Photoshop CC workspace issues
Aug 14, 2017 Aug 14, 2017
My workspace is not functioning correctly. The panels float.  It's fine until I need to use "curves"  or "levels".  When I do that I cannot see the "curves" panel entirely. Or the levels panel entirely.  I can only see about the top 1/3.  When I move the other panels down so that I can see the curves (or levels)  panel, the other panels instantly shrink to a miniscule size.  It also separates from the interface and floats freely.  It is maddening!!!  It doubles my processing time!!  I have tried both the Photography workspace and my own custom workspace.  No difference.   This all started recently when I put all the settings back to the defaults. Then I reset the workspace and start all over again!!! I am using the latest Photoshop CC.
258
Adobe
Hi Carol
Have you got your panels docked to each other?
Drag a panel to the bottom edge of another until you see the highlight edge change - then release. That way expanding a panel moves the panel below downward.
So :
1. Drag
2. See panel edge highlight (blue line below)
3. release
Once you have the panels the way you want them - Save the workspace
Dave
Well that didn't work. What else have you got?:-\
Aug 15, 2017 Aug 15, 2017
If you are seeing abnormal behaviour with the panels try resetting preferences.
Go to Preferences - General - Reset Preferences on Quit. Click OK then close and restart Photoshop
Dave
You should rearrange the panels so they work for you and save a custom workspace. A small screen has limited space. I recommend that you double click on the tabs to open and close the panels while you are working to make room.
Melissa Piccone | Adobe Trainer | Online Courses Author | Fine Artist
