Se sposto verticalmente una tabella contenente testo, questi cambia la linea di base, cambiano le altezze delle celle e molte volte parte del testo esce dal contenitore.
If you vertically move a table containing text, it changes the base line, it changes the heights of cells, and many times the text comes out of the container.
Hi franz_tecnosteel,
As per your query, when you move a table containing text vertically, it changes the table dimensions and sometimes times the text leaves the cells.
I tried the same at my end but I was unable to reproduce the issue. Please check if this is a problem with one file or multiple files. If the issue is with one particular file would you mind sharing your file?
Regards
Srishti
