When I type a Note in the text area of the Notes panel, there is a little box with an X in it at the start of every line, and it obscures the first letter of the line. The Notes text field is empty at first, but the box appears as soon as I click on the New Note button. The box appears to the right of the cursor, but doesn't move, so when I type a note, it covers the first letter. And a similar box occurs every time the text wraps to a new line.
I think this may have happened once before but I don't recall if it went away or if I did something like delete some preference files. Can anyone help me get rid of the Xboxes? I've tried restarting InDesign and the computer. No luck.
27 inch iMac (late 2015)
OSX Sierra 10.12.5
Adobe CC 2017
InDesign 2017.1 release, 12.1.0.56 Build
Hi ohmnath, I think I have the same problem, and have a taken a screenshot - here:
I guess this is something similar to
InD CC 2017: Tables - Header & Footer disappears when duplicating the table.
Strange icons appear in file - how to get rid of them?
InCopy doesn't display words correctly in Story view
You can try the solutions mentioned on these posts...
I do not know of any workaround for this bug
If you want, you can also report this as a bug here Adobe InDesign Feedback so that Adobe InDesign team can have it investigated... If possible, add as much information as possible while reporting the bug(like adding the sample indd document)
-Aman
InDesign Engineering Team
Whoever marked Aman's answer as correct, please don't. It clearly doesn't answer the issue. Shouldn't the marking as correct be limited to the person who originated a posting?
Currently, the problem is not occurring, so the "bug" may have been taken care of in an update.
Hi Fritz Hansen​,
We have not fixed this issue since it is not reproducible every time. Also, there is no workaround for this issue currently.
There is no other resolution for your query...Please report this as a bug on the link i have added above, so that it can be looked into.
Correct answers can be marked by both Forum moderators and the original poster of the question.
-Aman
