Bonsoir,
J'utilise Lightroom sans aucun soucis depuis longtemps, cependant aujourd'hui j'ai voulu importer
des photos depuis ma carte SD, des photos en format RAW, sauf que aucunes photos apparaît, m'empêchant ainsi
des les importer.
Sauriez-vous m'aider à trouver comme importer mes photos ?
D'avance merci,
Sweder,
Show us a screen capture of what you see when "no photos appear".
Try clicking on the "untitled" in "périphériques" instead of the one in the Folders area. The folder you have selected on the left (dossier sans title" is not a folder a camera would ever generate but looks like something you inadvertently created in the Finder (it's the default name for new folders in the French OS) so I would not expect any images in there at all. Also, on the right-hand side two panels are missing. There should be a rename panel and a Destination panel there. If selecting the correct disk doesn't work, try resetting your Lightroom preferences using the instructions here: https://www.lightroomqueen.com/articles-page/how-do-i-reset-lightrooms-preferences/
The Destination section is not being shown and the PATH to the folder you have listed at the top seems to be a Utility, and or the Utilities, folder which is usually in the Applications folder.
Right click on one of the headings in the right hand panel and select Destination to show it then select a folder that you know your user name has Write permissions to.
The path is actually correct. "utilisateurs" means "users" in French, so the chosen path is the images (i.e. what the French call "pictures") folder in the users' home directory which is the correct default destination and where the user will have write permissions.
