
Microsoft network server: Disconnect clients when logon hours expire Enabled
Microsoft network server: Server SPN target name validation level Not Defined
Network access: Allow anonymous SID/Name translation Disabled
Network access: Do not allow anonymous enumeration of SAM accounts Enabled
Network access: Do not allow anonymous enumeration of SAM accounts and shares Disabled
Network access: Do not allow storage of passwords and credentials for network authentication Disabled
Network access: Let Everyone permissions apply to anonymous users Disabled
Network access: Named Pipes that can be accessed anonymously
Network access: Remotely accessible registry paths System\CurrentControlSet\Control\ProductOptions,System\CurrentControlSet\Control\Server Applications,Software\Microsoft\Windows NT\CurrentVersion
Network access: Remotely accessible registry paths and sub-paths System\CurrentControlSet\Control\Print\Printers,System\CurrentControlSet\Services\Eventlog,Software\Microsoft\OLAP Server,Software\Microsoft\Windows NT\CurrentVersion\Print,Software\Microsoft\Windows NT\CurrentVersion\Windows,System\CurrentControlSet\Control\ContentIndex,System\CurrentControlSet\Control\Terminal Server,System\CurrentControlSet\Control\Terminal Server\UserConfig,System\CurrentControlSet\Control\Terminal Server\DefaultUserConfiguration,Software\Microsoft\Windows NT\CurrentVersion\Perflib,System\CurrentControlSet\Services\SysmonLog
Network access: Restrict anonymous access to Named Pipes and Shares Enabled
Network access: Restrict clients allowed to make remote calls to SAM
Network access: Shares that can be accessed anonymously Not Defined
Network access: Sharing and security model for local accounts Classic - local users authenticate as themselves
Network security: Allow Local System to use computer identity for NTLM Not Defined
Network security: Allow LocalSystem NULL session fallback Not Defined
Network security: Allow PKU2U authentication requests to this computer to use online identities.
Not Defined
Network security: Configure encryption types allowed for Kerberos Not Defined
Network security: Do not store LAN Manager hash value on next password change Enabled
Network security: Force logoff when logon hours expire Disabled
Network security: LAN Manager authentication level Not Defined
Network security: LDAP client signing requirements Negotiate signing
Network security: Minimum session security for NTLM SSP based (including secure RPC) clients Require 128-bit encryption
Network security: Minimum session security for NTLM SSP based (including secure RPC) servers Require 128-bit encryption
Network security: Restrict NTLM: Add remote server exceptions for NTLM authentication Not Defined
Network security: Restrict NTLM: Add server exceptions in this domain Not Defined
Network security: Restrict NTLM: Audit Incoming NTLM Traffic Not Defined
Network security: Restrict NTLM: Audit NTLM authentication in this domain Not Defined
Network security: Restrict NTLM: Incoming NTLM traffic Not Defined
Network security: Restrict NTLM: NTLM authentication in this domain Not Defined
Network security: Restrict NTLM: Outgoing NTLM traffic to remote servers Not Defined
Recovery console: Allow automatic administrative logon Disabled
Recovery console: Allow floppy copy and access to all drives and all folders Disabled
Shutdown: Allow system to be shut down without having to log on Enabled
Shutdown: Clear virtual memory pagefile Disabled
System cryptography: Force strong key protection for user keys stored on the computer Not Defined
System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing Disabled
System objects: Require case insensitivity for non-Windows subsystems Enabled
System objects: Strengthen default permissions of internal system objects (e.g. Symbolic Links) Enabled
System settings: Optional subsystems
System settings: Use Certificate Rules on Windows Executables for Software Restriction Policies Disabled
User Account Control: Admin Approval Mode for the Built-in Administrator account Not Defined
User Account Control: Allow UIAccess applications to prompt for elevation without using the secure desktop Disabled
User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode Prompt for consent for non-Windows binaries
User Account Control: Behavior of the elevation prompt for standard users Prompt for credentials
User Account Control: Detect application installations and prompt for elevation Enabled
User Account Control: Only elevate executables that are signed and validated Disabled
User Account Control: Only elevate UIAccess applications that are installed in secure locations Enabled
User Account Control: Run all administrators in Admin Approval Mode Enabled
User Account Control: Switch to the secure desktop when prompting for elevation Disabled
User Account Control: Virtualize file and registry write failures to per-user locations Enabled
Device Tree
ACPI x64-based PC
Microsoft ACPI-Compliant System
ACPI Fixed Feature Button
ACPI Power Button
AMDA00 Interface
Generic Bus
Intel Turbo Boost Max Technology 3.0 Driver
Microsoft Windows Management Interface for ACPI
PCI Bus
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE0
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE1
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE2
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE3
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE4
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE5
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE6
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE7
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FF8
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FF9
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FFC
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FFD
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FFE
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Broadcast - 6FAE
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBC
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBD
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBE
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBF
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Broadcast - 6F6E
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FB8
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FB9
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FBA
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FBB
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Global Broadcast - 6F6F
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Global Broadcast - 6FAF
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 - 6F30
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 - 6FA0
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 0 Error - 6FB2
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 0 Thermal Control - 6FB0
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 1 Error - 6FB3
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 1 Thermal Control - 6FB1
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 2 Error - 6FB6
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 2 Thermal Control - 6FB4
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 3 Error - 6FB7
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 3 Thermal Control - 6FB5
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAA
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAB
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAC
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAD
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS - 6F71
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS - 6FA8
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 1 - Channel 0 Thermal Control - 6FD0
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F88
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F8A
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F98
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F99
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F9A
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F9C
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6FC0
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent - 6F1D
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent - 6F34
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 - 6F36
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 - 6F37
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 - 6F81
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link Debug - 6F76
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Target Address/Thermal/RAS - 6F68
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox - 6F1E
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox - 6F1F
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox - 6F7D
ACPI Module Device
Intel Core i7-6900K CPU @ 3.20GHz
PCI Express Root Complex
Advanced programmable interrupt controller
Intel C610 series/X99 chipset PCI Express Root Port #1 - 8D10
Intel C610 series/X99 chipset SMBus Controller - 8D22
Intel C610 series/X99 chipset SPSR - 8D7C
Intel Ethernet Connection (2) I218-LM
Intel Management Engine Interface
