Need help with If/Then script adjustment
Aug 13, 2017 Aug 13, 2017
Hello,
I am a digital painter that has been dabbling in PS scripting (or more accurately "hacking", as JJMack likes to put it) over the last few years to help increase the efficiency in my workflow.  I have a script that I have been utilizing for the last few years that I have been able to modify periodically to meet my increased needs, but alas,... I have reached the limits of my current level of knowledge and require assistance!   The basic concept of the script is that I utilize Layer styles (described in the script as "magic layer1, magic layer2, etc...") that I am continually rasterizing, merging down on to a "base paint" layer beneath, and creating a new "magic layer" on top again.  As I utilize several of these "magic layers", the script is designed to cycle through the various names of these Layer styles (magic layer1, magic layer2, magic layer3, etc...) in order to determine how to begin, continue, or end the utilization of the script.  I have recently begun to utilize different Layer styles that I refer to as "special magic layers"; for these "special magic layers", I would like the script to run a different (scripted) process, rather than the usual "rasterization, merge down, create a new magic layer above" process.
Here is the script as it is written now:
function main() {
    var __indexOf = [].indexOf || function(item) { for (var i = 0, l = this.length; i < l; i++) { if (i in this && this === item) return i; } return -1; };
    var makeNewLayer = function() {
        var currentLayer = doc.activeLayer;
        var basePaintLayer = doc.artLayers.add();
        basePaintLayer.name = "base paint layer";
        basePaintLayer.move(currentLayer, ElementPlacement.PLACEBEFORE);
  doc.activeLayer.merge();
        var newLayer = doc.artLayers.add();
        newLayer.name = 'Magic Layer1';
        newLayer.move(currentLayer, ElementPlacement.PLACEBEFORE);
        try {
            newLayer.applyStyle('Magic Layer1');
        } catch(e) {
            throw new Error("Can't find Magic Layer Style");
        doc.activeLayer = newLayer;
    var doc = app.activeDocument,
        lay = doc.activeLayer,
        names = ['Magic Layer1',
                 'Magic Layer2',
                 'Magic Layer3',
                 'Magic Layer4',
                 'Magic Layer5'];
    // If the layer is not named as in names array
    if (__indexOf.call(names, lay.name) < 0 ) {
        // create a new layer
            makeNewLayer();
            return;
    if (doc.activeLayer.kind == LayerKind.NORMAL && doc.activeLayer.bounds[2] == 0 && doc.activeLayer.bounds[3] == 0) {
        var dialog = confirm("End this Magic Layer?");
        if (dialog) {
            app.activeDocument.activeLayer.remove();
    // Dialogue to rename ended Magic Layer
        if (dialog) {
    var aDoc = activeDocument;
    var actLay = aDoc.activeLayer;
        if (actLay.typename == "ArtLayer") {
            var newName = prompt ("Would you like to rename this layer?", actLay.name, "Rename");
        try {actLay.name = newName;} catch (e) {};
        } else {
            alert("active Layer is not a LayerSet");
        return;
        var idrasterizeLayer = stringIDToTypeID( "rasterizeLayer" );
    var desc5 = new ActionDescriptor();
    var idnull = charIDToTypeID( "null" );
        var ref4 = new ActionReference();
        var idLyr = charIDToTypeID( "Lyr " );
        var idOrdn = charIDToTypeID( "Ordn" );
        var idTrgt = charIDToTypeID( "Trgt" );
