I have searched the forum but none of the answers seem to apply to me...help!!!
Thank you.
Try looking at the location:
C:\Users\[user_name]\AppData\Local\Adobe\TypeSupport\PSE<version no>
and rename the files present there.
Anwesha
Sorry for the inconvenience.
Please try out the instructions mentioned in the article Error message when using the Text tool
Let us know if issue still persists.
Anwesha
Anwesha, thank you for your reply.
I performed solution 1, and restarted Elements. It did not work.
For solution 2, I found Myriad Web Pro, and deleted it (because i didn't know how to move it to another folder). Restarted Elements, it did not work.
For solution 3, there was no option for Windows 10.
For solution 4, I got to the Local Service folder, but I did not have the folders listed next.
What can we do now?
Thank you so much...
Anwesha
I see C:\Users\Owner...
Also, I'm hoping I can figure out how to "rename the files" if I ever get that far.
Thank you.
AppData folder is hidden by default.
You can turn on viewing of hidden files and folder or simply type the complete location C:\Users\[user_name]\AppData\Local\Adobe\ on Windows explorer search.
Anwesha
Anwesha,
Not only did I figure out how to turn on viewing of hidden files, I found the one file at the end of the string and changed one letter, and...IT WORKED!
Thank you very, very much. As an amateur photographer, I need to be able to put my copyright on my photos. This was a big problem for me.
I will follow up and give you high marks
Thanks again,
Lisa