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Address Map/VTd_Misc/System Management - 6F28
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D I/O APIC - 6F2C
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO Hot Plug - 6F29
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO RAS/Control Status/Global Errors - 6F2A
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 - 6F02
Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 - 6F03
PCI standard host CPU bridge
Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 2 - 6F04
PCI-to-PCI Bridge
PCI-to-PCI Bridge
PCI-to-PCI Bridge
PCI-to-PCI Bridge
Blackmagic DeckLink Mini Monitor 4K
Blackmagic DeckLink Mini Monitor 4K AVStream
Blackmagic DeckLink Mini Monitor 4K Audio
Speakers (Blackmagic DeckLink Mini Monitor 4K Audio)
Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 3 - 6F08
PCI-to-PCI Bridge
PCI-to-PCI Bridge
PCI-to-PCI Bridge
NVIDIA Quadro P4000
Generic PnP Monitor
Generic PnP Monitor
High Definition Audio Controller
NVIDIA High Definition Audio
LG TV-C (NVIDIA High Definition Audio)
LG ULTRAWIDE-8 (NVIDIA High Definition Audio)
Standard SATA AHCI Controller
Samsung SSD 850 PRO 1TB
ST2000DX002-2DV164
ST2000DX002-2DV164
ST4000DX001-1CE168
Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
USB Root Hub (USB 3.0)
Generic SuperSpeed USB Hub
Generic USB Hub
USB Input Device
HID-compliant vendor-defined device
Generic Bluetooth Radio
Bluetooth Device (Personal Area Network) #5
Bluetooth Device (RFCOMM Protocol TDI) #5
Microsoft Bluetooth LE Enumerator
Microsoft Bluetooth Enumerator
Apple Wireless Mouse
Device Identification Service
usi’s Mouse
Generic USB Hub
HID-compliant mouse
USB Composite Device
USB Input Device
HID Keyboard Device
USB Input Device
HID-compliant consumer control device
HID-compliant system controller
USB Mass Storage Device
WD Elements 107C USB Device
WD My Book 111D USB Device
WD SES Device
Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #2 - 8D2D
USB Root Hub
Generic USB Hub
Realtek High Definition Audio
Realtek Digital Output (Realtek High Definition Audio)
Realtek Digital Output(Optical) (Realtek High Definition Audio)
Speakers (Realtek High Definition Audio)
Intel(R) C610 series/X99 chipset PCI Express Root Port #4 - 8D16
PCI-to-PCI Bridge
PCI-to-PCI Bridge
Intel I210 Gigabit Network Connection
PCI-to-PCI Bridge
Asmedia 106x SATA Controller
Intel(R) C610 series/X99 chipset PCI Express Root Port #5 - 8D18
ST33000651AS
Intel(R) C610 series/X99 chipset PCI Express Root Port #7 - 8D1C
ASMedia USB3.0 eXtensible Host Controller
ASMedia USB Root Hub
Seagate FA GoFlex Desk USB Device
Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #1 - 8D26
USB Root Hub
Generic USB Hub
Intel(R) C610 series/X99 chipset LPC Controller - 8D47
Communications Port (COM1)
Direct memory access controller
High precision event timer
Microsoft ACPI-Compliant Embedded Controller
Motherboard resources
Numeric data processor
Programmable interrupt controller
System CMOS/real time clock
System speaker
System timer
Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Intel Raid 0 Volume
ST2000DX001-1NS164
CPU
Intel Core i7 6900K
Cores 8
Threads 16
Name Intel Core i7 6900K
Code Name Broadwell-E/EP
Package Socket 2011 LGA
Technology 14nm
Specification Intel Core i7-6900K CPU @ 3.20GHz
Family 6
Extended Family 6
Model F
Extended Model 4F
Stepping 1
Revision M0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64, NX, VMX, AES, AVX, AVX2, FMA3
Virtualization Supported, Disabled
Hyperthreading Supported, Enabled
Fan Speed 815 RPM
Bus Speed 100.0 MHz
Stock Core Speed 3200 MHz
Stock Bus Speed 100 MHz
Average Temperature 37 °C
Caches
L1 Data Cache Size 8 x 32 KBytes
L1 Instructions Cache Size 8 x 32 KBytes
L2 Unified Cache Size 8 x 256 KBytes
L3 Unified Cache Size 20480 KBytes
Cores
Core 0
Core Speed 3199.3 MHz
Multiplier x 32.0
Bus Speed 100.0 MHz
Temperature 37 °C
Threads APIC ID: 0, 1
Core 1
Core Speed 1899.6 MHz
Multiplier x 19.0
Bus Speed 100.0 MHz
Temperature 38 °C
Threads APIC ID: 2, 3
Core 2
Core Speed 1799.6 MHz
Multiplier x 18.0
Bus Speed 100.0 MHz
Temperature 37 °C
Threads APIC ID: 4, 5
Core 3
Core Speed 2899.3 MHz
Multiplier x 29.0
Bus Speed 100.0 MHz
Temperature 37 °C
Threads APIC ID: 6, 7
Core 4
Multiplier x 18.0
Bus Speed 100.0 MHz
Temperature 36 °C
Threads APIC ID: 8, 9
Core 5
Multiplier x 29.0
Bus Speed 100.0 MHz
Temperature 36 °C
Threads APIC ID: 10, 11
Core 6
Multiplier x 18.0
Bus Speed 100.0 MHz
Temperature 36 °C
Threads APIC ID: 12, 13
Core 7
Multiplier x 29.0
Bus Speed 100.0 MHz
Temperature 37 °C
Threads APIC ID: 14, 15
RAM
Memory slots
Total memory slots 8
Used memory slots 4
Free memory slots 4
Memory
Type Unknown
Size 65536 MBytes
DRAM Frequency 1199.8 MHz
CAS# Latency (CL) 15 clocks
RAS# to CAS# Delay (tRCD) 17 clocks
RAS# Precharge (tRP) 17 clocks
Cycle Time (tRAS) 35 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 9 %
Total Physical 64 GB
Available Physical 58 GB
Total Virtual 73 GB
Available Virtual 66 GB
SPD
Number Of SPD Modules 4
Slot #1
Type Unknown
Size 16384 MBytes
Manufacturer Corsair
Max Bandwidth DDR4-2132 (1066 MHz)
Part Number CMK16GX4M1B3000C15
SPD Ext. XMP
Timing table
JEDEC #1
Frequency 666.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 22
tRC 31
Voltage 1.200 V
JEDEC #2
Frequency 740.7 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 25
tRC 35
Voltage 1.200 V
JEDEC #3
Frequency 814.8 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 27
tRC 38
Voltage 1.200 V
JEDEC #4
Frequency 888.9 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 30
tRC 42
Voltage 1.200 V
JEDEC #5
Frequency 963.0 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 32
tRC 45
Voltage 1.200 V
JEDEC #6
Frequency 1037.0 MHz
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 35
tRC 49
Voltage 1.200 V
JEDEC #7
Frequency 1066.1 MHz
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
JEDEC #8
CAS# Latency 16.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
XMP-2998
Frequency 1499 MHz
CAS# Latency 15.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 35
Voltage 1.350 V
Slot #2
Type Unknown
Size 16384 MBytes
SPD Ext. XMP
Timing table
JEDEC #1
Frequency 666.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 22
tRC 31
Voltage 1.200 V
JEDEC #2
Frequency 740.7 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 25
tRC 35
Voltage 1.200 V
JEDEC #3
Frequency 814.8 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 27
tRC 38
Voltage 1.200 V
JEDEC #4
Frequency 888.9 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 30
tRC 42
Voltage 1.200 V
JEDEC #5
Frequency 963.0 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 32
tRC 45
Voltage 1.200 V
JEDEC #6
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 35
tRC 49
Voltage 1.200 V
JEDEC #7
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
JEDEC #8
CAS# Latency 16.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
XMP-2998
Frequency 1499 MHz
CAS# Latency 15.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 35
Voltage 1.350 V
Slot #3
Type Unknown
Size 16384 MBytes
SPD Ext. XMP
Timing table
JEDEC #1
Frequency 666.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 22
tRC 31
Voltage 1.200 V
JEDEC #2
Frequency 740.7 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 25
tRC 35
Voltage 1.200 V
JEDEC #3
Frequency 814.8 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 27
tRC 38
Voltage 1.200 V
JEDEC #4
Frequency 888.9 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 30
tRC 42
Voltage 1.200 V
JEDEC #5
Frequency 963.0 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 32
tRC 45
Voltage 1.200 V
JEDEC #6
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 35
tRC 49
Voltage 1.200 V
JEDEC #7
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
JEDEC #8
CAS# Latency 16.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
XMP-2998
Frequency 1499 MHz
CAS# Latency 15.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 35
Voltage 1.350 V
Slot #4
Type Unknown
Size 16384 MBytes
SPD Ext. XMP
Timing table
JEDEC #1
Frequency 666.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 22
tRC 31
Voltage 1.200 V
JEDEC #2
Frequency 740.7 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 25
tRC 35
Voltage 1.200 V
JEDEC #3
Frequency 814.8 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 27
tRC 38
Voltage 1.200 V
JEDEC #4
Frequency 888.9 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 30
tRC 42
Voltage 1.200 V
JEDEC #5
Frequency 963.0 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 32
tRC 45
Voltage 1.200 V
JEDEC #6
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 35
tRC 49
Voltage 1.200 V
JEDEC #7
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
JEDEC #8
CAS# Latency 16.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
XMP-2998
Frequency 1499 MHz
CAS# Latency 15.0
RAS# To CAS# 17
RAS# Precharge 17
tRAS 35
Voltage 1.350 V
Motherboard
Manufacturer ASUSTeK COMPUTER INC.
Model X99-E WS (SOCKET 2011)
Version Rev 1.xx
Chipset Vendor Intel
Chipset Model Broadwell-E
Chipset Revision 01
Southbridge Vendor Intel
Southbridge Model X99
Southbridge Revision 05
System Temperature 46 °C
BIOS
Brand American Megatrends Inc.