        ref4.putEnumerated( idLyr, idOrdn, idTrgt );
    desc5.putReference( idnull, ref4 );
    var idWhat = charIDToTypeID( "What" );
    var idrasterizeItem = stringIDToTypeID( "rasterizeItem" );
    var idlayerStyle = stringIDToTypeID( "layerStyle" );
    desc5.putEnumerated( idWhat, idrasterizeItem, idlayerStyle );
executeAction( idrasterizeLayer, desc5, DialogModes.NO );
    makeNewLayer();
    return;
main();
Here is the new script that I would like to have run INSTEAD if the layer is named "Special Magic Layer1, Special Magic Layer2, or Special Magic Layer3":
// Load transparency from layer
var idsetd = charIDToTypeID( "setd" );
    var desc272 = new ActionDescriptor();
        var ref127 = new ActionReference();
        var idChnl = charIDToTypeID( "Chnl" );
        var idfsel = charIDToTypeID( "fsel" );
        ref127.putProperty( idChnl, idfsel );
    desc272.putReference( idnull, ref127 );
    var idT = charIDToTypeID( "T   " );
        var ref128 = new ActionReference();
        var idTrsp = charIDToTypeID( "Trsp" );
        ref128.putEnumerated( idChnl, idChnl, idTrsp );
    desc272.putReference( idT, ref128 );
executeAction( idsetd, desc272, DialogModes.NO );
// Refine selection edges
var idrefineSelectionEdge = stringIDToTypeID( "refineSelectionEdge" );
    var desc273 = new ActionDescriptor();
    var idrefineEdgeBorderRadius = stringIDToTypeID( "refineEdgeBorderRadius" );
    var idPxl = charIDToTypeID( "#Pxl" );
    desc273.putUnitDouble( idrefineEdgeBorderRadius, idPxl, 0.000000 );
    var idrefineEdgeBorderContrast = stringIDToTypeID( "refineEdgeBorderContrast" );
    var idPrc = charIDToTypeID( "#Prc" );
    desc273.putUnitDouble( idrefineEdgeBorderContrast, idPrc, 0.000000 );
    var idrefineEdgeSmooth = stringIDToTypeID( "refineEdgeSmooth" );
    desc273.putInteger( idrefineEdgeSmooth, 0 );
    var idrefineEdgeFeatherRadius = stringIDToTypeID( "refineEdgeFeatherRadius" );
    desc273.putUnitDouble( idrefineEdgeFeatherRadius, idPxl, 0.000000 );
    var idrefineEdgeChoke = stringIDToTypeID( "refineEdgeChoke" );
    desc273.putUnitDouble( idrefineEdgeChoke, idPrc, 80.000000 );
    var idrefineEdgeAutoRadius = stringIDToTypeID( "refineEdgeAutoRadius" );
    desc273.putBoolean( idrefineEdgeAutoRadius, false );
    var idrefineEdgeDecontaminate = stringIDToTypeID( "refineEdgeDecontaminate" );
    desc273.putBoolean( idrefineEdgeDecontaminate, false );
    var idrefineEdgeOutput = stringIDToTypeID( "refineEdgeOutput" );
    var idrefineEdgeOutputSelection = stringIDToTypeID( "refineEdgeOutputSelection" );
    desc273.putEnumerated( idrefineEdgeOutput, idrefineEdgeOutput, idrefineEdgeOutputSelection );
executeAction( idrefineSelectionEdge, desc273, DialogModes.NO );
// Select layer below current layer
var idslct = charIDToTypeID( "slct" );
    var desc301 = new ActionDescriptor();
        var ref154 = new ActionReference();
        var idBckw = charIDToTypeID( "Bckw" );
        ref154.putEnumerated( idLyr, idOrdn, idBckw );
    desc301.putReference( idnull, ref154 );
    var idMkVs = charIDToTypeID( "MkVs" );
    desc301.putBoolean( idMkVs, false );
executeAction( idslct, desc301, DialogModes.NO );
// Create new layer above current layer
var idMk = charIDToTypeID( "Mk  " );
    var desc274 = new ActionDescriptor();
        var ref129 = new ActionReference();
        ref129.putClass( idLyr );
    desc274.putReference( idnull, ref129 );
executeAction( idMk, desc274, DialogModes.NO );
// Stamp visible into new layer
var idMrgV = charIDToTypeID( "MrgV" );
