haiii
i have problem in 1280 breakpoint, where i had adjusted text in 1280 breakpoint with page min height = 500.But in 1280 * 720 and 1280*600 the text is not aligned to centre.
so, is there any solution for text to align to centre at any breakpoint and any resolution?
It's expensive, but this will do what you need:
https://www.qooqee.com/muse-widgets/responsive-vertical-positioning/index.html
I do not understand what the centering of text has to do with minimum height of your page?
If you use fluid width breakpoints you can pin it to container by this:
If you use fixed width breakpoints you won`t need any pinning.
Best Regards,
Uwe
Uwe, stays59034610 has in mind the vertical center
