Can't undo/redo in Animate CC
Aug 13, 2017 Aug 13, 2017
I don't know what happened, but I was suddenly unable to undo as i was drawing. Everytthing was working fine before, and I was working for an over an hour until it happened. I tried restarting the program and the laptop, putting all preferences back to default and eventually tried reinstalling Animate CC, just so I wouldn't have to make a post about my issue. But nothing worked, and no matter how many times I try restarting everything, I just cannot seem to undo. i've been also having a few minor problems with Photoshop as well, but nothing that makes it unusable like now Animate is for me. I want to point out that ALL tools work fine in Animate, just the undo is slowing down my work for now. Will be patiently waiting for your suggestions. Thanks in advance
Here are my specs:
Intel Core i7<3630QM 2.4GHz
8GB RAM DDR3
AMD Radeon 7670M 2GB
320 GB HDD
Windows 10 Pro x64 bit
3.2K
Community Beginner , Aug 15, 2017 Aug 15, 2017
well, robdillon's suggestion didn't work for me because it wouldn't let me delete the preferences folder from regedit, and after Googling for a while I decided to just reinstall it once more, only this time it worked because I didn't let Animate keep the preferences I had on previously.
Now should I do something to make sure that doesn't happen, or stop it from happening when it does? Because reinstalling over and over is consuming a lot of my internet data.
It sounds like you need to reset your Preferences file for Animate. Here's a tech note on how to do that: Re-create preferences
Aug 14, 2017 Aug 14, 2017
If the first suggestion doesn't solve it - try reinstalling.
Animator and content creator for Animate CC
That doesn't make any sense. If you're a local admin on your own machine, you should have no problem deleting something non-critical like that. Did you try running regedit as administrator?
Glad that you got it sorted out. I'm sorry that it was more difficult than it should have been.
Mar 21, 2018 Mar 21, 2018
Just run into the same problem (or at least a very similar one), which appeared to be caused by a corrupt workspace configuration. The fix for us was to delete the workspace folder (%LOCALAPPDATA%\Adobe\Animate CC 2017\en_US\Configuration\Workspace).
One of the symptoms was that users were losing redo functionality, and also experiencing freezes during undo operations. You can check whether or not this is happening by opening the history window and attempting an undo. If your workspace is corrupt, you will see the result on the left (redo operations are missing) instead of the list on the right.
