1
Placing layer in exact position related to canvas.
Aug 20, 2017 Aug 20, 2017
Could you make a sample JavaScript code how to position a layer in exact position related to the canvas (whole image)?
For example, there is an image 600x600px dimensions. This image contains a 'Layer 1' which is 100x200px.
We need to place the 'Layer 1' in the coordinates of x=300px and y=300px related to the top left corner of the canvas.
Actions and scripting
5.9K
Adobe
Guide ,
#target photoshop;
if(documents.length) main();
function main(){
var X = 300; //Top left
var Y = 300; //Top left
try{
var doc = app.activeDocument;
app.displayDialogs = DialogModes.NO;
var strtRulerUnits = app.preferences.rulerUnits;
var strtTypeUnits = app.preferences.typeUnits;
app.preferences.rulerUnits = Units.PIXELS;
app.preferences.typeUnits = TypeUnits.PIXELS;
activeDocument.activeLayer = activeDocument.artLayers.getByName("Layer 1");
var LB = activeDocument.activeLayer.bounds;
activeDocument.activeLayer.translate(X-LB[0].value,Y-LB[1].value);
}catch(e){alert(e + "\nLine number = " + e.line);}
finally{
app.preferences.rulerUnits = strtRulerUnits;
app.preferences.typeUnits = strtTypeUnits;
Advocate ,
A trivial question
How do i get the x  and y coordinates.
Here is a script I posted sever times.  The script places a watermark/logo image file into the active document resizes the Watermark relative to the document's height then positions the water mark in one of the bottom corners with some margin size.  The first few variables in the script set most of the size and positioning options.  Its not hard to read the code.
#target photoshop;
app.bringToFront();
var logoFile = "~/Desktop/JJMack.png"; // Watermark file should be large for resize down works better than up
var LogoSize = 10;                     // percent of document height to resize Watermark to
var LogoMargin = 1;                    // percent of Document height the Watermark should have as a margin
var BottomLetf = false;                // false = Bottom Right true Bottom Left
placeWatermark(logoFile, LogoSize, LogoMargin);  // Place Watermark into the bottom of the document
function placeWatermark(Image,Size,Margin){
   if(!documents.length) return;                       // if no document return
   try{
      var doc = app.activeDocument;                    // set Doc object to active document
      app.displayDialogs = DialogModes.NO;             // Dialog off
      var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
      var strtTypeUnits = app.preferences.typeUnits;   // Save Users Type units
      app.preferences.rulerUnits = Units.PIXELS;       // work with pixels
      app.preferences.typeUnits = TypeUnits.PIXELS;    // work with pixels
      var fileObj = new File(Image);                   // the passed file
      if(!fileObj.exists){                             // If file does not exits tell user
         alert(fileObj.name  + " does not exist!");
         return;
      placeFile(fileObj);                              // Place in file the Watermark png file
      activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER); // Insure Place did not scale layer
      var SB = activeDocument.activeLayer.bounds;      // get layers bounds
      var layerHeight = SB[3] - SB[1];                 // get layers height
      var resizePercent = (100/layerHeight)*(Size/100*doc.height.value); // Percent to resize by
      activeDocument.activeLayer.resize(resizePercent ,resizePercent,AnchorPosition.MIDDLECENTER);  // Resize width and height by percentage
      SB = activeDocument.activeLayer.bounds;          // get resized layers bounds
      activeDocument.activeLayer.translate(-SB[0].value,-SB[1].value); // Move resized layer to top left canvas corner
      var LayerWidth = (SB[2].value - SB[0].value);    // get resized layers width
      var LayerHeight = (SB[3].value - SB[1].value);   // get resized layers height
      marginSize = Margin/100*doc.height.value;        // Margin size
      // move resized watermark into the document lower right corner with some margin or lower left
      if  ( BottomLetf) {activeDocument.activeLayer.translate(marginSize,( doc.height.value -marginSize - LayerHeight));}
      else {activeDocument.activeLayer.translate((doc.width.value -marginSize - LayerWidth),( doc.height.value -marginSize - LayerHeight));}
   catch(e) { alert(e + ': on line ' + e.line); }       // inform user of error
   finally{
      app.preferences.rulerUnits = strtRulerUnits;      // Restore user ruler units
      app.preferences.typeUnits = strtTypeUnits;        // Restore user type units
function placeFile(placeFile) {
    var desc21 = new ActionDescriptor();
    desc21.putPath( charIDToTypeID('null'), new File(placeFile) );
    desc21.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcsa') );
    var desc22 = new ActionDescriptor();
    desc22.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), 0.000000 );
    desc22.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), 0.000000 );
    desc21.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc22 );
    executeAction( charIDToTypeID('Plc '), desc21, DialogModes.NO );
JJMack
May 31, 2020 May 31, 2020
This code works well. Could you please provide the code to position the watermark to the bottom center of the document?