    var desc275 = new ActionDescriptor();
    var idDplc = charIDToTypeID( "Dplc" );
    desc275.putBoolean( idDplc, true );
executeAction( idMrgV, desc275, DialogModes.NO );
// Invert selection
var idInvs = charIDToTypeID( "Invs" );
executeAction( idInvs, undefined, DialogModes.NO );
// Delete selection
var idDlt = charIDToTypeID( "Dlt " );
executeAction( idDlt, undefined, DialogModes.NO );
// Undo selection
    var desc355 = new ActionDescriptor();
        var ref208 = new ActionReference();
        ref208.putProperty( idChnl, idfsel );
    desc355.putReference( idnull, ref208 );
    var idNone = charIDToTypeID( "None" );
    desc355.putEnumerated( idT, idOrdn, idNone );
executeAction( idsetd, desc355, DialogModes.NO );
// Merge down
var idMrgtwo = charIDToTypeID( "Mrg2" );
    var desc331 = new ActionDescriptor();
executeAction( idMrgtwo, desc331, DialogModes.NO );
// Select layer above current layer
    var desc337 = new ActionDescriptor();
        var ref190 = new ActionReference();
        var idFrwr = charIDToTypeID( "Frwr" );
        ref190.putEnumerated( idLyr, idOrdn, idFrwr );
    desc337.putReference( idnull, ref190 );
    desc337.putBoolean( idMkVs, false );
executeAction( idslct, desc337, DialogModes.NO );
// Delete selected layer
    var desc349 = new ActionDescriptor();
        var ref202 = new ActionReference();
        ref202.putEnumerated( idLyr, idOrdn, idTrgt );
    desc349.putReference( idnull, ref202 );
executeAction( idDlt, desc349, DialogModes.NO );
// Make new layer above current layer
    var desc80 = new ActionDescriptor();
        var ref77 = new ActionReference();
        ref77.putClass( idLyr );
    desc80.putReference( idnull, ref77 );
executeAction( idMk, desc80, DialogModes.NO );
// Add Magic Layer1 style
var idASty = charIDToTypeID( "ASty" );
    var desc15 = new ActionDescriptor();
        var ref14 = new ActionReference();
        var idStyl = charIDToTypeID( "Styl" );
        ref14.putName( idStyl, "Magic Layer1" );
    desc15.putReference( idnull, ref14 );
        var ref15 = new ActionReference();
        ref15.putEnumerated( idLyr, idOrdn, idTrgt );
    desc15.putReference( idT, ref15 );
executeAction( idASty, desc15, DialogModes.NO );
// Name layer style: Magic Layer1
    var desc16 = new ActionDescriptor();
        var ref16 = new ActionReference();
        ref16.putEnumerated( idLyr, idOrdn, idTrgt );
    desc16.putReference( idnull, ref16 );
        var desc17 = new ActionDescriptor();
        var idNm = charIDToTypeID( "Nm  " );
        desc17.putString( idNm, """Magic Layer1""" );
    desc16.putObject( idT, idLyr, desc17 );
executeAction( idsetd, desc16, DialogModes.NO );
Thank you; I am greatful for any and all assistance!  Also (as an aside), how do you post scripts in the forums in the 'script editor' form?  I've been trying to figure that out!?
-Eric
Actions and scripting
1.3K
Community Expert , Aug 17, 2017 Aug 17, 2017
I made a slight mistake with my above code, which I corrected. The last case - if you want a default case if the other cases don't match, should be with default. See my above post.
You need to simplify your code. The AM code makes things hard to read, so I like to put that stuff in functions and call them in my main code as needed. So something like:
var doc = activeDocument;
var curLayer = doc.activeLayer
myCode01 ()//I want the code in this function to be applied to everything
switch(curLayer.name)
Adobe
Hello,
Shameless bump!  (Okay,... not quite so shameless,... in fact, quite shameful!!)  Help?!  Please!