Version 3402
Date 14-11-2016
Voltage
+5V 5.000 V
+3.3V 3.264 V
+12V 12.000 V
VIN3 1.024 V
VIN4 0.864 V
VCORE 0.944 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation PCIEX16_1
Characteristics 3.3V, Shared, PME
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Data lanes x16
Slot Designation PCIEX16_2
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Data lanes x16
Slot Designation PCIEX16_3
Slot Number 2
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation PCIEX16_4
Slot Number 3
Slot PCI-E
Slot Type PCI-E
Data lanes x16
Slot Designation PCIEX16_5
Slot Number 4
Slot PCI-E
Slot Type PCI-E
Data lanes x16
Slot Designation PCIEX16_6
Slot Number 5
Slot PCI-E
Slot Type PCI-E
Data lanes x16
Slot Designation PCIEX16_7
Slot Number 6
Graphics
Monitor 1
Name LG ULTRAWIDE on NVIDIA Quadro P4000
Current Resolution 3440x1440 pixels
Work Resolution 3440x1410 pixels
State Enabled
Multiple displays Extended, Primary, Enabled
Monitor Width 3440
Monitor Height 1440
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Monitor 2
Name LG TV on NVIDIA Quadro P4000
Current Resolution 3072x1728 pixels
Work Resolution 3072x1698 pixels
State Enabled
Multiple displays Extended, Secondary, Enabled
Monitor Width 3840
Monitor Height 2160
Device \\.\DISPLAY2\Monitor0
NVIDIA Quadro P4000
Manufacturer NVIDIA
Model Quadro P4000
Device ID 10DE-1BB1
Revision A2
Subvendor NVIDIA (10DE)
Current Performance Level Level 0
Bus Interface PCI Express x16
Temperature 55 °C
Driver version 22.21.13.8205
BIOS Version 86.04.56.00.0b
Memory 4095 MB
Count of performance levels : 1
Level 1 - "Perf Level 0"
Storage
Hard drives
Intel Raid 0 Volume
Manufacturer Intel
Interface RAID
Capacity 7452 GB
Real size 8,001,569,161,216 bytes
RAID Type Software RAID
S.M.A.R.T
S.M.A.R.T not supported
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter X:
File System NTFS
Volume Serial Number D8EDA6C1
Size 7451 GB
Used Space 4416 GB (59%)
Free Space 3035 GB (41%)
ST2000DX001-1NS164
Manufacturer Seagate
Heads 16
Cylinders 243,201
Tracks 62,016,255
Sectors 3,907,024,065
SATA type SATA-III 6.0Gb/s
Device type Fixed
ATA Standard ACS2
Serial Number Z4Z39F1G
Firmware Version Number CC41
LBA Size 48-bit LBA
Power On Count 1334 times
Power On Time 270.1 days
Speed 7200 RPM
Features S.M.A.R.T., APM, NCQ
Max. Transfer Mode SATA III 6.0Gb/s
Used Transfer Mode SATA III 6.0Gb/s
Interface SATA
Capacity 1863 GB
Real size 2,000,398,934,016 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 31 °C
Temperature Range OK (less than 50 °C)
S.M.A.R.T attributes
01
Attribute name Read Error Rate
Real value 0
Current 114
Worst 99
Threshold 6
Raw Value 0004CBFB40
Status Good
03
Attribute name Spin-Up Time
Real value 0 ms
Current 96
Worst 94
Threshold 0
Raw Value 0000000000
Status Good
04
Attribute name Start/Stop Count
Real value 1,409
Current 99
Worst 99
Threshold 20
Raw Value 0000000581
Status Good
05
Attribute name Reallocated Sectors Count
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
07
Attribute name Seek Error Rate
Real value 0
Current 77
Worst 60
Threshold 30
Raw Value 0003089347
Status Good
09
Attribute name Power-On Hours (POH)
Real value 270d 2h
Current 93
Worst 93
Threshold 0
Raw Value 0000001952
Status Good
0A
Attribute name Spin Retry Count
Real value 0
Current 100
Worst 100
Threshold 97
Status Good
0C
Attribute name Device Power Cycle Count
Real value 1,334
Current 99
Worst 99
Threshold 20
Raw Value 0000000536
Status Good
B7
Attribute name SATA Downshift Error Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
B8
Attribute name End-to-End error / IOEDC
Real value 0
Current 100
Worst 100
Threshold 99
Status Good
BB
Attribute name Reported Uncorrectable Errors
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BC
Attribute name Command Timeout
Real value 4,295,098,371
Current 100
Worst 99
Threshold 0
Raw Value 0000020003
Status Good
BD
Attribute name High Fly Writes (WDC)
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BE
Attribute name Airflow Temperature
Real value 31 °C
Current 69
Worst 56
Threshold 45
Raw Value 00221A001F
Status Good
BF
Attribute name G-sense error rate
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C0
Attribute name Power-off Retract Count
Real value 114
Current 100
Worst 100
Threshold 0
Raw Value 0000000072
Status Good
C1
Attribute name Load/Unload Cycle Count
Real value 20,671
Current 90
Worst 90
Threshold 0
Raw Value 00000050BF
Status Good
C2
Attribute name Temperature
Real value 31 °C
Current 31
Worst 44
Threshold 0
Raw Value 000000001F
Status Good
C5
Attribute name Current Pending Sector Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Attribute name Uncorrectable Sector Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Attribute name UltraDMA CRC Error Count
Real value 1
Current 200
Worst 200
Threshold 0
Raw Value 0000000001
Status Good
F0
Attribute name Head Flying Hours
Real value 241d 16h
Current 100
Worst 253
Threshold 0
Raw Value 00000016A8
Status Good
F1
Attribute name Total LBAs Written
Real value 21,133,677,431
Current 100
Worst 253
Threshold 0
Raw Value 00EBAA5377
Status Good
F2
Attribute name Total LBAs Read
Real value 75,601,275,345
Current 100
Worst 253
Threshold 0
Raw Value 009A2FE9D1
Status Good
Partition 0
Partition ID Disk #1, Partition #0
Disk Letter D:
File System NTFS
Volume Serial Number 20B88602
Size 1862 GB
Used Space 1848 GB (99%)
Free Space 13.9 GB (1%)
Heads 16
Cylinders 45,600
Tracks 11,628,000
Sectors 732,564,000
Device type Fixed
ATA Standard ATA8-ACS
Serial Number Z1F02FE0
Firmware Version Number CC94
LBA Size 48-bit LBA
Power On Count Unknown
Power On Time Unknown
Speed 7200 RPM
Used Transfer Mode SATA II 3.0Gb/s
Interface USB (SATA)
Capacity 2794 GB
Real size 3,000,592,965,632 bytes
RAID Type None
S.M.A.R.T
Status Unknown
Partition 0
Partition ID Disk #10, Partition #0
Size 200 MB
Partition 1
Partition ID Disk #10, Partition #1
Disk Letter F:
File System HFS Plus
Volume Serial Number 546BDC25
Size 2794 GB
Used Space 2332 GB (83%)
Free Space 462 GB (17%)
Manufacturer SAMSUNG
Heads 16
Cylinders 124,519
Tracks 31,752,345
Sectors 2,000,397,735
Device type Fixed
ATA Standard ACS2
Serial Number S3D2NX0HB00871J
Firmware Version Number EXM03B6Q
LBA Size 48-bit LBA
Power On Count 657 times
Power On Time 96.3 days
Speed Not used (SSD Drive)
Features S.M.A.R.T., NCQ, TRIM, SSD
Interface SATA
Capacity 953 GB
Real size 1,024,209,543,168 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 37 °C
05
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
09
Real value 96d 6h
Current 99
Worst 99
Threshold 0
Raw Value 0000000906
Status Good
0C
Real value 657
Current 99
Worst 99
Threshold 0
Raw Value 0000000291
Status Good
B1
Attribute name Wear Leveling Count
Real value 20
Current 99
Worst 99
Threshold 0
Raw Value 0000000014
Status Good
B3
Attribute name Used Reserved Block Count (Total)
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
B5
Attribute name Program Fail Count (Total)
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
B6
Attribute name Erase Fail Count (Total)
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
B7
Attribute name Runtime Bad Block (Total)
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
BB
Attribute name Uncorrectable Error Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BE
Attribute name Temperature Exceed Count
Real value 37
Current 63
Worst 49
Threshold 0
Raw Value 0000000025
Status Good
C3
Attribute name ECC Rate
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C7
Attribute name CRC Error Count
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
EB
Attribute name Power Recovery Count
Real value 170
Current 99
Worst 99
Threshold 0
Raw Value 00000000AA
Status Good
F1
Real value 24,694,645,353
Current 99
Worst 99
Threshold 0
Raw Value 00BFEA6269
Status Good
Partition 0
Partition ID Disk #2, Partition #0
File System NTFS
Volume Serial Number A8B40D1E
Size 499 MB
Used Space 376 MB (75%)
Free Space 123 MB (25%)
Partition 1
Partition ID Disk #2, Partition #1
Disk Letter C:
File System NTFS
Volume Serial Number F24DA06A
Size 953 GB
Used Space 833 GB (87%)
Free Space 119 GB (13%)
ST4000DX001-1CE168
Heads 16
Cylinders 486,401
Tracks 124,032,255
Sectors 7,814,032,065
Device type Fixed
ATA Standard ACS2
Serial Number Z306W58A
Firmware Version Number CC45
LBA Size 48-bit LBA
Power On Count 505 times
Power On Time 75.6 days
Speed 5900 RPM
Interface SATA
Capacity 3726 GB
Real size 4,000,787,030,016 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 32 °C
