Hi there,
When I make a selection, press refine edge, en want to do something with my brush, it's just not possible.. My mouse becomes a circle with a line , and when I click on the image, I only hear a pling..
The edge detection doesn't work either.. Nothings happens when changing the value
What to do? Any ideas?
Did you try resetting your preferences?
1. Exit the application
2. Press and hold Alt+Control+Shift (Windows) or Option+Command+Shift (macOS) as
you start Adobe Software. You may be prompted to delete the current settings. The
new preferences files are created when you start the application.
Problem solved! Thanks!
