Locked
Object on top of object: messes with horisontal space
Aug 14, 2017 Aug 14, 2017
I have a problem with a website, but it's actually an issue I've come across several times. When two objects (e.g. image over image) are placed on top of each other, the horisontal space moves oddly when changing the browser size.
Image 1. The space between "frokost menu" and "serveres mellem..." looks like it should
Image 2. When making the browser smaller the space between "frokost menu" and "serveres mellem..." becomes larger, which it shouldn't.
If I remove the image below (background_image.jpg in the back in a-master, breakpoint 320+450) this issue disappears, but I need that extra image in the back. This has happened to me before when for example an image and a text-box have overlapped slightly.
Heres the files: https://www.dropbox.com/s/2i8ng3u387q0r6p/00Muse-problem.zip?dl=0
235
LEGEND , Aug 14, 2017 Aug 14, 2017
Starting step by step:
Master: Breakpoint at 320 unnecessary, nothing to "break" from here:
Better to set it up like this:
From Master move to "Menu Udkast":
I took away the footer element from the master and copied it to the page and grouped it to the upper elements.
The breakpoint at 320 is deleted as well and the issue is gone as far as I can see.
Does this help?
Best Regards,
Uwe
Does this help?
Best Regards,
Uwe
Aug 15, 2017 Aug 15, 2017
Thank you for taking the time to reply. Yes, it looks like this fixes the problem. I wonder if it was the grouping that fixed it?