01
Real value 0
Current 114
Worst 99
Threshold 6
Raw Value 00039C36C0
Status Good
03
Real value 0 ms
Current 93
Worst 91
Threshold 0
Status Good
04
Real value 698
Current 100
Worst 100
Threshold 20
Raw Value 00000002BA
Status Good
05
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
07
Real value 0
Current 69
Worst 60
Threshold 30
Raw Value 000074D537
Status Good
09
Real value 75d 14h
Current 98
Worst 98
Threshold 0
Raw Value 0000000716
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 97
Status Good
0C
Real value 505
Current 100
Worst 100
Threshold 20
Raw Value 00000001F9
Status Good
B7
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
B8
Real value 0
Current 100
Worst 100
Threshold 99
Status Good
BB
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BC
Real value 34,360,262,666
Current 100
Worst 98
Threshold 0
Raw Value 000008000A
Status Good
BD
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BE
Real value 32 °C
Current 68
Worst 57
Threshold 45
Raw Value 00221A0020
Status Good
BF
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C0
Real value 26
Current 100
Worst 100
Threshold 0
Raw Value 000000001A
Status Good
C1
Real value 6,362
Current 97
Worst 97
Threshold 0
Raw Value 00000018DA
Status Good
C2
Real value 32 °C
Current 32
Worst 43
Threshold 0
Raw Value 0000000020
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
F0
Real value 87d 19h
Current 100
Worst 253
Threshold 0
Raw Value 000000083B
Status Good
F1
Real value 15,953,396,694
Current 100
Worst 253
Threshold 0
Raw Value 00B6E583D6
Status Good
F2
Real value 72,874,141,369
Current 100
Worst 253
Threshold 0
Raw Value 00F7A326B9
Status Good
Partition 0
Partition ID Disk #3, Partition #0
Disk Letter Y:
File System NTFS
Volume Serial Number D2BCA63A
Size 2047 GB
Used Space 2022 GB (98%)
Free Space 25.8 GB (2%)
Partition 1
Partition ID Disk #3, Partition #1
Disk Letter Z:
File System NTFS
Volume Serial Number 30D230EF
Size 1677 GB
Used Space 1305 GB (77%)
Free Space 372 GB (23%)
ST2000DX002-2DV164
Heads 16
Cylinders 243,201
Tracks 62,016,255
Device type Fixed
ATA Standard ACS2
Serial Number Z4Z56QDJ
LBA Size 48-bit LBA
Power On Count 702 times
Power On Time 102.3 days
Speed 7200 RPM
Interface SATA
Capacity 1863 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 33 °C
01
Real value 0
Current 116
Worst 99
Threshold 6
Raw Value 00067338A0
Status Good
03
Real value 0 ms
Current 96
Worst 95
Threshold 0
Status Good
04
Real value 954
Current 100
Worst 100
Threshold 20
Raw Value 00000003BA
Status Good
05
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
07
Real value 0
Current 67
Worst 60
Threshold 30
Raw Value 00005B3136
Status Good
09
Real value 102d 8h
Current 98
Worst 98
Threshold 0
Raw Value 0000000998
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 97
Status Good
0C
Real value 702
Current 100
Worst 100
Threshold 20
Raw Value 00000002BE
Status Good
B7
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
B8
Real value 0
Current 100
Worst 100
Threshold 99
Status Good
BB
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BC
Real value 1
Current 100
Worst 99
Threshold 0
Status Good
BD
Real value 1
Current 99
Worst 99
Threshold 0
Status Good
BE
Real value 33 °C
Current 67
Worst 56
Threshold 45
Raw Value 00231A0021
Status Good
BF
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C0
Real value 84
Current 100
Worst 100
Threshold 0
Raw Value 0000000054
Status Good
C1
Real value 4,379
Current 98
Worst 98
Threshold 0
Raw Value 000000111B
Status Good
C2
Real value 33 °C
Current 33
Worst 44
Threshold 0
Raw Value 0000000021
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
F0
Real value 122d 8h
Current 100
Worst 253
Threshold 0
Raw Value 0000000B78
Status Good
F1
Real value 9,484,575,358
Current 100
Worst 253
Threshold 0
Raw Value 003553227E
Status Good
F2
Real value 44,148,658,407
Current 100
Worst 253
Threshold 0
Raw Value 00477710E7
Status Good
Partition 0
Partition ID Disk #4, Partition #0
Size 1.81 TB
ST2000DX002-2DV164
Heads 16
Cylinders 243,201
Tracks 62,016,255
Device type Fixed
ATA Standard ACS2
Serial Number Z4Z652V8
LBA Size 48-bit LBA
Power On Count 695 times
Power On Time 108.5 days
Speed 7200 RPM
Interface SATA
Capacity 1863 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 33 °C
01
Real value 0
Current 117
Worst 99
Threshold 6
Raw Value 00077147F8
Status Good
03
Real value 0 ms
Current 96
Worst 94
Threshold 0
Status Good
04
Real value 740
Current 100
Worst 100
Threshold 20
Raw Value 00000002E4
Status Good
05
Real value 0
Current 100
Worst 100
Threshold 10
Status Good
07
Real value 0
Current 69
Worst 60
Threshold 30
Raw Value 00008E83FB
Status Good
09
Real value 108d 11h
Current 98
Worst 98
Threshold 0
Raw Value 0000000A2B
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 97
Status Good
0C
Real value 695
Current 100
Worst 100
Threshold 20
Raw Value 00000002B7
Status Good
B7
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
B8
Real value 0
Current 100
Worst 100
Threshold 99
Status Good
BB
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BC
Real value 1
Current 100
Worst 100
Threshold 0
Status Good
BD
Real value 3
Current 97
Worst 97
Threshold 0
Raw Value 0000000003
Status Good
BE
Real value 33 °C
Current 67
Worst 57
Threshold 45
Status Good
BF
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C0
Real value 65
Current 100
Worst 100
Threshold 0
Raw Value 0000000041
Status Good
C1
Real value 7,049
Current 97
Worst 97
Threshold 0
Raw Value 0000001B89
Status Good
C2
Real value 33 °C
Current 33
Worst 43
Threshold 0
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
F0
Real value 111d 8h
Current 100
Worst 253
Threshold 0
Raw Value 0000000A70
Status Good
F1
Real value 9,982,350,435
Current 100
Worst 253
Threshold 0
Raw Value 0052FE9463
Status Good
F2
Real value 56,083,348,467
Current 100
Worst 253
Threshold 0
Raw Value 000ED3FBF3
Status Good
Partition 0
Partition ID Disk #5, Partition #0
Disk Letter E:
File System NTFS
Volume Serial Number 040F4A3F
Size 1863 GB
Used Space 1713 GB (91%)
Free Space 149 GB (9%)
ST33000651AS
Form Factor 3.5"
Heads 16
Cylinders 364,801
Tracks 93,024,255
Sectors 5,860,528,065
Device type Fixed
Serial Number Z2930SZ8
LBA Size 48-bit LBA
Power On Count 1948 times
Power On Time 392.2 days
Speed 7200 RPM
Features S.M.A.R.T., AAM, NCQ
Interface SATA
Capacity 2794 GB
Real size 3,000,592,982,016 bytes
RAID Type None
S.M.A.R.T
Status Warning
Temperature 38 °C
01
Real value 0
Current 117
Worst 99
Threshold 6
Raw Value 00094A4CAC
Status Good
03
Real value 0 ms
Current 90
Worst 89
Threshold 0
Status Good
04
Real value 2,773
Current 98
Worst 98
Threshold 20
Raw Value 0000000AD5
Status Good
05
Real value 160
Current 99
Worst 99
Threshold 36
Raw Value 00000000A0
Status Good
07
Real value 0
Current 76
Worst 60
Threshold 30
Raw Value 0002FD728E
Status Good
09
Real value 392d 4h
Current 90
Worst 90
Threshold 0
Raw Value 00000024C4
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 97
Status Good
0C
Real value 1,948
Current 99
Worst 99
Threshold 20
Raw Value 000000079C
Status Good
B7
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
B8
Real value 0
Current 100
Worst 100
Threshold 99
Status Good
BB
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
BC
Real value 30,065,229,831
Current 100
Worst 99
Threshold 0
Raw Value 0000070007
Status Good
BD
Real value 1
Current 99
Worst 99
Threshold 0
Status Good
BE
Real value 38 °C
Current 62
Worst 47
Threshold 45
Raw Value 00281C0026
Status Good
BF
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C0
Real value 438
Current 100
Worst 100
Threshold 0
Raw Value 00000001B6
Status Good
C1
Real value 2,849
Current 99
Worst 99
Threshold 0
Raw Value 0000000B21
Status Good
C2
Real value 38 °C
Current 38
Worst 53
Threshold 0
Raw Value 0000000026
Status Good
C3
Attribute name Hardware ECC Recovered
Real value 0
Current 21
Worst 4
Threshold 0
Status Good
C5
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
F0
Real value 376d 15h
Current 100
Worst 253
Threshold 0
Raw Value 000000234F
Status Good
F1
Real value 4,029,443,756
Current 100
Worst 253
Threshold 0
Raw Value 00F02C6EAC
Status Good
F2
Real value 1,852,017,317
Current 100
Worst 253
Threshold 0
Raw Value 006E638AA5
Status Good
Partition 0
Partition ID Disk #6, Partition #0
Size 1.00 MB
Partition 1
Partition ID Disk #6, Partition #1
Size 2.72 TB
Manufacturer Western Digital
Heads 16
Cylinders 45,599
Tracks 11,627,745
Sectors 732,547,935
Device type Fixed
ATA Standard ACS2
Serial Number WD-WCC4N6TPSCNC