Thank you!
Victor
Here you go:
// Align Active Layer
//macscripter.net/viewtopic.php?id=38890
AdLf = Align Left
AdRg = Align Right
AdCH = Align Centre Horizontal
AdTp = Align Top
AdBt = Align Bottom
AdCV = Align Centre Vertical
//www.ps-scripts.com/viewtopic.php?f=66&t=7036&p=35273&hilit=align+layer#p35273
align('AdBt'); align('AdCH'); // Change as required
function align(method) {
    app.activeDocument.selection.selectAll();
    var desc = new ActionDescriptor();
    var ref = new ActionReference();
    ref.putEnumerated(charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
    desc.putReference(charIDToTypeID("null"), ref);
    desc.putEnumerated(charIDToTypeID("Usng"), charIDToTypeID("ADSt"), charIDToTypeID(method));
    try {
        executeAction(charIDToTypeID("Algn"), desc, DialogModes.NO);
    } catch (e) {}
    app.activeDocument.selection.deselect();
Guide ,
Aug 21, 2017 Aug 21, 2017
To get the active layer details.
#target photoshop;
alert("Left = " +LB[0].value + " Top = " + LB[1].value + " Right = " + LB[2].value + " Bottom = " + LB[3].value);
Advocate ,
I noticed that if the document and another dimension the square is positioned at another point
Can not you use rulers in percent?
Guide ,
If you wish to do so.
Advocate ,
Aug 22, 2017 Aug 22, 2017
SuperMerlin
I can not get it to work
You could set an example
Thank you
Guide ,
That example requires you have an open document with a layer named "Layer 1"
This example create a document and a layer, fills a section of that layer and moves it so that the top left is positioned at X = 300 Y = 300
#target photoshop;
main();
function main(){
try{
    // X & Y is where the the layer is to be moved to.
//create a new document
var doc = app.documents.add(1800, 1200, 300, null, NewDocumentMode.RGB, DocumentFill.WHITE);
//create a new layer
doc.artLayers.add();
//make a selection
doc.selection.select([[600,400],[800,400],[800,800],[600,800]], SelectionType.REPLACE, 0, false);
//create a colour
var Red = new SolidColor;
Red.rgb.hexValue = "ff0000";
//set foreground colour to red
app.foregroundColor = Red;
//fill selection
doc.selection.fill(app.foregroundColor);
//deselect
doc.selection.deselect();
// get bounds of active layer
//move layer to X,Y as defined above
//get bounds to display position of the layer
//display X and Y of top left corner of layer
alert("Top X is " + LB[0].value + "\nTop Y is " +LB[1].value);
finally{
Participant ,
Aug 25, 2022 Aug 25, 2022
Being a PS scripting beginner myself, it took me a while to get a grasp on how placing and moving (translating) objects works. So here's a little ASCII art and code reference I made that may help. I keep this in one of my script files for when I need a refresher.
   /**** Bounds reference:
    An array of 4 values in the order [x1,y1,x2,y2] or [Left,Top,Right,Bottom]
    bounds[0] = x1 or Left
    bounds[1] = y1 or Top
    bounds[2] = x2 or Right
    bounds[3] = y2 or Bottom
    Width = (x2-x1) or (bounds[2]-bounds[0])
    Height= (y2-y1) or (bounds[3]-bounds[1])
    Diagram:
     (x1,y1)        (x2,y1)
    (0-Left)    (2-Right)(1-Top)
       ...___Width____...
        |             Height
     (x1,y2)        (x2,y2)
                  (3-Bottom)
@27shutterclicks â€“ thanks for sharing, I do a similar thing as well:
var layerBounds = activeDocument.activeLayer.bounds;
var layerWidth = layerBounds[2].value - layerBounds[0].value;
var layerHeight = layerBounds[3].value - layerBounds[1].value;
alert(layerBounds[0].value);
alert(layerBounds[2].value);
alert(layerBounds[1].value);
alert(layerBounds[3].value);
alert(layerWidth);
alert(layerHeight);
// or
var selectionBounds = activeDocument.selection.bounds;
var selectionLeft = selectionBounds[0].value;
var selectionTop = selectionBounds[1].value;
var selectionRight = selectionBounds[2].value;
var selectionBottom = selectionBounds[3].value;
var selectionWidth = selectionBounds[2].value - selectionBounds[0].value;
var selectionHeight = selectionBounds[3].value - selectionBounds[1].value;
var selectionXCenter = (selectionBounds[0].value + selectionWidth) / 2;
var selectionYCenter = (selectionBounds[1].value + selectionHeight) / 2;
// Left [0], Top [1], Right [2] and Bottom [3]
//    Bounds:
//    + - - - - - - - [1] - - - - - - - +
//   [0]                               [2]
//    + - - - - - - - [3] - - - - - - - +
