As a newbie with RH7, I'm looking at using Browse Sequences.
I created two named sequences and assigned a few topics to each,
but when I generate a WebHelp output the only visible presence
seems to be the "back - forward" triangles above the TOC. No
listbox showing the named sequences offered. The only clue that the
two sequences are working is that the back and forward buttons do
move through a particular sequence when I happen to select a topic
that's in that sequence from the TOC.
Referring to N. Perlin's article,
www.stcsig.org/oi/hyperviews/archive/02Spring/022cmagi.htm, for
example, what I see is similar to his Figure 1. Can RH7 generate
WebHelp that shows a browse sequence pictogram similar to that
shown in his Figure 3? If not, browse sequences appear to be
useless to foist upon my users.
Thanks for your comments.
Steve
