from another server (server02),what is the solution to merge
a new pdf document on server02 from theses urls from server01?
I try with cfdocument but it doesn't work...
I don't expect it to. Cfdocument is for converting from CFML
and HTML to PDF, not for merging.
Since you're on CF8, you can use the cfpdf tag. The following
example downloads two PDF files, then merges them. However, I get
the feeling there should be a more efficient way.
