I use the Pattern Stamp Tool (PST) from time to clone paint from photographs. I make a pattern from a whole layer image and paint from it, using the PST as a brush. I set the tool to Aligned and Impressionist modes. An oddity which I noticed some time ago but failed to investigate, cropped up again today working on a new picture. That is, the top edge - about a couple of mm - is shaved off the top and added to the bottom of the image. So, I am painting from a pattern made from a (layer) image that has been shifted up a little. You can see the effect that appears after painting from the pattern below:
(the top of the image)
(the bottom of the image)
You can see a thin band of sky appearing along the bottom of the image.
It is not the end of the world, but I am curious as to why it happens and if there is a simple way to ensure that pattern and derived image are all square. I wondered if perhaps it is something to do with the Impressionist setting. You can see that "Aligned" is already selected. Here are my tool bar settings:
Grateful for any advice.
David
Hi David
I can get this to happen if I brush with the centre of the brush just off the canvas. It looks like it then treats the brush centre as a new "tile" of the image so if I brush along the top I am using the bottom of the new tile.
See below which is taken from an image with a dark top edge and light bottom edge
Brush centre just inside the image - no impact
Moving the brush centre just off the canvas and I pick up the image from the bottom
So the answer appears to be keep the brush centre just
...Copy link to clipboard
Hi David
So the answer appears to be keep the brush centre just inside the image.
Edit to add : It only happens with the Impressionist setting checked
Dave
Dave - much obliged. Thanks very much. If I select the layer I am painting into would that stop the "overbrush"?
David
Hi
Surprisingly, to me anyway, I tried "select all" on the layer to be painted earlier - fully expecting that to work. It didn't
Dave
Yes, I just tried it too and the brushed pattern still spills. Hmm..
David
