What's the difference of yuv420 PrPixelFormats
Aug 13, 2017 Aug 13, 2017
the prm sdk define below yuv420 PrPixelFormats:
PrPixelFormat_YUV_420_MPEG2_FRAME_PICTURE_PLANAR_8u_601    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', '1', '2'),
PrPixelFormat_YUV_420_MPEG2_FIELD_PICTURE_PLANAR_8u_601    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', 'i', '2'),
PrPixelFormat_YUV_420_MPEG2_FRAME_PICTURE_PLANAR_8u_601_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', '1', 'f'),
PrPixelFormat_YUV_420_MPEG2_FIELD_PICTURE_PLANAR_8u_601_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', 'i', 'f'),
PrPixelFormat_YUV_420_MPEG2_FRAME_PICTURE_PLANAR_8u_709    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', '1', '7'),
PrPixelFormat_YUV_420_MPEG2_FIELD_PICTURE_PLANAR_8u_709    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', 'i', '7'),
PrPixelFormat_YUV_420_MPEG2_FRAME_PICTURE_PLANAR_8u_709_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', '1', 'F'),
PrPixelFormat_YUV_420_MPEG2_FIELD_PICTURE_PLANAR_8u_709_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('y', 'v', 'i', 'F'),
PrPixelFormat_YUV_420_MPEG4_FRAME_PICTURE_PLANAR_8u_601    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', '1', '2'),
PrPixelFormat_YUV_420_MPEG4_FIELD_PICTURE_PLANAR_8u_601    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', 'i', '2'),
PrPixelFormat_YUV_420_MPEG4_FRAME_PICTURE_PLANAR_8u_601_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', '1', 'f'),
PrPixelFormat_YUV_420_MPEG4_FIELD_PICTURE_PLANAR_8u_601_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', 'i', 'f'),
PrPixelFormat_YUV_420_MPEG4_FRAME_PICTURE_PLANAR_8u_709    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', '1', '7'),
PrPixelFormat_YUV_420_MPEG4_FIELD_PICTURE_PLANAR_8u_709    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', 'i', '7'),
PrPixelFormat_YUV_420_MPEG4_FRAME_PICTURE_PLANAR_8u_709_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', '1', 'F'),
PrPixelFormat_YUV_420_MPEG4_FIELD_PICTURE_PLANAR_8u_709_FullRange    = MAKE_PIXEL_FORMAT_FOURCC('Y', 'v', 'i', 'F'),
but,what's the difference between these formats? I know 601 & 709 means BT601 & BT709 colorspace,but what's the meaning of word "FRAME","FIELD","MPEG2","MPEG4", and "FullRange"?
SDK
848
If I want to develop a h264 export plugin,which pixel format I should choose?
Engaged ,
Aug 14, 2017 Aug 14, 2017
you need more or less all of them, depending on the capabilities you want to offer...
FRAME/FIELD = progressive / interlaced
FullRange = use luminance levels of 0..255 instead of 16..235
MPEG2/MPEG4 = use feature-set of respective encoding methods
Is it means if the video my plugin process is interleaved,I should use FIELD pixel format,otherwise use FRAME pixel format?
my plugin do h264 & hevc video encoding,so should I use MPEG4 pixel format ?