Firmware Version Number 80.00A80
LBA Size 48-bit LBA
Power On Count 538 times
Power On Time 35.5 days
Speed 5400 RPM
Capacity 2794 GB
Real size 3,000,558,944,256 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 30 °C
01
Real value 0
Current 200
Worst 200
Threshold 51
Status Good
03
Real value 6375 ms
Current 172
Worst 171
Threshold 21
Raw Value 00000018E7
Status Good
04
Real value 541
Current 100
Worst 100
Threshold 0
Raw Value 000000021D
Status Good
05
Real value 0
Current 200
Worst 200
Threshold 140
Status Good
07
Real value 0
Current 100
Worst 253
Threshold 0
Status Good
09
Real value 35d 12h
Current 99
Worst 99
Threshold 0
Raw Value 0000000354
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
0B
Attribute name Recalibration Retries
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
0C
Real value 538
Current 100
Worst 100
Threshold 0
Raw Value 000000021A
Status Good
C0
Real value 324
Current 200
Worst 200
Threshold 0
Raw Value 0000000144
Status Good
C1
Real value 13,038
Current 196
Worst 196
Threshold 0
Raw Value 00000032EE
Status Good
C2
Real value 30 °C
Current 120
Worst 101
Threshold 0
Raw Value 000000001E
Status Good
C4
Attribute name Reallocation Event Count
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C5
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C6
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C8
Attribute name Write Error Rate / Multi-Zone Error Rate
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
Partition 0
Partition ID Disk #7, Partition #0
Size 300 MB
Partition 1
Partition ID Disk #7, Partition #1
Disk Letter H:
Volume Serial Number C5B5F8F5
Size 2794 GB
Used Space 2548 GB (91%)
Free Space 245 GB (9%)
Heads 16
Cylinders 45,599
Tracks 11,627,745
Sectors 732,547,935
Device type Fixed
ATA Standard ACS2
Serial Number WD-WCC4E2FAER0T
LBA Size 48-bit LBA
Power On Count 1742 times
Power On Time 72.6 days
Speed 5400 RPM
Capacity 2794 GB
RAID Type None
S.M.A.R.T
Status Good
Temperature 32 °C
01
Real value 0
Current 200
Worst 200
Threshold 51
Raw Value 000000002C
Status Good
03
Real value 8066 ms
Current 178
Worst 175
Threshold 21
Raw Value 0000001F82
Status Good
04
Real value 1,760
Current 99
Worst 99
Threshold 0
Raw Value 00000006E0
Status Good
05
Real value 0
Current 200
Worst 200
Threshold 140
Status Good
07
Real value 0
Current 100
Worst 253
Threshold 0
Status Good
09
Real value 72d 15h
Current 98
Worst 98
Threshold 0
Raw Value 00000006CF
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
0B
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
0C
Real value 1,742
Current 99
Worst 99
Threshold 0
Raw Value 00000006CE
Status Good
C0
Real value 1,057
Current 199
Worst 199
Threshold 0
Raw Value 0000000421
Status Good
C1
Real value 38,346
Current 188
Worst 188
Threshold 0
Raw Value 00000095CA
Status Good
C2
Real value 32 °C
Current 120
Worst 97
Threshold 0
Status Good
C4
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C5
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C6
Real value 1
Current 200
Worst 200
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C8
Real value 2
Current 200
Worst 200
Threshold 0
Raw Value 0000000002
Status Good
Partition 0
Partition ID Disk #8, Partition #0
Size 300 MB
Partition 1
Partition ID Disk #8, Partition #1
Disk Letter G:
Volume Serial Number 61C22F79
Size 2794 GB
Used Space 2138 GB (76%)
Free Space 655 GB (24%)
Form Factor GB/2.5-inch
Heads 16
Cylinders 243,197
Tracks 62,015,235
Sectors 3,906,959,805
Device type Fixed
ATA Standard ACS2
Serial Number WD-WCC4M0442261
LBA Size 48-bit LBA
Power On Count 393 times
Power On Time 132.4 days
Speed 5400 RPM
Capacity 1862 GB
Real size 2,000,365,289,472 bytes
RAID Type None
S.M.A.R.T
Status Good
Temperature 37 °C
01
Real value 0
Current 200
Worst 200
Threshold 51
Status Good
03
Real value 4091 ms
Current 178
Worst 169
Threshold 21
Raw Value 0000000FFB
Status Good
04
Real value 1,504
Current 99
Worst 99
Threshold 0
Raw Value 00000005E0
Status Good
05
Real value 0
Current 200
Worst 200
Threshold 140
Status Good
07
Real value 0
Current 100
Worst 253
Threshold 0
Status Good
09
Real value 132d 9h
Current 96
Worst 96
Threshold 0
Raw Value 0000000C69
Status Good
0A
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
0B
Real value 0
Current 100
Worst 100
Threshold 0
Status Good
0C
Real value 393
Current 100
Worst 100
Threshold 0
Raw Value 0000000189
Status Good
C0
Real value 71
Current 200
Worst 200
Threshold 0
Raw Value 0000000047
Status Good
C1
Real value 1,432
Current 200
Worst 200
Threshold 0
Raw Value 0000000598
Status Good
C2
Real value 37 °C
Current 110
Worst 98
Threshold 0
Status Good
C4
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C5
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C6
Real value 0
Current 100
Worst 253
Threshold 0
Status Good
C7
Real value 0
Current 200
Worst 200
Threshold 0
Status Good
C8
Real value 0
Current 100
Worst 253
Threshold 0
Status Good
Partition 0
Partition ID Disk #9, Partition #0
Size 200 MB
Partition 1
Partition ID Disk #9, Partition #1
Disk Letter I:
Volume Serial Number 94DE0C25
Size 1862 GB
Used Space 1437 GB (77%)
Free Space 425 GB (23%)
Optical Drives
No optical disk drives detected
Audio
Sound Cards
Blackmagic Audio
NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Playback Devices
Speakers (Realtek High Definition Audio) (default)
Peripherals
HID Keyboard Device
Device Kind Keyboard
Device Name HID Keyboard Device
Vendor Unknown
Location USB Input Device
Driver
Date 6-21-2006
Version 10.0.15063.0
File C:\Windows\system32\DRIVERS\kbdhid.sys
File C:\Windows\system32\DRIVERS\kbdclass.sys
HID-compliant mouse
Device Kind Mouse
Device Name HID-compliant mouse
Vendor PixArt Imaging
Location HID-compliand device
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\mouhid.sys
File C:\Windows\system32\DRIVERS\mouclass.sys
HP LaserJet Pro MFP M125-M126 PCLmS
Device Kind Printer
Device Name HP LaserJet Pro MFP M125-M126 PCLmS
Vendor Hewlett Packard
Location DEVFB58FE (HP LaserJet Pro MFP M126nw)
Driver
Date 9-6-2013
Version 11.21.0.2679
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hppclms_125-128.gpd
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hptps-pipelineconfig.xml
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpbxpsrender.dll
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIDRV.DLL
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIRES.DLL
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIDRVUI.DLL
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDNAMES.GPD
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDDTYPE.GDL
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDSCHEM.GDL
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDSCHMX.GDL
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIDRV.HLP
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\LOCALE.GPD
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\mxdwdrv.dll
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\xpssvcs.dll
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpmacronamesf8.gpd
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsdrvf8.dll
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsUIf8.dll
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsresf8.dll
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsUIDialogf8.dll
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\MSXPSINC.GPD
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpcm125126.ini
File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\MXDWDRV.DLL
HP LJ M125126 Scan Drv
Device Kind Camera/scanner
Device Name HP LJ M125126 Scan Drv
Vendor Hewlett-Packard
Driver
Date 4-29-2015
Version 36.0.75.24896
File C:\Windows\system32\hpwia2_lj125126.dll
File C:\Windows\system32\hppscancoins64.dll
File C:\Windows\system32\hpptsplj125126_x64.dll
File C:\Windows\system32\hpzjcd01scan.dll
File C:\Windows\SysWOW64\hpptsplj125126.dll
File C:\Windows\system32\drivers\usbscan.sys
WSD Scan Device
Device Name WSD Scan Device
Comment DEVFB58FE (HP LaserJet Pro MFP M126nw)
Location http://192.168.1.70:3911/c995a693-2120-739f-7245-b9b0055dede2
Driver
Date 6-21-2006
File C:\Windows\system32\DRIVERS\WSDScan.sys
My Book 111D
Device Kind Portable Device
Device Name My Book 111D
Vendor WD
Comment I:\
Location Volume
Driver
Date 6-21-2006
Version 10.0.15063.502
File C:\Windows\System32\drivers\WUDFRd.sys
Elements 107C
Device Name Elements 107C
Vendor WD
Comment H:\
Location Volume
Driver
Date 6-21-2006
Elements 107C
Vendor WD
Comment G:\