-Eric
I would use a switch statement to route the code to how you want it. Place routines that are common to several of the switch conditions in a function so that they can easily be referred to in the switch.
var layerName = doc.activeLayer.name;
switch(layerName){
    case 'magic layer1':
    //code here
    break;
    case 'magic layer2':
    //code here
    break;
    case 'special magic layers':
    //code here
    break;
    default:
    //will run this code if non of the above cases match
Okay so I've tried this,... not sure if my functions are 'wrapped' or called correctly,... but I'm getting an error at "will run this code if none of the above cases match".  As you may notice (by all of my ugly code), I depend on the script listener a lot, and am not really much of a coder.  Although I am trying to learn, it's hard to manage to find the time to devote to learning javascript while working the day job.  Not sure how to proceed from here:
var rasterizeMagiclayer = function() {
    //Rasterize Magiclayer layer
// Merge layer down
    var desc43 = new ActionDescriptor();
executeAction( idMrgtwo, desc43, DialogModes.NO );
// Name layer: Magiclayer1
        desc17.putString( idNm, """Magiclayer1””” );
// Add Magiclayer1 style
        ref14.putName( idStyl, "Magiclayer1” );
var rasterizeSpecialMagic1 = function() {
// Invert selection
// Delete selection
// Undo selection
// Merge down
        desc17.putString( idNm, """Magiclayer1""" );
        ref14.putName( idStyl, "Impasto" );
switch(layerName){
    case 'Magiclayer1’:
        call (rasterizeImpasto)
    break;
    case 'Magiclayer2’:
    break;
    case 'SpecialMagic1':
        call (rasterizeSpecialMagic1)
    break;
    case:
// Name layer style: base paint layer
        desc17.putString( idNm, """base paint layer""" );
        desc17.putString( idNm, """Impasto""" );
// Add Magiclayer1 layer style
    break;
Thanks for your assistance!
-Eric
switch(curLayer.name){
    case 'layer name 1':
        myCode02 ()//I only want the code for this function used on this layer name
        break;//don't forget to use a break and a semicolon after each case.
    case 'layer name 2':
        myCode03 ()//I only want the code for this function used on this layer name
        break;
    default:
        myCode04 ()//I want the code in this function to run only if none of the other layer names match. A default section is optional.
        //no break; is needed
myCode05 ()//This function will run after the switch and apply to all layer names
function myCode01(){
    //code here for this function
    }//end function
function myCode02(){
    }//end function
function myCode03(){
    }//end function
function myCode04(){
    }//end function
function myCode05(){
    }//end function
Aug 20, 2017 Aug 20, 2017
        names = [‘magic layer1’,
                 ‘magic layer2’,
                 ‘magic layer3’
                   ‘special magic layer’];
        var dialog = confirm("End this Magic layer?");
        if (dialog) {
        if (dialog) {
I'm assuming you have more code outside of this function. If not you really don't need to wrap it all in a function. You also seem to have one extra brace, so not sure what's going on with that. You have two if statements right next to each other for your dialog (lines 11 and 15) Those should be combined. If you want the script to end, you just have to make sure there is no code to follow. So if there is more code outside this function, and you call the function, and there is code after that function call, it will still play the code. If you really want to stop the script, you could put the entire script in a try/catch block then when you want the script to end do something like this
try{
   alert('before the throw')
   throw 'The script will end'
   alert('after the throw')
catch(e){alert(e)}
This will play the alert, throw an error and the show the alert of the throw, but not play the second alert.
As far as suspend history, I'll have to look into that. I really don't use that.
Yes, that is what is occurring,... the script is going to the next code (this function is line 4 of the script that you supplied for me:)
So the switch statement follows.  What I am trying to accomplish is that if I enact the script and the name of the layer match's any of the designated names AND there are NO active pixels in the layer (the layer is empty), then it will throw the "End this magic layer?" dialog.  If I answer 'yes', the active layer will be deleted and the dialog to rename the new active layer (the layer that was below the previous layer) is enacted.  This IS happening,... but,... as you said, the script is continuing on to the switch statement and calling an error; As this script will ONLY be enacted should the layer be empty, I want it to conclude after the dialog to rename the layer.
