I am receiving this error when I go to Image - Adjustments - Brightness and Contrast:
Could not complete the Brightness/Contrast command because of a program error.
The error also occurs when accessing the Equalize tab under Image - Adjustments.
I have uninstalled and reinstalled PS and the problem has been cleared up. Everything else I use on a regular basis was working fine, but obviously there was some small glitch in the installation. Thanks you all for he responses
If the active layer has no pixels in the selected area (transparent), you'll get that error.
Also, have you tried a brightness/contrast adjustment layer to see if that works?
I normally use an adjustment layer for Brightness Contrast, but there is no visible modification. That was what promped me to use image/adjust which produced the error.
There is only one layer and it is active.
I have tried on about a dozen other images and get the same error on each.
Hi
Can you show a screenshot with the layers panel visible and the image window immediately before making the image adjustment?
You might also want to try a preference reset in the meantime. Go to Preferences >General > Reset Preferences on Quit. You will need to restart Photoshop after clicking OK.
Dave
You might not have a layer selected.
Try flattening a copy of the image and see if you get the same error.
If not, make sure you have a layer selected.
You may want to try MACnTUTOR's very excellent suggestion of trying an adjustment layer.
HTH
Glad you're sorted
I first got into this error when editing a PNG file screenshot from an IPhone. When I used the same picture but taken from my DSLR I got no problem. My conclusion was the selected pixels are too little/ too small. I went back to the PNG file from the IPhone, selected a larger area, and it works fine. So using a higher resolution picture or selecting a larger area of the image will solve your issue. Stay safe and healthy!
