An unknown problem has occurred and the data in the Adobe Print Engine Failed to print
Jan 24, 2017 Jan 24, 2017
It means " An unknown problem has occurred and the data in the Adobe Print Engine Failed to print "
1.4K
Guide ,
Hi
First you should try to isolate the page(s) that cause the problem.
Then, try to figure out what could cause an error on the(se) page(s). Delete dodgy elements and export page until you got no more error. When you finally managed to isolate which element causes error, it will be more easy to deal with it (corrupted font, EPS, corrupted JPG, etc....)
Vinny
Aug 18, 2017 Aug 18, 2017
Hello everybody.
I have the same problem. Suddenly an only text dokument showed this window. Could print the document a lot of times before without any problems. Re-installed Indesign – didn't help.
Any ideas how to solve this problem. Thanks for your reply.
Is this just the one document that is giving you printing issue?
If so, try saving the file as an IDML (File > Save As, Format IDML) and reopen it in InDesign This method can cure most ills of InDesign documents.
If not, you should try to isolate the issue to a particular page as Vinnie suggested.
Thanks Jeff for your reply.
Well the exchange to an idml file Works only if I open the Document in Indesign 6. It does not  work if I open the Document In
CS 2017 and then try to print out.
Meanwhile, when I open a new document, write one word on the empty page, print that page, it works – print it again, the window above opens.
Are you on Mac or PC? What OS?
Any other applications with printing problems like this? Illustrator? Photoshop? Acrobat DC?
I am working on a Mac with the latest OS Sierra 10.12.6.
InDesign CS2017.
Did not test any other Application.
I would suggest trying other applications. That way you'll know if it's just InDesign.
Illustrator and photoshop are working.
I ask a friend of mine if she can have a look at the document, send her the file and she could print it without any problems.
Already de-installed and installed Indesign CS2017. No effect on the print.
Have you tried Trashing InDesign Preferences? It's possible they are corrupted.
Trash Preferences ID: https://forums.adobe.com/thread/526990
Aug 20, 2017 Aug 20, 2017
I already did that. Afterwards I am able to print the Document one time but if I print the same document again the usual window apears.
Aug 24, 2017 Aug 24, 2017
Has anyone any other suggestion. Now every new document gets this message. Printout works with CS6.
Adobe Employee ,
Aug 25, 2017 Aug 25, 2017
Hi theoh,
For Error "Error "...The Adobe Print Engine has failed..." | Print | ", please try below-mentioned help articles.
The Adobe Print Engine fails error in InDesign
Troubleshoot printing problems in InDesign
Regards
Srishti