The same issue seems to occur should I answer 'no' to the "End magic layer?" dialog; rather than just concluded,... it continues on to the switch statement.  I think I understand what you are suggesting, but I would rather the script just conclude on its own for those two circumstances without throwing an additional alert for me to interact with.
Is there a way to ask the script to only run this function if the layer has NO active pixels (layer is empty) AND then without continuing to the switch statement?
PS. The extra brace was because I had it wrapped in a function,... which I now realize that I didn't need to do....
-Eric
You can also set a variable to end the script. Say
var run = true;
Then when you want to end the script, make sure any code after your switch or whatever you have is in an if statement to check if run is still true.
If you are doing a loop, and want to end it, which it sounds like you're doing, put a break; in an if statement and the loop will stop.
I'm sorry, but my javascript knowledge is minimal;  I kind of understand what you're saying intellectually, but I can't seem to figure out where to put  the break; in order to make it work:
var curLayer = doc.activeLayer,
                 ‘magic layer2’,
                 ‘magic layer3’,
                 ‘special magic layer1’,
                 ‘special magic layer2’];
        if (dialog) {
        if (dialog) {
        rasterizeMagic()
    break;
    case 'magic layer2’:
        rasterizeMagic()
    break;
    case 'magic layer3’:
        rasterizeMagic()
    break;
    case 'special magic layer1':
        rasterizeSpecialmagic()
    break;
    case 'special magic layer2’:
    break;
    default:
    begin magiclayers()
//functions for switch statements begin below here
low here
////functions for switch statements begin below here for switch statements begin below here
I seemed to me, that placing the break; between line 20 and 21 should work,... but alas it doesn't end the script.  Also, I'm at a lost for how to end the script if the dialog on line 10 is NOT confirmed.
Thanks for your patience and consideration,
-Eric
Aug 21, 2017 Aug 21, 2017
You might want to try the structure of this script:
var actLayer = doc.activeLayer;
var run = true;
var layArray = new Array();
//loop to get layers and put into an array so you can make them active. If you delete layers in a loop, you need to do something like this
for(var i = 0;i>doc.layers.Length;i++){
    layArray.push (doc.activeLayer);
    }//end loop
//This is the loop that can cycle through layers or whatever you want
for(var i = 0;i<layArray.length;i++){
    //if for checking if layer is pixel based and not empty
    if(doc.activeLayer.kind == LayerKind.NORMAL && doc.activeLayer.bounds[2] == 0 && doc.activeLayer.bounds[3] == 0)){
        actLayer = layArray;//goes through all layers that were put in the layer array
        doc.activeLayer = actLayer;
        //add confirm here to remove layer
        var removeLayer = confirm('Do you want to remove magic layer?');
        if(removeLayer){
            actLayer.remove();
            //add confirm to end the script. if no, the script will continue and go to the next layer in the array
            //if you alway want to end the script if you remove a layer, you don't have to have this second confirm statment
            //just put the change the run variable to false within this if statement
            var endScript = confirm ('Do you want to end the script?');
            if(endScript){run = false}//set run to false to end the script
            }//end if for removing layer
        else{//the else will run the name of the layer through the switch and continue the script
            //add prompt to rename the layer
            var chgLayerName = prompt ('Do you want to rename this layer?', actLayer.name, 'Rename');
            if(chgLayerName !=null){actLayer.name = chgLayerName};//makes sure the cancel button isn't pressed
            switchForLayerNames ();
            };//end else
    }//end if to see if the active layer is a pixel based layer
    if(!run){break;}//This will stop the loop and the script should stop if you don't have any code after the loop.
    };//end brace for loop
function switchForLayerNames(){
    switch(actLayer.name){
        case 'some layer name 1':
            //code here to do something to this layer
            break;//need break after each case statement
            //more code
            break;
        default:
            //this will catch the layers that don't have a name matched in your switch statement.