Location Volume
Driver
Date 6-21-2006
FA GoFlex Desk
Device Name FA GoFlex Desk
Vendor Seagate
Comment K2 Unlimited
Location Volume
Driver
Date 6-21-2006
Printers
Adobe PDF
Printer Port Documents\*.pdf
Print Processor winprint
Availability Always
Priority 1
Duplex None
Print Quality 1200 * 1200 dpi Color
Status Unknown
Driver
Driver Name Adobe PDF Converter (v6.03)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\PSCRIPT5.DLL
Fax
Printer Port SHRFAX:
Availability Always
Priority 1
Duplex None
Print Quality 200 * 200 dpi Monochrome
Status Unknown
Driver
Driver Name Microsoft Shared Fax Driver (v4.00)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\FXSDRV.DLL
Final Draft PDF Converter 4
Printer Port NUL:
Availability Always
Priority 1
Duplex None
Print Quality 600 dpi Color
Status Unknown
Driver
Driver Name Amyuni Document Converter 400 (v0.64)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\acpdf400.dll
HP LaserJet Pro MFP M126nw (Default Printer)
Printer Port WSD-6cc21a8a-3ec9-4ac3-a4b4-20161a2efca9.0035
Availability Always
Priority 1
Duplex None
Print Quality 600 * 600 dpi Monochrome
Status Unknown
Driver
Driver Name HP LaserJet Pro MFP M125-M126 PCLmS (v6.03)
Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\mxdwdrv.dll
Microsoft Print to PDF
Printer Port PORTPROMPT:
Availability Always
Priority 1
Duplex None
Print Quality 600 * 600 dpi Color
Status Unknown
Driver
Driver Name Microsoft Print To PDF (v6.03)
Driver Path C:\Windows\System32\DriverStore\FileRepository\ntprint.inf_amd64_8c30031d8d0a5589\Amd64\mxdwdrv.dll
Microsoft XPS Document Writer
Availability Always
Priority 1
Duplex None
Status Unknown
Driver
Driver Name Microsoft XPS Document Writer v4 (v6.03)
Send To OneNote 16
Printer Port NUL:
Availability Always
Priority 1
Duplex None
Status Unknown
Driver
Driver Name Send to Microsoft OneNote 16 Driver (v6.03)
Network
You are connected to the internet
Connected through Intel I210 Gigabit Network Connection
IP Address 192.168.1.140
Subnet mask 255.255.255.0
Gateway server 192.168.1.1
Preferred DNS server 192.168.1.1
DHCP Enabled
DHCP server 192.168.1.1
External IP Address 103.57.254.22
Adapter Type Ethernet
NetBIOS over TCP/IP Enabled via DHCP
NETBIOS Node Type Hybrid node
Link Speed 269.9 KBps
Computer Name
NetBIOS Name ANDMEDIATWO
DNS Name AndMediaTwo
Membership Part of workgroup
Workgroup ANDMEDIA
Remote Desktop
Disabled
Console
State Active
Domain ANDMEDIATWO
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout (ms) 60,000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout (ms) 30,000
IEProxy Auto Detect Yes
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Sharing and Discovery
Network Discovery Enabled
File and Printer Sharing Enabled
File and printer sharing service Enabled
Simple File Sharing Enabled
Administrative Shares Enabled
Adapters List
Enabled
Connection Name Bluetooth Network Connection 5
DHCP enabled Yes
MAC Address 00-1A-7D-DA-71-11
Intel(R) Ethernet Connection (2) I218-LM
Connection Name Ethernet 2
DHCP enabled Yes
MAC Address 34-97-F6-00-99-F3
Intel(R) I210 Gigabit Network Connection
NetBIOS over TCPIP Yes
DHCP enabled Yes
MAC Address 34-97-F6-00-99-F4
DHCP 192.168.1.1
DNS Server 192.168.1.1
TeamViewer VPN Adapter
Connection Name Ethernet 3
DHCP enabled Yes
MAC Address 00-FF-84-C3-8F-20
Network Shares
Users C:\Users
Share C:\Users\Public\Share
Current TCP Connections
C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe (18984)
Local 192.168.1.140:50140 ESTABLISHED Remote 162.247.242.20:443 (Querying... ) (HTTPS)
C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\node.exe (19092)
Local 127.0.0.1:50159 LISTEN
C:\Program Files (x86)\Adobe\Adobe Sync\CoreSync\CoreSync.exe (20340)
Local 192.168.1.140:61461 ESTABLISHED Remote 54.235.95.139:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61895 ESTABLISHED Remote 54.250.233.211:443 (Querying... ) (HTTPS)
C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNotifyServer.exe (7800)
Local 0.0.0.0:8050 LISTEN
C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\BMDStreamingServer.exe (17380)
Local 127.0.0.1:13823 LISTEN
Local 127.0.0.1:13823 ESTABLISHED Remote 127.0.0.1:49799 (Querying... )
C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\CheckVersionPCI.exe (13492)
Local 127.0.0.1:49799 ESTABLISHED Remote 127.0.0.1:13823 (Querying... )
C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe (19536)
Local 127.0.0.1:15292 LISTEN
Local 192.168.1.140:50118 ESTABLISHED Remote 54.174.15.225:443 (Querying... ) (HTTPS)
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (14740)
Local 192.168.1.140:61568 ESTABLISHED Remote 104.16.89.20:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61470 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61876 CLOSE-WAIT Remote 52.38.131.240:80 (Querying... ) (HTTP)
Local 192.168.1.140:61877 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61878 ESTABLISHED Remote 172.217.26.232:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61879 ESTABLISHED Remote 151.101.24.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61880 ESTABLISHED Remote 151.101.24.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61469 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61882 ESTABLISHED Remote 74.125.200.93:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61885 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
Local 192.168.1.140:61886 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
Local 192.168.1.140:61889 ESTABLISHED Remote 216.58.203.194:80 (Querying... ) (HTTP)
Local 192.168.1.140:61890 ESTABLISHED Remote 216.58.203.194:80 (Querying... ) (HTTP)
Local 192.168.1.140:61067 ESTABLISHED Remote 74.125.130.188:5228 (Querying... )
Local 192.168.1.140:61284 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61291 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61312 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61407 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61439 ESTABLISHED Remote 74.208.215.59:80 (Querying... ) (HTTP)
Local 192.168.1.140:61720 ESTABLISHED Remote 216.58.203.142:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61721 CLOSE-WAIT Remote 161.202.1.7:80 (Querying... ) (HTTP)
Local 192.168.1.140:61722 CLOSE-WAIT Remote 161.202.1.7:80 (Querying... ) (HTTP)
Local 192.168.1.140:61723 ESTABLISHED Remote 52.222.136.24:80 (Querying... ) (HTTP)
Local 192.168.1.140:61718 ESTABLISHED Remote 104.122.122.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61728 ESTABLISHED Remote 74.125.68.154:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61716 ESTABLISHED Remote 108.177.97.103:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61714 ESTABLISHED Remote 216.58.203.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61732 ESTABLISHED Remote 202.134.152.202:80 (Querying... ) (HTTP)
Local 192.168.1.140:61733 ESTABLISHED Remote 52.222.135.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61734 ESTABLISHED Remote 216.58.203.131:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61739 ESTABLISHED Remote 151.101.64.196:80 (Querying... ) (HTTP)
Local 192.168.1.140:61749 ESTABLISHED Remote 74.125.68.95:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61750 ESTABLISHED Remote 74.125.68.95:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61751 CLOSE-WAIT Remote 104.19.193.102:80 (Querying... ) (HTTP)
Local 192.168.1.140:61712 ESTABLISHED Remote 216.58.203.131:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61705 ESTABLISHED Remote 216.58.203.138:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61754 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
Local 192.168.1.140:61755 ESTABLISHED Remote 52.222.135.252:80 (Querying... ) (HTTP)
Local 192.168.1.140:61756 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
Local 192.168.1.140:61757 ESTABLISHED Remote 210.176.156.21:80 (Querying... ) (HTTP)
Local 192.168.1.140:61758 ESTABLISHED Remote 210.176.156.21:80 (Querying... ) (HTTP)
Local 192.168.1.140:61759 ESTABLISHED Remote 210.176.156.21:80 (Querying... ) (HTTP)
Local 192.168.1.140:61760 ESTABLISHED Remote 52.222.136.244:80 (Querying... ) (HTTP)
Local 192.168.1.140:61704 ESTABLISHED Remote 74.125.68.95:80 (Querying... ) (HTTP)
Local 192.168.1.140:61763 ESTABLISHED Remote 216.58.203.142:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61764 ESTABLISHED Remote 31.13.78.17:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61703 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61769 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
