Hello,
I have attempted to upload HD videos to Adobe Stock and it seems that mp4 files are no longer working.
I have uploaded files in the same format in past and Adobe Stock has accepted. I don't understand why it has changed.
Will someone with Adobe please enlighten me as to what I am doing wrong.
Thank you.
Thanks for sending the files over. I downloaded one of the clips and learned it’s HEVC which is probably the problem. Also, the resolution was 1920x1088 which is a tiny bit off from the acceptable 1920X1080.
If you submit as H.264, 1920x1080 it should be fine.
Kind regards,
-Mat
Moved to Adobe Stock forum.
How long is the clip? It looks like a small file. Must be at least 5 seconds long and can't be longer than 60 seconds.
-Mat
The clip is within the parameters set out by Adobe. That is why I am baffled as to why it is not working. I used the same codec as my previous submissions.
Thanks for the reply.
Please send the clip to me using a Dropbox link or something similar and I'll take a look.
email: mhayward at adobe.com [edited by mod]
Mat,
thank you for the response, I have made a folder that I have shared with you via dropbox. It has some of the files that can't be uploaded.
Kind regards,
-Mat