            //If this is the layer you want the confirm statement, you can put it here, you may not need it here,
            //and it can be removed since it's also in the code in the loop:
            var askQuestion = confirm ('Do you want to end the script?');
            //if statement to check which choice was selected: a true would be yes, to ending the script
            if(askQuestion){run = false}// if the selection to end the script is true, the run variable is set to false;
        };//end brace for switch
    ////Here you use an if statement to end the loop if run was set to false;
    }//end function switchForLayerNames
Aug 27, 2017 Aug 27, 2017
                 ‘magic layer2’,
                 ‘magic layer3’,
        if (dialog) {
        if (dialog) {
        rasterizeMagic()
    break;
        rasterizeMagic()
    break;
        rasterizeMagic()
    break;
    break;
    break;
    default:
    begin magiclayers()
  • Lines 3-7 are for the purpose of ensuring that the code that begins on line 9 enacts ONLY if the layer matches the array of DESIGNATED NAMES.  For some reason, that is NOT occurring,… the code for line 9 is enacting for ANY layer that has zero active pixels.  How can I ensure that this script only enacts when the layer name matches the 'names array'?
  • Lines 9-13 should (if the layer name matches the array AND the layer has zero active pixels) produce a dialog box that will ask if I would like to “End this Magic Layer?”  If I answer “No”, I simply want the dialog box to close and nothing else.  Script over.  That is NOT happening,… the script is continuing on to the switch statement;  how do I stop that from occurring?  This is because sometimes in the midst of painting, I accidentally enact the script when I don’t intend to; this allows me to stop the script in such cases.
  • If I answer “Yes”, then line 12 will simply delete the active layer (the layer that has zero active pixels and matches the array of names) and then:
  • Lines 15-19 will allow me to rename the layer below the previously deleted layer, should I wish to. (You previously asked me why I have two statements right next to each other for dialog, lines 11 and 15.  I believe that is because the enacting of the dialog on line 15 is dependent upon the answer to the dialog on line 11,... that is to say, should I answer "No" to the dialog on line 11, then it is unnecessary to continue to the dialog for line 15, as the script should simply end.)  Once the dialog to rename to remaining layer is complete, I would like the script to stop.  Nothing else,… no additional dialogs,…. Nothing.  Script over.  This is also NOT happening, as the script is also continuing on to the switch statement; how do I stop that from occurring?
Anyone and Everyone and especially ,
Thanks for the time and effort,
-Eric
I made a few changes, but you still might have issues. Your list of name is just an array of names, I can't see any place where you check that list of name against the current layer name. I added a loop for that that will then set the script to run by setting the variable 'run' to true.
On your confirm if you want to delete the layer, you don't have an else for if you select no, so of course the script will keep running. You have to set the run variable to false, so it will stop any other code from running by wrapping it in a if statement.
I still don't think you need two if statements for your confirm. The else to end the script takes are of that, and all the code that is suppose to run if you select yes should be in that one if statement.
var run = false;
        names = [‘magic layer1’,     //this is just an array. I don't see where you're checking it against the names of the layer
                 ‘magic layer2’,
                 ‘magic layer3’,
for (var i = 0; i<names.length;i++){//This loops through the names in the array and sees if there is a match with the current layer. If so it sets the rest of the script to run.
    if(curLayer.name == names){run = true}
    }//end loop
    if (doc.activeLayer.kind == LayerKind.NORMAL && doc.activeLayer.bounds[2] == 0 && doc.activeLayer.bounds[3] == 0 && run) { //add run check to see if script needs to run
        if (dialog) {
            app.activeDocument.activeLayer.remove();  //you defined doc as the activedocument, so why use app.activeDocument here?
            var aDoc = activeDocument;    //move code to main if for dialog, also you defined the activedocument at the top. You don't need to redefine it, unless there are two open docs.
               }   //end if for artLayer
            }  //end if for dialog
        else{run = false};//add to end script if you select no on confirm
     }   //end if for layer checking
if(run){//wrap switch in if statement
            rasterizeMagic()
        break;
            rasterizeMagic()
        break;
        case 'magic layer3':
            rasterizeMagic()
        break;
        break;
        case 'special magic layer2':
        break;
        default:
        begin magiclayers() //What's the begin? looks like that will throw an error. Plus this will not run unless you have a match now with the names in your array.