Local 192.168.1.140:61774 CLOSE-WAIT Remote 34.202.239.120:80 (Querying... ) (HTTP)
Local 192.168.1.140:61702 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61777 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
Local 192.168.1.140:61778 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
Local 192.168.1.140:61779 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
Local 192.168.1.140:61780 ESTABLISHED Remote 216.58.203.130:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61701 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61783 ESTABLISHED Remote 151.101.9.108:80 (Querying... ) (HTTP)
Local 192.168.1.140:61784 CLOSE-WAIT Remote 34.202.239.120:80 (Querying... ) (HTTP)
Local 192.168.1.140:61700 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61788 ESTABLISHED Remote 202.134.152.201:80 (Querying... ) (HTTP)
Local 192.168.1.140:61790 CLOSE-WAIT Remote 199.96.57.6:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61699 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61673 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61798 ESTABLISHED Remote 151.101.10.2:80 (Querying... ) (HTTP)
Local 192.168.1.140:61799 ESTABLISHED Remote 151.101.40.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61800 ESTABLISHED Remote 216.58.203.141:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61801 ESTABLISHED Remote 151.101.40.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61802 ESTABLISHED Remote 216.58.203.131:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61672 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61671 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61805 ESTABLISHED Remote 216.58.203.129:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61670 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61669 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61808 ESTABLISHED Remote 31.13.78.35:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61810 ESTABLISHED Remote 148.69.64.76:80 (Querying... ) (HTTP)
Local 192.168.1.140:61812 ESTABLISHED Remote 216.58.203.194:80 (Querying... ) (HTTP)
Local 192.168.1.140:61817 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
Local 192.168.1.140:61820 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
Local 192.168.1.140:61821 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
Local 192.168.1.140:61668 ESTABLISHED Remote 66.235.159.165:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61823 CLOSE-WAIT Remote 52.11.253.14:80 (Querying... ) (HTTP)
Local 192.168.1.140:61824 ESTABLISHED Remote 216.58.220.162:80 (Querying... ) (HTTP)
Local 192.168.1.140:61825 CLOSE-WAIT Remote 54.254.201.68:80 (Querying... ) (HTTP)
Local 192.168.1.140:61827 ESTABLISHED Remote 161.170.238.122:80 (Querying... ) (HTTP)
Local 192.168.1.140:61830 ESTABLISHED Remote 54.206.87.167:80 (Querying... ) (HTTP)
Local 192.168.1.140:61649 ESTABLISHED Remote 66.235.159.165:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61834 ESTABLISHED Remote 216.58.203.142:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61835 ESTABLISHED Remote 31.13.78.35:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61616 ESTABLISHED Remote 120.138.106.206:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61837 ESTABLISHED Remote 107.178.242.198:80 (Querying... ) (HTTP)
Local 192.168.1.140:61838 ESTABLISHED Remote 52.222.135.55:80 (Querying... ) (HTTP)
Local 192.168.1.140:61613 ESTABLISHED Remote 66.235.159.165:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61840 ESTABLISHED Remote 210.176.156.45:80 (Querying... ) (HTTP)
Local 192.168.1.140:61842 ESTABLISHED Remote 103.229.206.182:80 (Querying... ) (HTTP)
Local 192.168.1.140:61609 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
Local 192.168.1.140:61844 CLOSE-WAIT Remote 104.244.43.209:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61845 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
Local 192.168.1.140:61608 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
Local 192.168.1.140:61848 ESTABLISHED Remote 148.69.64.76:80 (Querying... ) (HTTP)
Local 192.168.1.140:61849 ESTABLISHED Remote 216.58.203.129:80 (Querying... ) (HTTP)
Local 192.168.1.140:61850 ESTABLISHED Remote 216.58.220.162:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61607 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
Local 192.168.1.140:61852 ESTABLISHED Remote 31.13.78.17:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61853 ESTABLISHED Remote 172.217.24.35:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61606 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
Local 192.168.1.140:61858 CLOSE-WAIT Remote 34.194.121.84:80 (Querying... ) (HTTP)
Local 192.168.1.140:61605 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
Local 192.168.1.140:61860 ESTABLISHED Remote 104.244.42.8:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61719 ESTABLISHED Remote 216.58.203.136:80 (Querying... ) (HTTP)
Local 192.168.1.140:61862 CLOSE-WAIT Remote 34.194.121.84:80 (Querying... ) (HTTP)
Local 192.168.1.140:61863 ESTABLISHED Remote 54.206.87.167:80 (Querying... ) (HTTP)
Local 192.168.1.140:61864 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61865 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61866 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61867 ESTABLISHED Remote 151.101.0.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61604 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
Local 192.168.1.140:61587 ESTABLISHED Remote 104.16.89.20:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61571 ESTABLISHED Remote 104.16.89.20:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61871 CLOSE-WAIT Remote 52.38.131.240:80 (Querying... ) (HTTP)
Local 192.168.1.140:61872 ESTABLISHED Remote 151.101.0.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61873 ESTABLISHED Remote 54.206.87.167:80 (Querying... ) (HTTP)
C:\Program Files (x86)\Google\Drive\googledrivesync.exe (18200)
Local 192.168.1.140:50012 CLOSE-WAIT Remote 216.58.197.42:443 (Querying... ) (HTTPS)
Local 192.168.1.140:50014 CLOSE-WAIT Remote 216.58.197.42:443 (Querying... ) (HTTPS)
Local 192.168.1.140:60282 ESTABLISHED Remote 74.125.68.125:5222 (Querying... )
Local 192.168.1.140:61466 CLOSE-WAIT Remote 216.58.197.74:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61113 CLOSE-WAIT Remote 216.58.203.141:443 (Querying... ) (HTTPS)
C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe (17240)
Local 127.0.0.1:49923 ESTABLISHED Remote 127.0.0.1:49850 (Querying... )
C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe (16836)
Local 127.0.0.1:49850 LISTEN
Local 127.0.0.1:49850 ESTABLISHED Remote 127.0.0.1:49923 (Querying... )
C:\Program Files\Speccy\Speccy64.exe (12920)
Local 192.168.1.140:61893 ESTABLISHED Remote 188.121.41.51:80 (Querying... ) (HTTP)
C:\Windows\System32\svchost.exe (21152)
Local 192.168.1.140:50448 ESTABLISHED Remote 74.125.68.108:993 (Querying... )
hasplms.exe (5784)
Local 0.0.0.0:1947 LISTEN
lsass.exe (960)
Local 0.0.0.0:49777 LISTEN
nvcontainer.exe (4512)
Local 127.0.0.1:65001 ESTABLISHED Remote 127.0.0.1:49844 (Querying... )
Local 127.0.0.1:49844 ESTABLISHED Remote 127.0.0.1:65001 (Querying... )
Local 127.0.0.1:65001 LISTEN
Local 127.0.0.1:65000 LISTEN
postgres.exe (6340)
Local 0.0.0.0:5432 LISTEN
remoting_host.exe (5944)
Local 192.168.1.140:49782 ESTABLISHED Remote 74.125.68.125:5222 (Querying... )
services.exe (952)
Local 0.0.0.0:49674 LISTEN
spoolsv.exe (3128)
Local 0.0.0.0:49667 LISTEN
svchost.exe (1088)
Local 0.0.0.0:135 (DCE) LISTEN
svchost.exe (1500)
Local 0.0.0.0:49665 LISTEN
svchost.exe (1900)
Local 0.0.0.0:49666 LISTEN
svchost.exe (4500)
Local 0.0.0.0:7680 LISTEN
svchost.exe (4852)
Local 192.168.1.140:49728 ESTABLISHED Remote 111.221.29.97:443 (Querying... ) (HTTPS)
System Process
Local 192.168.1.140:61684 TIME-WAIT Remote 216.58.203.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61660 TIME-WAIT Remote 151.101.8.207:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61804 TIME-WAIT Remote 151.101.40.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61661 TIME-WAIT Remote 151.101.8.207:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61803 TIME-WAIT Remote 151.101.40.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61795 TIME-WAIT Remote 151.101.40.134:80 (Querying... ) (HTTP)
Local 192.168.1.140:61662 TIME-WAIT Remote 117.18.237.29:80 (Querying... ) (HTTP)
Local 192.168.1.140:61674 TIME-WAIT Remote 151.101.8.64:80 (Querying... ) (HTTP)
