Sound recording is distorted and slow
Aug 21, 2017 Aug 21, 2017
I have tried to record directly fro mteh Mic and also importind a pre recorded file, as well as a song.
The result is all the same - s-l-o-w motion sound, almost like 40% speed or less and not synced with the mouth.
Any suggestions
688
Adobe Employee ,
Aug 22, 2017 Aug 22, 2017
Hmmm, check your CH preferences and play with the settings below, especially that last checkbox...it sounds like there's a sample rate issue.
On my side the sample rate is locked at 4411 / 192000hz
On mine no attempt to force hardware . . . .  either.
Also Device Class is locked at MME (no additional options)
Don't have on my version the I/O Buffer Size
Appreciate any other insight or suggestions
Adobe Employee ,
Aug 25, 2017 Aug 25, 2017
If those options are locked, that sounds like the issue. I see several options under samples and Hz on my end. You may want to try another type of mic (USB? headset?) and see if that helps.
Aug 24, 2017 Aug 24, 2017
Was perplexed for a couple weeks. Had to work on a different computer to get an animation done. It was definitely the sample rate! Once I dropped it from 96000 to 44100 the issues went away! Thanks so much. I wonder if it installed with those settings as a default?
