Hi, I have a form that requires two different digital signatures. However, on the first digital signature they set it so fill in and digital signatures are allowed. However, when the second person tries to digitally sign, no options are available. We are using version Adobe Acrobat Pro DC 2015.
I have this same issue. We are running Acrobat Pro DC 2015.006.30456 On Win 10.0.16299. The document, after the first signature, has no security and is set to Fill in and digital signatures allowed.
I have verified that multiple signatures are possible when signature blocks are placed in the document prior to signing. But I would still like to know why we suddenly cannot place more than one signature without the signature fields.
Hi kipepeo,
As per the issue description mentioned above, you are facing issue when trying to sign a pdf with multiple signatures field, is that correct?
Would it be possible to share the pdf file you are working with to replicate the issue at our end? To share the file here in the forums, refer to the steps given in this link: How to share a file using Adobe Document Cloud
You may also share the link for the pdf via private message - How Do I Send Private Message
Let us know if you need any help.
Shivam
