I'm having problems using the photoshop brushes. whenever i try to use them instead of a normal line, i get squares. I've tried everything i could think of. Does anyone have a solution to this ?
What size brush and paper are you using? What magnification is your document on? I can reproduce this effect if I use a small brush at high magnification so that individual pixels show.
I've tried different brush sizes and also paper sizes. The result is still the same. Also magnification is normal. Whether it's a high or low, i'm still getting those same results.
I think your document has a low resolution...
Please create a new photoshop document:A4 size, 300 dpi resolution.
Then select a brush 10 pixel wide and try to draw.
I did try that earlier before I put up my question here but it didn't help.
Please read this:
FAQ: How do I capture and post a screen shot or video?
Could you please post a screenshot taken at View > 100% and with the pertinent Panels (Layers, Channels, Options Bar, …) visible?