Local 192.168.1.140:61664 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61665 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61874 TIME-WAIT Remote 151.101.0.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61666 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61822 TIME-WAIT Remote 120.138.127.81:80 (Querying... ) (HTTP)
Local 192.168.1.140:61807 TIME-WAIT Remote 151.101.40.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61678 TIME-WAIT Remote 202.134.152.202:80 (Querying... ) (HTTP)
Local 192.168.1.140:61679 TIME-WAIT Remote 202.134.152.202:80 (Querying... ) (HTTP)
Local 192.168.1.140:61680 TIME-WAIT Remote 202.134.152.202:80 (Querying... ) (HTTP)
Local 192.168.1.140:61681 TIME-WAIT Remote 104.122.122.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61682 TIME-WAIT Remote 104.122.122.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61683 TIME-WAIT Remote 104.122.122.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61806 TIME-WAIT Remote 216.58.203.129:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61685 TIME-WAIT Remote 216.58.203.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61686 TIME-WAIT Remote 216.58.203.131:80 (Querying... ) (HTTP)
Local 192.168.1.140:61687 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
Local 192.168.1.140:61688 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
Local 192.168.1.140:61689 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
Local 192.168.1.140:61690 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
Local 192.168.1.140:61691 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
Local 192.168.1.140:61692 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
Local 192.168.1.140:61861 TIME-WAIT Remote 104.244.42.8:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61693 TIME-WAIT Remote 216.58.203.136:80 (Querying... ) (HTTP)
Local 192.168.1.140:61706 TIME-WAIT Remote 216.58.203.138:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61694 TIME-WAIT Remote 216.58.203.136:80 (Querying... ) (HTTP)
Local 192.168.1.140:61695 TIME-WAIT Remote 216.58.203.136:80 (Querying... ) (HTTP)
Local 192.168.1.140:61792 TIME-WAIT Remote 199.96.57.6:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61787 TIME-WAIT Remote 34.202.239.120:80 (Querying... ) (HTTP)
Local 192.168.1.140:61781 TIME-WAIT Remote 216.58.203.130:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61775 TIME-WAIT Remote 108.161.189.5:80 (Querying... ) (HTTP)
Local 192.168.1.140:61768 TIME-WAIT Remote 31.13.78.17:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61762 TIME-WAIT Remote 91.228.166.11:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61753 TIME-WAIT Remote 74.125.68.95:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61658 TIME-WAIT Remote 54.255.223.63:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61752 TIME-WAIT Remote 74.125.68.95:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61713 TIME-WAIT Remote 216.58.203.131:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61731 TIME-WAIT Remote 74.125.68.154:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61730 TIME-WAIT Remote 74.125.68.154:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61724 TIME-WAIT Remote 108.177.97.103:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61884 TIME-WAIT Remote 54.250.233.211:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61883 TIME-WAIT Remote 74.125.200.93:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61881 TIME-WAIT Remote 151.101.24.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61875 TIME-WAIT Remote 151.101.0.134:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61870 TIME-WAIT Remote 104.16.80.166:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61869 TIME-WAIT Remote 104.16.80.166:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61868 TIME-WAIT Remote 104.16.80.166:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61859 TIME-WAIT Remote 185.33.223.202:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61856 TIME-WAIT Remote 172.217.24.35:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61851 TIME-WAIT Remote 216.58.220.162:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61846 TIME-WAIT Remote 104.244.43.209:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61843 TIME-WAIT Remote 54.206.87.167:80 (Querying... ) (HTTP)
Local 192.168.1.140:61839 TIME-WAIT Remote 161.170.238.122:80 (Querying... ) (HTTP)
Local 192.168.1.140:61836 TIME-WAIT Remote 103.243.221.87:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61631 TIME-WAIT Remote 52.193.182.88:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61635 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61636 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61637 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61833 TIME-WAIT Remote 52.11.253.14:80 (Querying... ) (HTTP)
Local 192.168.1.140:61650 TIME-WAIT Remote 66.235.159.165:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61654 TIME-WAIT Remote 192.229.232.199:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61655 TIME-WAIT Remote 104.16.21.35:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61656 TIME-WAIT Remote 54.255.223.63:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61657 TIME-WAIT Remote 54.255.223.63:443 (Querying... ) (HTTPS)
Local 192.168.1.140:61659 TIME-WAIT Remote 151.101.8.207:443 (Querying... ) (HTTPS)
System Process
Local 0.0.0.0:445 (Windows shares) LISTEN
Local 0.0.0.0:5357 LISTEN
Local 192.168.1.140:139 (NetBIOS session service) LISTEN
TeamViewer_Service.exe (4840)
Local 127.0.0.1:5939 LISTEN
wininit.exe (872)
Local 0.0.0.0:49664 LISTEN
xrdd.exe (4928)
Local 0.0.0.0:5454 LISTEN
Local 127.0.0.1:5454 ESTABLISHED Remote 127.0.0.1:49774 (Querying... )
Local 127.0.0.1:49668 ESTABLISHED Remote 127.0.0.1:49669 (Querying... )
Local 127.0.0.1:49669 ESTABLISHED Remote 127.0.0.1:49668 (Querying... )
Local 127.0.0.1:49774 ESTABLISHED Remote 127.0.0.1:5454 (Querying... )
Generated with Speccy v1.31.732
The instructions on my web site are to SUBMIT the Speccy results, not to post them on the forum, I hope no one else ever tries this. Also while the file above is very extensive it is also not complete.
I counted 134 processes running. This is about twice as many as my well tuned dedicated video editing computer has. It is no wonder that you cannot play a timeline with all those other processes stealing CPU cycles
You need to tune this computer
I know this is ancient but process count has almost no effect on anything. Most services are just sitting around waiting for specific events and their code never runs unless some very specific thing happens... tons of tuning guides immediately go into "disable unused services" but since service code is never executed unless something specifically opens a named pipe and calls some functionality they provide this does nothing for CPU.
The same goes for well-behaved licensing servers and such for other software.
Similarly most running programs on a given system aren't doing anything except on a schedule dispatch from the Windows task scheduler once or twice a day.
The only "offenders" in terms of not behaving well in my experience are:
There are probably some video codecs which can exceed the bitrate able to be provided by 2 regular HDDs in RAID0...
Also, AutoPICO appears to be a component of KMSPico, which is a tool that emulates a Windows volume license key server which it restarts twice a day to allow Windows to be used indefinitely without actually buying it. Stuff like that (when it needs to be running all the time) tends to be written badly Microsoft knows about this particular "crack" and based on their past attitude towards software like this there's a good chance they're degrading performance of everything intentionally on the OS that wasn't paid for...
I have an 8K R3D 6 second clip which I can playback on my 3-year old laptop at 1/8 resolution and after cleaning the Media Cache and Media Cache Files misses 1 frame but the second playback i get perfect playback
Hey PrashantMac, the 3rd test is in the same timeline as the 2nd, just move the playhead forward a few frames for the new instructions. You can use the default Adobe name for the project when it asks to convert, the exported file names will not change. Just make sure to delete any existing EXPORT files (only) before you run PPBM again, otherwise Adobe will rename the export files for you also.
