Hello,
When I send Coldfusion accentuated, it does not happen because of; ect...
Here is an example :
<meta http-equiv="Content-Type" content="text/html ; charset = utf-8 "/>
<body>
<CFOUTPUT>
<cfset mesx = "Nous avons collecté le maximum d'informations sur les golfs.<br>Nous n'avons pu, faute d'information et en particulier d'e-mail,… ">
mesx : #mesx#
</CFOUTPUT>
Here's the feedback :
Invalid CFML construct found on line 29 at column 67. | |
ColdFusion was looking at the following text: ; The CFML compiler was processing:
The error occurred in \\192.168.0.1\H3637\zennetbuilder.com\Admin\EssaiD.cfm: line 29 | |
27 : <TR> 28 : 29 : <cfset mesx = "Nous avons collecté le maximum d'informations sur les golfs.<br> 30 : 576 : Nous n'avons pu, faute d'information et en particulier d'e-mail »> |
I'm not an experienced developer. If anyone can give me a clue!
Thank you
Mark
To use # as a character in a string, escape it by adding another #. Otherwise, ColdFusion thinks you wish to evaluate a variable.
<cfset mesx = "Nous avons collecté le maximum d&##39;informations sur les golfs.<br>Nous n&##39;avons pu, faute d&##39;information et en particulier d&##39;e-mail, ...">
<CFOUTPUT>
mesx : #mesx#
</CFOUTPUT>
Hello,
I do not understand your answer.
When it is entered: "Ceci est l'essai du jour", the system receives "Ceci est l'essai du jour." And because of ; It crashes.
Thank you for your help.
Cdlt
marcp12146864 wrote
Hello,
It crashes not because of ; but because of #. That is a special character in ColdFusion. When it occurs in a string you should escape it by adding another #. Hence "Ceci est l&##39;essai du jour".
Hello,
That I understood well ;-)!
It's new ? Because until now I had not had this problem (but am a beginner)
But above all how to solve the problem with several programs?
Examples welcome
cordially
What do you mean? Please illustrate with code examples.
I guess if this happened 1 times, it can happen other times in other programs!
My code is simple:
Ceci est l'essai du 20 août 2017 |
Tank you
Assuming you have a recent version of ColdFusion, then use the canonicalize function.
Example
<cfprocessingdirective pageencoding="utf-8" >
<cfset testString ="Ceci est l'essai du 20 août 2017">
<cfoutput>
Test string: #testString#<br>
encodeForHTML(testString): #encodeForHTML(testString)#<br>
canonicalize(encodeForHTML(testString),false,false): #canonicalize(encodeForHTML(testString),false,false)#
</cfoutput>
Open the CFM page and view the source in the browser.
Je n'ai que la version 8
It is possible on ColdFusion 8! There is a workaround whereby you can call the canonicalize method on an encoder created from the ESAPI Java cl....