        } //end switch
}//end if to check to see if switch should run
I seem to be catching an error on line 3 at “run + false;”
How the script functions in its entirety:
When I run the script:
    ▪    If the active layer does NOT match any of the names in the array, the script will make two layers:
                  A layer labeled: “base paint”
                  A layer above the “base paint” layer labeled, for instance: “Magic layer 1” (which has a corresponding layer style).
    ▪    If I draw on this “Magic layer1” (active pixels on the layer) and then enact the script, the code should run through the array of names, determine that there are active pixels and then continue on to the switch statement, which will cause it to rasterize the layer style, merge it down on to the “base paint” layer, and then create a new layer above the “base paint” layer, that is labeled, for instance, “Magic layer 3” (the “Magic layer” that is created will depend upon the script that I enact,… the change in name and applied layer style is dictated in the functions).
    ▪    If I DON’T draw on this “Magic layer1” (no active pixels on the layer) and then enact the script, the code should run through the array of names, determine that there are NO active pixels and then run the script to end (should I answer “No” to the initial dialog) or run the script to delete the active layer and give the dialog to rename the remaining layer and then end.
The script is supposed to work as a “one button” solution for utilizing all of the layer styles that I use in my art.
Thanks again,
-Eric
Aug 28, 2017 Aug 28, 2017
Line 3 should be:
var run = false;
not
var run + false;
To create your new layers, add the code to do that in the else statement at line 25 in my last post.
Oops,....
  1. var run = false
... is actually what I have in the script (just missed hitting the shift key whilst typing that message),... but still getting an error.
All of the making of layers, rasterization and such is achieved in the switch statements; I only need the code that takes place before the switch statement to work properly (the code responsible for ensuring that if the layer matches the names array AND does/does not have active pixels).
Aug 29, 2017 Aug 29, 2017
What error are you getting with that line? Post the code that you have upto and including it, to make sure there's no type. It shouldn't error on something simple like that.
Aug 31, 2017 Aug 31, 2017
Okay.  Here is the entire script.
var run = false;
             ‘magic layer2’,
             ‘magic layer3’,
}//end loop
    if (dialog) {
        var aDoc = activeDocument;//move code to main if for dialog, also you defined the activedocument at the top. You don't need to redefine it, unless there are two open docs.
        rasterizeMagic()
    break;
        rasterizeMagic()
    break;
        rasterizeMagic()
    break;
    break;
    break;
    default:
    } //end switch
function rasterizeMagic(){
    //Rasterize Impasto layer
// Merge layer down
// Name layer style: magic layer1
    desc17.putString( idNm, """magic layer1""" );
// Add magic layer1 style
    ref14.putName( idStyl, "magic layer1" );
    }//end function
function rasterizeSpecialmagic(){
// Invert selection
// Delete selection
// Undo selection
// Merge down
    }//end function
function begin magiclayers(){
    }//end function
For some reason this script is coming out double spaced?!  Anyway,... if you want to test it, you only need to make a layer style named "magic layer1".   Doesn't matter what kind of layer style it is,.... I guess you could make it a 'drop shadow' style.  Also,... I'm not sure if I ever specified that I am running CS6.
Thanks again,
-Eric
Sep 03, 2017 Sep 03, 2017
So I got a little time to play around with this today; it was beneficial for me to step away, give myself a breather, and come back with a fresh eye.  I finally figured it out!!  I basically put the "layer pixel count/dialog box function" within the functions that are already in the switch statement with an "if/else" and voila,.... it worked perfectly!  I want to thank you so, so much for all of your assistance, patience, and especially for the learning experience.  I wouldn't call myself anywhere near 'proficient' in javascript now, but I do understand so much more than I did when started this script rewrite.  Once again,... much appreciation; I wouldn't have been able to figure this out without your help.
Thank you,
-Eric
Glad you got it figured out. I've been a bit swamped with other things, so haven't had time to look at it.
