In this month's Character Animator Tips & Tricks, August 2017 @ 10:41, two layers are merged in a puppet by using the Command + E action. It's an arm and a hand.
It works in the video in Photoshop but I'm unable to duplicate the effect in Illustrator. Is there an Illustrator version to doing this?
Dave, in another video, says something to the effect that he likes to save a version of the puppet with all elements as they are ... and then creates a second puppet with elements merged and simplified to be used in Ch. I'd like to follow best-form principles. So this merging of layers seems important.
Thanks for your help,
Evan
Illustrator works a little differently - the only way to "merge" that I know of is the Pathfinder tool, but that's limited to similar-color/styled objects. But...Notice how Illustrator tends to list every single shape into separate layers? <path>, <shape>, etc? When you import, CH actually merges those together into single layers - otherwise you would have a rig mode puppet panel a mile long. CH will do that as long as you don't rename anything from the defaults.
So with AI files, I wouldn't worr
...Copy link to clipboard
So with AI files, I wouldn't worry too much about the merging thing.
So as long as I leave the layers as <Path>, as Illustrator provides, the parent layer is a composite in Ch. Leave it alone in Illustrator and leave it to Ch to composite later. Will do.
Thank you.
Ive done this before with basic mouth annd eye sets...swaped in to an existing AI body shape as long as you have the Head layered properly it works great!
The most difficult part is finding which puppets are Illustrator files and not Photoshop...you would think adobe would have this down by now...no I don't want to download the example puppet under see more, waste my time only to find out its photoshop?
Am I missing something....they put it in the disclaimer Photoshop & Illustrator?
Show uo which is which for crying out loud?
