I'm creating a new poster where all the copy follows a diagonal basegrid (see image attached for reference).
Due to the size of the title, this would be split in 3 or 4 lines and I wondered if there is a way to allow the full copy to follows the same path tool. At the moment, when I select the + for the copy, this is placed on a box text and doesn't follow the path.
Did you try Shear Tool?
Shear and Rotation angles can be adjusted in Control Panel, entering exact numbers.
