Hello to All,
I have Photoshop CS6 installed on Mac and I'm looking for a lens profile for Canon EF 11-24mm f/4L USM lens. I know I can make a custom profile but would prefer not to.
If that's any help I also have Lightroom 5 installed.
Thank you!
The 9.6.1 dng converter should work on OS X 10.9 and still include the Canon EF 11-24mm f/4L USM lens profile.
Adobe - Adobe Camera Raw and DNG Converter : For Macintosh : Adobe DNG Converter 9.6.1
If you install the newest dng converter 9.12 that should get you the Canon EF 11-24mm f/4L USM lens profile.
The dng converter installs the same lens profiles as camera raw does.
Adobe - Adobe Camera Raw and DNG Converter : For Macintosh : Adobe DNG Converter 9.12
Hi Jeff,
Thank you so much for the link. I did try to install it but wasn't successful as I'm still running OS X 10.9.5. This DNG Converter requires 10.10 or higher. Any chances there is a previous version that works for 10.9.x? Unfortunately I don't really like newer OS X versions so I stayed on old Meverick.
Margaret
Actually if you install camera raw 9.1.1 plugin for cs6 that should include the profile as well.
Try Help>Updates from within photoshop cs6.
Sorry i should have suggested this first.
Worked like a charm! thank you!!
